Toshiba tz55x71 won't turn on
I can't turn on the TV once I have turned it off unless I unplug it then plug it back in?
Thanks
Steve
  • 552 Answers
Http://fileshare.eshop.bg/index.php?what=search2
If you are a little handy, there is alot of information here.
If not, I will dig for info.
Posted on Mar 04, 2008
What's your problem? won't turn on..... yellow/orange light continually flashes three times...
Toshiba Regza 37in - 37HL17
TV will not turn on - Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: 2007SEN069.zip (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
09adb97e-8925-4d59-b218-7443a6e64989.png 82ea33aa-2353-4e13-a5db-8be13ba85711.png
Aug 06, 2012 | Toshiba Regza 37HL17 37 in. LCD TV
Resets by itself to factory settings at least once every day. also will not hold favorites list once tv is turned off.
Unplug it, press and hold the power button down for 30 seconds, plug it back in and turn it on.
Jan 06, 2010 | Toshiba 40RV525U 40 in. LCD TV
Toshiba 50hp95 will not respond and has flashing red power light. It seems many people have this problem, what's the solution? We have tried all the Toshiba suggestions.
My 50hp95 had the same problem; the red power light is flashing and the tv will not turn on. I unplug the power and plug it back in and the TV clicks, but the power light continues to flash red. My problem was a bad Seine module which you can bypass if you do not need to watch HD off air programming. Since I get my HD from the cable, I can bypass it. All you need to do is remove the back panel from the TV (unplug the TV first) and on the main circuit board unplug the white connector labeled PJ63A. The main circuit board is the one in the center of the TV and the PJ63A connector is the bottom white connector on the left side of the main circuit board (the label is printed in white on the circuit board under the connector). Once I plugged the TV back in it worked immediately.
Sep 09, 2009 | Toshiba 50HP95 50 in. Plasma Television
Toshiba tv will not turn on
I have a toshiba tv and it will not turn on. There is a flashing green light that comes on, but there is no picture or sound.
Oct 31, 2008 | Toshiba DVD Recorder AND Series2 TiVo...
Won't Turn on, standby LED lit
HI,
I am having the same problem, any solution? Thanks! -Steve
Aug 19, 2008 | Sony KP-61V80 TV
TOSHIBA TZ55X71
Sounds like something minor in the standby voltage circuitry, However it will eventually prevent the set from working. I would check the voltage regulators and capacitors in the power supply.
Feb 24, 2008 | Televison & Video
TZ55X71 screen and protector broken part #'s??? How to clean lenses???
http://free.atozmanuals.com/index.jhtml?partner=^CG7^xdm524&s1=adwords-22e539d9e6369d28d62ae4a9a56a40ce&s2=5498ad8d4dd2413b934ce0ce75dd43fa5a5a4bdd&s3=&s4=&s5=&utm_source=adwords&utm_campaign=808986899&utm_term=segment+ski+8933745652033491368&mt=&network=d&kid=kwd-10009911&aid=41398201826&lpurl=http%3A%2F%2Ffree.atozmanuals.com%2Findex.jhtml%3Fpartner%3D%5ECG7%5Exdm524&gclid=EAIaIQobChMIiqrvqcXV2AIVi4TtCh3XngsqEAEYASAAEgJh1vD_BwE
Jan 13, 2018 | Televison & Video
Television will not turn on consistently
There are far better experts from this site who would know more if you can post back specific model no or preferably the Chassis no. of your Toshiba.
Just to start the ball rolling, to my knowledge, most models of CTVs since a few years back uses an internal mini computer. Like any computer it does need to be reset and in your case, unplugging (actually for a few hours) performs a hard reset . For a few minutes is a soft reset.
At times, the standby led or power led would also flash a certain sequence to indicate if there is an internal fault detected by the protection circuitry. By unplugging, you did a reset on the protection circuitry and if your problem is intermittent or develops over a period of viewing time (chances are heat related problem), then the protect will auto activate and will not allow power on the next time (if the unit is plug).
Hope that this be of some initial help/idea. Please post back and I'm sure others would be offering detailed assistance thereafter.
Good luck and kind regards.
Nov 13, 2007 | Televison & Video
Televison & Video Logo
163 people viewed this question
Top Televison & Video Experts
