Question about Intel Motherboard
Motherboard led stop glowing after 10 second.
Connect power cod motherboard led is glow but after 5 to 15 second led off. pl help me solution.
Arun
arun2k5@indiatimes.com
  • Thomas Christopher
    Thomas Christopher May 11, 2010
    My guess is the Power supply is bad. Did you do a check on it?
  • 156 Answers
The problem should be in your power supply unit (SMPS) try replacing it.
Posted on Dec 04, 2009
    Genius:
  • 1,601 Answers
Please let me know how you made out.
Posted on Mar 06, 2008
Projector cp-sx635 lamp indicator glows red (RED). intimate trouble shoot pl
sounds like the bulb will not fire up. most likely cause is the bulb needs replacing
Jan 03, 2013 | Hitachi CPSX635 4000 Lumens LCD Projector...
My compaq prescario CQ45 is not booting up. When I press the power on button, the LEDs are glowing. I could also hear a brief sound as if the fan is operating. After 4 to 5 seconds, the fan also stops...
There are a few reasons/causes of this.
The most common cause is the modem going faulty. Remove the modem and it may come back to life as it can't finish POST.
The Bios has an error, remove the Cmos battery and let the board discharge for 1/4 hour, re fit it and it may POST.
The uProcessor may need re seating and have a bad contact on a pin. Re seat the uProcessor and clean off old heatsink compound installing new.
Maybe as they are the most common I have come across, you may fall into one of them, I hope, otherwise it is a dead motherboard I'm sorry to suggest. Even if the RAM is faulty, it should attempt to POST.
Jan 02, 2011 | Compaq Presario Notebook
3 beep sound
If a PC suddenly fails to boot properly, you should perform a hard reset as the first action. Performing the hard reset will correct many problems. If the computer still does not start properly, select your symptom from the list below to guide you to the recommended corrective actions.
  1. Disconnect all peripheral devices and remove all USB devices and SD media cards. You want to test the computer not the accessories!
  2. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds to drain all residual power and restore default startup settings.
  3. Reconnect the AC power adapter (but do not insert the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a fan or other moving parts turning.
  4. If the computer does not start, the LED lights do not glow, and the display is black, you can perform one or more of the following actions to resolve the no power issue.
    • Verify the computer is receiving power from the AC adapter . Verify that the AC adapter is not damaged and is connected correctly to a working wall outlet plug. Verify AC power is connected to the system board by examining the AC adapter, wiring, and pin connection for damage. The keyboard LEDs will glow when AC power is connected to the system board. Damaged components, like the AC adapter or the pin in the power connector, may require an HP-certified repair.
    • Use a different AC power adapter . If you have access to a different AC adapter or power pack that is designed for the computer, connect it to the notebook and try to start the computer. If you own or have access to more than one notebook, verify that you are using the adapter which belongs to the notebook. CAUTION: Using a power adapter that does not meet the power requirements or has the wrong type of connector may damage the computer. On newer notebook models, connecting the wrong adapter to the notebook may cause the power LED lights to blink but not power the computer.
    • Remove the battery and boot on AC power only . A discharged or defective battery may prevent the AC adapter from supplying enough power to start the computer. To verify that power from the AC adapter is available for PC; remove the battery, connect AC power adapter, and press power button. If available, try using a different AC adapter, that is rated for the PC, and repeat this test.
    • Remove the AC adapter and boot on battery power only . A defective AC adapter may not charge the battery and prevent the computer from booting on battery power only. To verify battery power available for the PC; connect AC power adapter, allow battery to charge for 30 minutes or more, disconnect the power adapter and press power button. If available, try using a fully charged battery, of the same type, from another computer and repeat this test.
      • If LEDS do not glow and the fan or hard drive do not spin, battery may need to be replaced.
      • If tests of both the battery and the AC adapter fail, there may be a problem with system board requiring service by HP.
      • If LEDs glow and PC boots, the AC adapter may need to be replaced.
      • If LEDs glow, but PC does not boot go to LEDs glow, fan is heard, but display is black or blank section.
Nov 21, 2010 | HP Compaq d530c PC Desktop
Thinkcentre M55 8806 power on off problem
May be your computer motherboard wires connection get loose or getting moisture in wires. Or there may be some earthing problem in ur power switch. First, check the wires connection & tighten up properly. if problem persists, check the earthing by power tester. Check you RAM if it is properly tight in the jack.
Dec 26, 2008 | Computers & Internet
Unable to start LINKSYS WVC54GC
If the power light is not on, it could only mean 3 things, power adapter, power outlet and the camera itself. First, try to connect it to a different power outlet, see if power light will come on, if not use a different power adapter with the same power specs, if still power light is not on, then it has camera could be bad. Call linksys support line and have it replace
Sep 24, 2008 | Linksys Wireless-G WVC54GC Network Camera
CONNECTION MOTHER BOARD MSI 7043
connection to the motherboard as per your query is not critical. you can do trial and error method, since an LED connected in reverse will not damage it, but just show no glow. so just reverse again, if it glows then its okay if still no glow then the LED is dead. Anyway, if you need the manual you can download from this link: http://global.msi.com.tw/index.php?func=downloadfile&dno=3825&type=manual
Jul 23, 2008 | Intel Motherboard
No screen light on switching
there are two possibilities
1. you might not properly insert your hardware
2. its broken
resiting it will help
if not replacing it will do
Jan 17, 2008 | Sony VAIO VGN-S150 Notebook
Intel Motherboard Logo
71 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
