Lens Replacement I have a pioneer CD player. the lens was out when i opened the equipment. Now my problem is to know if it is possible to replace that lens. Small disc is glass who is in DVD, CD player.
SOURCE: Kawasaki #SVP500 5-Disc DVD/CD player Manual
http://www.18002526123.com/productdocuments/SVP500.pdf
Posted on Mar 21, 2007
SOURCE: Broken DVD player
it is not possible but what u can do is find another same model(which does not work from used up product market ) writer and open it take out the try watch carefully how it is fixed to the writer,now open all the screws of your writer carefully,and replace the one which you have bought from used up items.fit all the screws back and check if it works. if it does not then i am sorry to say you will have to buy a new one.But ya u cld do 1 thing check if the warranty is still there if yes then quickly replace it.
hope this will solve ur prob. plz rate me.
Posted on Dec 07, 2007
mjap
  • 107 Answers
SOURCE: Fisher CD-RW1000 2-Disc CD-dvd stuck in player
hmmmm.... try to take off the cover of your dvd player and observe it.(if you try my advice, try it in your own risk and with caution) then check the tray maybe there is something got stuck in there and also check the gears, if nothing, a belt just came off. check the motor too, I guess It has 2 switches too. clean them up. and then try to power up.
note:
(keep you fingers away at the power supply section)
Posted on Jan 30, 2008
SOURCE: pioneer pd-m406 cd changer magazine style
The Pioneer component 6 CD magazine changers only play normal store bought CDs, not CDs you make yourself.
sorry.
Posted on Feb 20, 2008
  • 4234 Answers
SOURCE: U3 error for my pioneer pd-f605 100 cd player
I don't have the service manual with me at the moment and I'm on the road. I'll look up the error code and update this somtime tomorrow.
Dan
Posted on Aug 27, 2008
Can't get a dvd or cd to play
how long have you been using this player? I suspect the laser (lens) of the player. I think the laser (lens) is weak that's why it cannot read data/files on DVD discs.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Good luck.
Jan 29, 2011 | Pioneer AVH-P5700DVD Car DVD Player
Pioneer cd player in truck stopped working
The lens is all worn out. It has reached its end of life. Time to replace the cd player... or if you can find a replacement lens. you can still use that player.. its an old player though, there are lots of new technology with the new players on the market.. its better to just get yourself a new one =)
Jun 21, 2009 | Pioneer DEH-2800MP CD Player
Pioneer cdj 200 wont read discs
Hi, try cleaning the lens with a cleansing disk. if this doesn't produce results, it will confirm a major issue within the lens assembly. you will need to replace the lens assembly in this case. it is unable to track or read in this damaged sate.
May 19, 2009 | Pioneer CDJ-200 CD Player
Fading
You can order the entire cover, if you'd like. And there are some generic metal colored covers available for them.
Also, we offer custom artwork in the form of a vinyl wrap for the CDJ units.
- OPTiC
Repair Videos
Pioneer DJ Repair
DJ Equipment Sales
Pioneer Parts
Nov 22, 2008 | Pioneer CDJ-1000MKII CD Player
Cd malfunction
Lens cleaners aren't enough. You might have to take it to a service center to have it opened up and professionally cleaned.
If there is no damage to the cd traverse assembly, then the issue might be with either the quality of your burned CDs, or method used to burn.
I always tell people to burn at slow speeds - 4x is ideal. Yes, I know it's slow, but it will burn your cds at a better quality.
- OPTiC
Pioneer DJ Repair Videos
Pioneer DJ Repair
Pioneer DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Jul 01, 2008 | Pioneer CDJ-800MK2 Turntable
Opening
the flexible pcb in the unit is broken and you will need to replace it, the pioneer part number for the replacement is CNP 6869 this is a replacement kit
Dec 07, 2007 | Pioneer DEH-P8500MP CD Player
Cd player wont play
The error code is a mechanical error fault, possibly something in the mechanics that load the CD onto the spindle motor. The only sure way to know what the problem is, is to open the unit and let it load a disc and see what happens. The problem may also be due to a very dirty laser lens, with a dirty lens the laser won't be able to read the TOC (table of contents) and all the CD's will cycle through the changer and a error code will be set. Best of Luck.
Sep 12, 2007 | Pioneer DEH-P6600 CD Player
ND message
It might be an older CD player that can't read computer-made discs, or it could be a disc incapability... If you sure that the system supports the disc's format.. And it won't play other discs... try to clean the CD lens. CD lens cleaning discs: Every CD, stereo equipment, department, discount, store - and even sidewalk venders - carries CD lens cleaning discs. Are they of any value? Can they cause damage? I generally don't consider CD lens cleaning discs to be of much value for preventive maintenance since they may just move the crud around. However, for pure non-greasy dust (no tobacco smoke and no cooking grease), they may not hurt and could even do a good enough job to put off a proper cleaning for a while longer. However, it's also possible they will ruin the lens. Consider that the worst thing to do to a precision optical surface is to wipe it with a dry cloth as this is likely to scratch the surface as it rubs the dust over it. To the lens, a speck of dust is like a boulder. Once the lens is scratched, replacement of the entire optical pickup is the only remedy. And, since there are absolutely no sorts of standards for these things, it is possible for a really poorly designed cleaning disc to damage the lens even if the dust itself is non-abrasive. In addition, if the cleaning disc doesn't look like a CD to the optical pickup or disc-in sensor, the lens it may not even spin. So, the drawer closes, the drawer opens, and NOTHING has been accomplished! (But at least no damage will be done.) As if this isn't enough, NEVER put one into a high-X CDROM (DVD player or DVDROM drive). The high speed rotation may cause the cleaning disc and/or player/drive to self destruct. And, don't try a cleaning disc on an automotive CD player that sucks in the disk - it will get stuck.
Dec 26, 2005 | GE Slim Spacemaker 7-5295 CD Shelf System
Pioneer PD-F906 Laser carriage at spindle/extended
Dec 26, 2005 | Pioneer PD-F906 100-Disc CD Changer
No Disc
If you sure that the system supports the disc's format.. and it wont play other discs... try to clean the CD lens. CD lens cleaning discs: Every CD, stereo equipment, department, discount, store - and even sidewalk venders - carries CD lens cleaning discs. Are they of any value? Can they cause damage? I generally don't consider CD lens cleaning discs to be of much value for preventive maintenance since they may just move the crud around. However, for pure non-greasy dust (no tobacco smoke and no cooking grease), they may not hurt and could even do a good enough job to put off a proper cleaning for a while longer. However, it's also possible they will ruin the lens. Consider that the worst thing to do to a precision optical surface is to wipe it with a dry cloth as this is likely to scratch the surface as it rubs the dust over it. To the lens, a speck of dust is like a boulder. Once the lens is scratched, replacement of the entire optical pickup is the only remedy. And, since there are absolutely no sorts of standards for these things, it is possible for a really poorly designed cleaning disc to damage the lens even if the dust itself is non-abrasive. In addition, if the cleaning disc doesn't look like a CD to the optical pickup or disc-in sensor, the lens it may not even spin. So, the drawer closes, the drawer opens, and NOTHING has been accomplished! (But at least no damage will be done.) As if this isn't enough, NEVER put one into a high-X CDROM (DVD player or DVDROM drive). The high speed rotation may cause the cleaning disc and/or player/drive to self destruct. And, don't try a cleaning disc on an automotive CD player that sucks in the disk - it will get stuck.
Dec 15, 2005 | Panasonic SC-AK300 CD Shelf System
536 people viewed this question
 Grubhead
Grubhead
