Question about Refrigerators
Icemaker won't make ice
240556500 is the number on the freezer door by icemaker instructions.
I have a Frigidaire ref/frzr M#F44N21C. Quite awhile ago. while moving the fridge, I broke the copper line going to the icemaker. I finally got around to replacing the line with a flex hose, but now the ice maker doesn't work!?! The metal arm moves up and down but nothing else happens. Any ideas?
  • 114 Answers
First, check to make sure you have water pressure at your supply line. (flex hose) If you have pressure and the icemaker is cycling, (arm moving up and down on its own) you most likely have a defective water inlet valve. This is the valve that the supply line connects to. Water is fed to this valve through your flex hose and then passed through a solenoid to your icemaker when the solenoid is energized.
Posted on Mar 04, 2008
I have a GSS221FRFWW with and ice and water dispenser problem. The light in the dispenser has gradually gotten dimmer, and the water won't dispense unless you remove the light bulb. The ice maker...
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Sep 30, 2011 | Refrigerators
Ice dispenser will not put out any ice
NOTE: This
Leo Ponder
imufo2
Sep 23, 2011 | Frigidaire 22.6 Cu. Ft. Side-by-Side...
Maytag VFI2569VEM icemaker won't make ice
NOTE: This
Leo Ponder
imufo2
Sep 20, 2011 | Maytag Refrigerators
The ice maker on my side by side frigidaire refrigerator has stopped automatically making ice. This model has the through the door crushed or cube ice and water/light dispensers. I can lift the wire to...
NOTE: This
Leo Ponder
imufo2
Sep 19, 2011 | Frigidaire Refrigerators
Ice Maker Problem Need Ice Maker Manual
NOTE: This
Leo Ponder
imufo2
Sep 19, 2011 | Frigidaire FRS26R4A Side by Side...
Frigidaire side by side ice maker not working
NOTE: This
Leo Ponder
imufo2
Sep 16, 2011 | Frigidaire 20.6 cu. ft. Top Freezer...
Icemaker is not working. water supply is on
NOTE: This
Leo Ponder
imufo2
Sep 14, 2011 | Frigidaire FRT21S6J Top Freezer...
Frigidaire model # fsc23bbdsb3 ice maker problem after long power outage
NOTE: This
Leo Ponder
imufo2
Sep 10, 2011 | Frigidaire Refrigerators
We have a Frigidaire Gallery refrigerator. We turned the water off in the house while we were gone on vacation and now the icemaker won't work.
NOTE: This
First I would check the fan in the freezer. Listen to see if it is running
Leo Ponder
imufo2
Sep 09, 2011 | Frigidaire 14.7 Cu. Ft. Top-Mount...
Ice maker not making ice on frigidaire
NOTE: This
http://www.applianceaid.com/procedures.html
I'm
Leo Ponder
imufo2
Aug 23, 2011 | Frigidaire Refrigerators
Refrigerators Logo
804 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
