Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Channels 3,4,5,6 no picture
Get fuzzy screen on these channels all other channels are fine
  • Anonymous Aug 10, 2008
    CHANNEL'S 3,4,5, AND 6 DON'T COME IN .OTHER CHANNELS WORK FINE UNABLE TO HOOK CABLE BOX TO TV.
    Genius:
  • 1,030 Answers
I have seen this on our cable system at the shop. it could be the system of most likely the tuner in the unit is haveing issuses.
Posted on Mar 04, 2008
My panasonic TX37 lzd 80 tv has on screen message no signal on some freeview channels and the picture is fuzzy
Change your main board but before check if the power supply is ok. Good luck,
Serge.
Feb 26, 2016 | Panasonic Televison & Video
The screen has a picture but it is green purple & pink & a little fuzzy,channels turn fine sounds of seems to be a tuning problem is this worth fixing or time to throw out tv is 3 years old
hi
This is not a tuner problem . The blue color is missing and the cause is the main board if you are handy with tools you could find the part#
printed on he board and find it on ebay
Sep 29, 2010 | Emerson EWL3706 37 in. LCD Television
Why is the screen fuzzy?
Make sure that all of your wires are firmly connected. I am assuming you are using an RF adapter. Check whether the "Channel" switch is set to 3 or 4, and then make sure you TV is set to the same channel..
If this does not work, let me know and I will assist you further.
Jun 14, 2010 | Sega Genesis Console
Cable picture is fuzzy
Call your cable company as there might be a problem with the drop line or aerial coming into your house. now another thing is if you have a signal splitter( ex: 2-way, 3-way, 4-way) before the cable box, that could be degrading the signal as each input may drop the signal significantly. remeber, don't use too many splitters as they will make the signal faded/fuzzy. also, make sure all the connectors are clean and are not badly bent or the ends frayed. If you can see wire insulation from the cable line then it's no good.
Apr 05, 2010 | Insignia 42" LCD Flat-Panel HDTV
When viewing photos it?s striped/fuzzy
Try pressing the up/down on the multiselector. Does that change the view? If so, you've just discovered how to cycle through different views of the image.
If that doesn't do anything, then do the menu and info screens come up correctly, or are they also striped or fuzzy? If so, then the camera may need servicing.
Jan 12, 2010 | Nikon D3000 Digital Camera
Fuzzy tv screen that says lost signal (no dishnetwork signal)
Here are a few suggestions,
*Check your connections to make sure none are loose.
*Try checking the Dish box to make sure everything that should be turned on is actually on.
*Also make sure channel 3 is the correct channel by contacting your service provider.
I hope theis solution is helpful. Please take a moment to rate this solution.
Feb 12, 2009 | Televison & Video
Vizio 42'' LCD having intermittent fuzzy screen on stdrd channels
you might have an overheating problem- make sure you have adequate ventilation around your tv
Nov 25, 2008 | Vizio GV42L 42 in. LCD Television
Scrambled picture
Which caps on which boards as that sounds like a issue with the signal and FMT PCB. The v26 chassis like yours has problems with bad caps on the DM, Signal, FMT and the PWB and terminal
Jun 28, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Partial screen picture
bad caps in the vertical section
Dec 14, 2006 | Quasar SP-2722 27" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
51 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
