Konica 1112 Copy Machine NEEDS TO LIVE a few more years
I have a Konica 1112 photo copy machine. It draws in dirt and requires frequent cleaning. I am having no success with producing a clear copy, it is streaked with black strips on the copy. WHAT CAN I DO?
  • bpowermom Mar 12, 2008
    Thanks, I have already removed glass, cleaned all mirrors, and also the photo eye. Last week one of the motors went out so it is TOAST!
    Thanks anyway.
  • Anonymous Mar 19, 2008
    Check cassette light keeps coming on, and stops the unit. What is it, where is it and what should I do?
    Thanks
Call a service tech to come in and do a full optical cleaning. Requires removal of the glass.
Posted on Mar 12, 2008
Printing black ground in konica minolta bizhub c220
have a tech come out clean the machine run require procedures to determine problem
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 26, 2014 | Konica Minolta Bizhub C220 Color Copier
Copy of konica 7135 is unclear while running. at first is copy is clear, later the copy is not clear... blurred
try to make some copies from your pc if the results is ok that simply means something with your scanner unit, for exaple the pnnel needs to be lubricated and the ccd unit needs to be cleaned.
Mar 20, 2014 | Konica Minolta Konica 7020 7022 7025 7030...
I HAVE Konica Minolta Konica Minolta C550 .WHEN I USED COPY OR PRINT EXITING PEAPER IS DIRTY OR HAVE BAR BLACK. PLEASE GUIDE ME
"Dirty" could be one of 3 things... Transfer belt, Imaging unit and fuser unit. Make 5 copies in jam the machine by opening a cover. remove pages and see where the "dirt" originates from.
Jan 08, 2014 | Konica Minolta bizhub Office Equipment &...
I have Bizhub 600,when i make a copy, the Df, and scanner are working normally, after that you see in the screen (Read to accept another jop) and the machines does not copy please tell me what is the...
When is the last time a full PM was done. with the counter properly cleared and require procedures where done after the developer and drum are replaced, did you clear the counters for the new drum?? Replacing the heater (FUSER/FIXER is not the problem) A good cleaning in and around the Photo drum and developer section with the developer replaced and counters properly check and so get a qualified Konica Minolta Tech out to look at the machine. My recommendation
Oct 29, 2012 | Konica Minolta Bizhub 600 750 Image...
The screen says the Paten glass needs to be cleaned. What is the paten glass? Also when copies are made a black line is showing up on the edge of the copy.
platen glass means that you need to clean the copy glass - glass where you put the originals for copying.
If you have an auto document cleaner there is also small glass on left side of "platen glass" wich is seen when you open the copy machine cover or dadf.
The black line is probably from dirt on copy glass, I pressume because courectour liquid ( most common ). use some stronger detergent or wd-40 to disolve the dirt and clean with glass detergent and dry it.
If you still have the black line try to print something from machine.If you do not have it on print its the copy glass problem - clean it - again.
Pls.rate
May 09, 2010 | Canon imageRUNNER 1023iF Black and White...
Do you recommend Canon ClC 1180 for business
Depends on what you want to do with the copier. This a graphic's machine if you require high quality photo type output this is a perfect machine. It's not fast and will not run heavy stocks. It performs best with Hammermill color laser paper. If optioned with the Fiery Print Controller it will produce great print from photoshop and other graphics programs.
The CLC-1180 is Service intensive and will require frequent service calls and I highly recommend you have a service contract.
If you just require general office color such as Powerpoint , Word and don't require photo quality output, I would recommend the ImageRunner C-3200, ImageRunner C-3380 or ImageRunner 5180. These machines require less service and cost less per copy to operate.
Feb 19, 2010 | Canon CLC 1180 Copier
Copy with dirty paper
This machine sounds like it needs a service. Is the paper dirty before it reaches the fuser unit? You can check this by opening the door while the machine is printing (if you're quick), if the dirt is on the copy before it is fused to the paper then the origin of the dirt is in the process area - clean the area particularly check the cleaning assembly and clean the transport bed (the assembly that pulls out with a green handle been turned to the left). If it is after fusing then your fuser roller and/or cleaning web (roller) is worn and/or dirty. Some techs wind back the cleaning web to buy more time - good luck
Canon Copier Service Manuals
Jun 08, 2009 | Canon NP 6050 Copier
Konica 1015 copier with image ghosting problem
I hope the correct toner is in there.
It could be that the cleaning blade on the drum isn't working or the charge isn't working right.
Sep 17, 2008 | Office Equipment & Supplies
Minolta 2300DL feed problem
This is a common problem with the majic colors. There is a solenoid inside the machine that needs to be replaced. Not an easy job. This should be done by a tech.
Aug 14, 2007 | Konica Minolta magicolor 2300DL Laser...
Computers & Internet Logo
153 people viewed this question
Alun Cox
David Payne
David Payne
