Question about Kitchen Ranges
Cooker AEG Double oven, Bottom oven stopped working. Changed the element. the fan does not seem to run as before. seems slower
  • 549 Answers
If you are getting the proper amount of heat from the oven, then you should check out the fan circuit.
There should be a wire diagram somewhere on it. If not let me know and I will try to find one.
Please give make and model number.
Posted on Mar 04, 2008
Replaced EOU43002X element, clock/timer now dead
Make sure there is power to the timer. Should be a fuse somewhere.
Mar 19, 2014 | Electrolux Ovens
Can't get the bottom oven working on my Zenith 50 cooker
Is it electric oven? Element gone most likely cause. Does the light and fan still come on?
Sep 05, 2012 | AEG Ovens
Hi. Just need to know if the oven door is adjustable on our AEG electric double oven cooker? The bottom oven seems to 'leak' hot air slightly from the top right hand corner and when you press on the same...
there will be a slight adjustment that can be done if you undo any screws or bolts holding the door , no need to take them completely out but just enough to re position the door , make sure there are no hinges that are bent .
Nov 18, 2017 | AEG Ovens
How do i replace the element in the bottom oven of an AEG U3100-4 cooker ?
If it is a fan assisted oven, remove the screws securing the rear cover inside the oven compartment, remove cover, and you should see the oven element there.
Undo the element, and fit new one.
Aug 04, 2010 | AEG U3100-4 Electric Double Oven
Aeg d5701-4 bottom oven slow to heat up and does not reach set temperature fan works
It sounds like the oven element is not working.
To check it, remove rear panel in oven compartment, after running it for a few minutes, it should be very hot to the touch, BE CAREFUL, DO NOT BURN YOUR FINGERS.
Apr 21, 2010 | AEG D5701-4 Electric Double Oven
Aeg 3050b oven not getting hot fan running and both lights on no heat even when turned to 275 degrees oven was working ok yesterday but seems to have gone all at once
Does the thermostat click and the light go off and on when you turn it up and down if so it is mechanically working.
Fan will run irrespective of element working
Either the element has failed or the connections to the element
Both require you to take the back off the machine to check them out
Jan 26, 2010 | AEG B2100-4 Electric Single Oven
AEG Competence D2160-1m2 (double oven)
You neede to replace the oven element.
This is located at the rear of the oven compartment behind a removeable cover.
Nov 29, 2008 | AEG D5701-4 Electric Double Oven
Top oven (and Grill) have stopped workingMy 3 Year old AEG Competence D2100-4 Double oven has malfunctioned.  Bottom (main oven) works fine but top oven and grill have ceased to function.  The fan will run...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Nov 12, 2008 | AEG D2100-4 Electric Double Oven
Kitchen Ranges Logo
120 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
