Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Washing machine works, but wont do spin cycle- clothes sopping wet but clean
Wife noticed the beginning of a tiny burning smell too lately. clothes clean, but very wet since spin cycles seems to not work any more.
this is the washer
wondering if repair is cost-effective or i should buy a new washer...
http://www.epinions.com/pr-Whirlpool_LSQ9549L_Washing_Machine/display_~full_specs
  • 1 more comment
  • Morts Mar 04, 2008
    Hi, I have the same problem, washer will not spin. There is power to the machine but no spin cycle. Model # LSR6332KQ1, Sr. # CR1870500
    Thanks
    Delroy Mortimer
    delmort@hotmail.com
  • EdLemko Mar 04, 2008
    thanks for the response. wife said that it agitates, and cleans the clothes, but the spin cycle never starts, and the clothes are just sopping wet, but clean.
  • Anonymous Mar 08, 2008
    My washing machine washed and as it went into the drain and spin cycle it made a loud noise like something was stuck somewhere. After I turned it off the noise sounded like a ratchet slowing down. It drained but did not spin. After pulling it out from the wall, noticed oil on the floor. Any help would be appreciated.
    President:
  • Whirlpool Master
  • 2,651 Answers
First off check to make sure its spinning at all. although the waters draining is it really spinning? are the clothes stuck to the side walls as if they had??if so i would tip machine back and look on floor and around the inside of cabinet approx 12 in. from ground level looking for oil,( transmission oil) . if present youll need a new transmission and clutch assy
Posted on Mar 04, 2008
Maytag Performa clothes washer. Model LAT2500AAE. Made screeching sounds during spin cycle also burned rubber smell. Turned off. Removed and replaced belts. One belt was shot. Ran a test run and still...
Check to see if your water pump is spinning. It could be seized up and the burning smell could be the belt spinning on the seized pulley. Good luck Friend.
Oct 10, 2017 | Maytag Washing Machines
Clothes sopping wet at end of all cycles
Here is a tip that I wrote a bout front load washer spinning and draining problems...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 16, 2010 | Frigidaire ATF6000ES Front Load Washer
After the wash cycle is complete the clothes are still wet.
Open the machine and remove the drain pump. Clean out any debris and try again.
Remove the front panel.
The pump should be directly in front of you. Open it and clean it.
This procedure will have to be done occasionally.
Mar 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
GE Top Load Washer WLSR2000G3WW~smells like burning and wont drain
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Nov 06, 2008 | GE WBSR3140DW Top Load Washer
Washing Machine Problem
if this is a sears or roper or whirlpool unit then check the direct drive coupling, if it sound like it should be spinning but doesn't
May 17, 2008 | Washing Machines
Washer smells burning, and is WAY off balance... HELP
if you are handy at fixing such things it is not too terribly hard to fix, but you will need to remove the drum. Hopefully, it is just a worn belt, you will also want to check the clutch, motor pulley and motor coupler. The motor coupler can also produce the burnt smell and the wet clothing. I would say it is definitely worth fixing. Get an estimate and go from there .
Mar 16, 2008 | Washing Machines
Washer repair
The transmission might have locked up causing the motor to overheat.
Nov 10, 2007 | Frigidaire FWS833A Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
830 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
