Question about Dishwashers
Whirlpool dishwasher blinking light
I have a blinking greenlight over the clean button. I have tried to "key dance" but it still wont go through a cycle, it will try but stop about 5 min. into it. Can you please help me.
Thanks
  • LadyP_97 Sep 07, 2008
    Removed kick-plate to see how to repair blinking green lights. Was told that the keyboard needs to be replaced. If I bought this dishwasher 12/07 & registered on-line, will this be covered under warranty? Also, how do I go about having this work done?
Keysequence to reset
heated dry
normal
heated dry
normal
all lights will come on
then close the door
then clean light should go off
Posted on Jun 30, 2008
  • chmich1999 May 13, 2011
    Yes !!!!!!!!!!!!!!!!!! Success
    President:
  • 2,651 Answers
Remove the bottom kick panel there should be a tech sheet glued behind it w/a full trouble shooting portion , your problem is listed there
Posted on Mar 04, 2008
Mine didn't have a technical sheet under the kick plate.
Mine didn't respond to the key sequence either.
We took a power hit and it wouldn't reset. I went to the breaker box and killed the breaker for about a minute, then turned it back on. That reset it completely. Normal operation now.
Posted on Mar 13, 2010
Flashing clean light
check behind kick plate for service manual. To clear 7 blinking lights go into diagnostic by doing a finger dance, touch hi temp scour then air dry till it goes into diagnostic this will check all systems .Once finished you will most likely need to change the chopper and junk in or around the sump Cheers
Dec 08, 2013 | Whirlpool Gold 24 in. Built-In Dishwasher...
Tip
Flashing or blinking green clean light 7 times?
This dishwasher looks for a temperature rise of the water during a heating cycle if it fails to see this rise for multiple cycles it may shut down and blink the clean light 7 times.
The failure can be wide ranging here are a few things to check before resetting the control.
-The unit not being level so both door switches do not make contact
- The sump plugged up so water is not pumping across the heater (see sump clean out below)
- Not enough water filling the dishwasher
- The heat element is not working
To reset the control use this key dance within 5 seconds press:
HEATED DRY, NORMAL, HEATED DRY, NORMAL
This will cause you to enter the diagnosis cycle once this is finished or you hit cancel the control should be unlocked and ready to use.
Here is a link for instructions on sump clean out
Poor cleaning or noisy Whirlpool KitchenAid or Kenmore
General Dishwasher washability
White powder hard water calcium residue
on Apr 25, 2010 | Maytag MDB8959AW Builtin Dishwasher
Hi my dishwasher won't turn on because the CLEAN Button is blinking what does this mean?
Maybe it blinks 7 times? Most likely the unit did not see the correct temp of water and thinks the heater is not working. you can usually clear this code with a "button dance". usually the 2 buttons are dealing with heated dry cycles or sanitary cycles. press one then the other repetitively 3 to 5 times, eg.(sani-cycle>heated dry>sani-cycle>heated dry...)
Apr 14, 2011 | Whirlpool Dishwashers
Kitchenaid KUDS01FL -Dishwasher - "clean" light wont stop flashing; cant start a new load
The clean light usually will blink due to a failure to heat the water properly. This dishwasher looks for a temperature rise of the water during a heating cycle if it fails to see this rise for multiple cycles it may shut down and blink the clean light.
There are a few things to check before resetting the control.
To reset the control use this key dance within 5 seconds press: HEATED DRY, NORMAL, HEATED DRY, NORMAL
Thank you !
May 20, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Whirlpool quiet partner 1 # DU1055XTSQ2
Read this article, it should address your problem.
http://fixitnow.com/wp/2006/03/20/whirlpool-built-dishwasher-includes-kitchenaid-and-some-kenmores-wont-start-clean-led-blinks-seven-times/
http://tclaundryrepair.com/
Feb 24, 2009 | Whirlpool 24 in. DU1100XTPS Built-in...
Whirlpool gold
First press your "Sani-rinse" button and the your "Heat Dry" button and toggle between them a couple times. This will reset your control module. If the clean light continues to blink then it means that your heating element needs replacing.  This is not a big job, either. You will need to order a new element and come back for instructions if you can't figure it out quickly....
Dec 16, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool gu2400 clean light is blinking 7 times
Yes this is a heater fault detection error. The unit may not be heating the water resulting in unsanitary dishes so the unit shuts down in this fault. Also the door may not have completely shut resulting in the heater not working, but everything else does (the heater common line is broken at the door switch. Clear the fault by entering diagnostics with this key dance heated dry, normal, heated dry, normal. All the leds will light, you can then press cancel and try another wash cycle. If fault occurs again, you must repair heater problem.
Dec 23, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Diswasher not working
If you have a Kitchenaid. You need to press in this order.... high temp, energy saver dry, high temp, energy saver dry, the lights will all start blinking, after they are done the cycle will start. Press cancel twice. ;)
Dec 07, 2007 | KitchenAid 23 in. KUDD01DPPA Stainless...
Clean light flashing
The clean light should be blinking 7 times, pause, then repaeat if it is doing this -- it is a water heating fault. Use one of the following key dances to clear fault
a) Heat Dry - Normal - Heat Dry - Normal
b)High Temp-Air Dry-High Temp-Air Dry
All the Leds should light up now just press cancel and Unit should operate. If it shuts down again the heater isnt working properly. Some times the door doesnt get shut well and that causes the fault. But the dishes arent very clean if the heater is not working.
Oct 16, 2007 | Whirlpool 24 in. DU1055XTPS Stainless...
Clean light stays on
Chamer, do you have high temp wash, heated dry pads on the control panel? If so do this key dance...high temp wash..heated dry..high temp wash...heated dry. The panel should light up and go through the test mode. Im assuming the clean light is flashing. Post back, let me know..Catriver.
Apr 09, 2007 | Whirlpool 24 in. DU1100XTPS Built-in...
Dishwashers Logo
3,213 people viewed this question
Top Dishwashers Experts
