Put the chain on to the smallest chainring/thats the gears by the pedal,on the rear gear cog move the chain to the smallest gear cog, then release the cable make sure the 123 is at the right position ie no,1 then secure the cable the derailieur should be about 6mm distance from the inside of the chain,you can now finetune via the h/l screws and the cable tensioner
I would start out with the left gear set to 2 and the right shifter set to 4 or 5. If that's too difficult, then shift the left gear to 1.
Most people really don't shift gears on bikes much and that's a shame because it can make cycling much easier. I would advise you to take some time to learn about shifting as it will make riding much easier, especially if there are any hills around.
The left hand shifter is for the 3 large gears in between your pedals. This shifter produces the biggest change in effort. As a general rule, use the first one for uphills, the middle for flats and the last one for downhills. Of course this is all relative to your conditioning. You should attempt to maintain a pedaling cadence of 75-90 (in general) so that you always feel like the pedals are spinning and that you are not grinding it out. The right hand shifter is for the 7 gears on the rear of the bike and are used for smaller changes. Here is a link that will provide more detailed info on this subject. Happy cycling!
http://coachlevi.com/cycling/complete-beginner-guide-to-bicycle-gears-shifting/
