Question about Anchor Audio/PA Systems: Megavox Pro Deluxe Microphone
Megavox model pb-35W
The PA system chargers but will not power up. I opened it and it turns out that if I take out the fuse then put it back in it powers up, but when I turn the power off then on again it doesn't want to turn on. Fuse works fine, connection is troublesome. My question: is there a way to work around this??
When I connect charger with my laptop 30 sec show battery is charging after 30 sec one message show:- QuickSet The Ac power adapter type cannot be determined. your system will operate slower...
del recognition circuit may have failed in charger , or could be fine central pin on charger plug or laptop plug has broken connection,it is used to tell laptop that this is genuine dell charger.If you remove battery will laptop work off charger.if does then definitely one of the three problem possible . for first only soln try another dell charger first,often has to be one to suit your model ,common dell problem ,if then work and charge battery ,you will need to replace charger as recognition circuit failed. If either of last 2 can repair but need to pull apart repair broken connection ,or open up laptop and check power connection and repair connection . If you remove battery will laptop work off charger.if does the definately one of the three problem possible . for first only soln try another dell charger first,often has to be one to suit your model ,common dell problem ,if then work and charge battery ,you will need to replace charger as recognition circuit failed.
Oct 27, 2013 | Dell Inspiron 65W PA-12 1525 LAPTOP
GERICOM laptop power charger - Liteon model PA-1900-005
yes this is common rating for laptop any laptop adapter can be replaced see the output voltage and current of another adapter matching . if connector is not matching then solder the matching connector
Mar 03, 2010 | Computers & Internet
Looking for manual Realistic MPA-40 35W
I have a realistic mpa-40 35 -watt pa amplifier owner's manual
cat, no, 32-2032A
You can conyact me @ ltlerock@aol.com
Jan 03, 2010 | Audio Players & Recorders
Radioshack 250 watt pa amp stopped making sound
for the past month i have been shopping for the perfect home theater system and have narrowed it down to a bose system,a sony system and a paramax p510...i have listened to all 3 systems and have found the paramax to be the better system not a cheaper system but seem more bang for my buck at 3200$,a very powerful tube amp and downfiring sub maxes out at 2000 watts...
Nov 14, 2009 | Radio Shack 250 Watt PA Amplifier...
PLAYER WILL NOT TURN ON AT ALL
There is a fuse on the back of he player usually right above where you attach the wiring harness.
May 21, 2009 | Pioneer DEH-245 CD Changer
Motherboard having a system password , idonot know what is its pa
Open the case and look for a jumper switch (usually blue or black color) labeled CLRTC or CRL. A jumper switch is a small connector connecting two pins on the motherboard. Same like the one in CD ROM drive or hard drive for selecting master or slave.
If you find it, unplug the power cable, remove the jumper. Wait 10 - 15 seconds, then put it back. Plug the power cable and try power up your computer.
Dec 25, 2008 | Dell Dimension 2400 PC Desktop
Pb avec le son
Dear Sir,
Ihave a COMPAQ PRESSARIO Computer model MV520. Lately I am getting lines on the screen at the bottom. Suggest the remedy.
K.S.Bajaj
Jun 16, 2008 | Compaq Presario X1000 Notebook
Anchor Audio/PA Systems: Megavox Pro Deluxe Microphone Logo
3,386 people viewed this question
Top Anchor Audio Players & Recorders Experts
Michial Gueffroy
old marine
old marine
Tom Chichester
Are you an Anchor Audio Player and Recorder Expert? Answer questions, earn points and help others
