Question about ParkerVision SIGNALMAX WR1500 (884181000031) Router
Power Supply I misplaced the power supply. Can someone provide the info from the pack so I can figure out which one it is? Thanks TB
  • 1 more comment
  • TBPA Mar 04, 2008
    Unfortunately it does have that there.
  • TBPA Mar 09, 2008
    Great.
    Thanks, I really appreciate your help.
  • time21 Jun 13, 2008
    I lost the power supply to my Parkervision WR1500 Router can anyone tell me what is the imput voltage is?
Thanks.
Exactly what I needed.
Posted on Mar 09, 2008
  • 807 Answers
Have a look an the underside or back of the unit and see if it has a label on it with the voltage and current requirements.
May be something like 12v - 1Amp or similar like 15v - 800mA,
12v - 1200mA etc. These will more than likely be DC as the power supply has the electronics to convert the mains AC to low voltage/current DC.
If you can find them it will be easy to shop around for a power supply to match. It may also show the polarity of the plug that plugs in to the router from the power supply. i.e. outer = Negative (-), center hole =Positive (+).
Posted on Mar 04, 2008
  • Stuart
    Stuart Mar 07, 2008
    Just found out what you need.
    The original adapter had an output power of 12V DC and 1.2A (1200mA). The
    polarity is center pin positive.
Lost power supply for Seagate 3.5 external drive
You can use it, just make sure that the polarities are the same as the original.
Apr 07, 2008 | Seagate 160GB 3.5" External USB Drive 160...
I have a samsung lcd i have no video
Please replace power supply board in tv that is not providing voltage supply to back light inverter boards in tv, required power supply board is available discount-merchant.com
Click above link to view power supply board image and price info.
Thanks.
Mar 16, 2011 | Televison & Video
What is the power supply for the Norcent 5224pi-072 - I haven't had this connected since moving and I had misplaced the Power adapter and found one that connects, but not sure its the correct one
I haven't solved 'the problem' as I don't have a problem other than the fact that greedy people like yourself can't even tell me the power supply adapter for the Norcent I own...I don't have any problem technically other than trying to figure out what the adpater number is for my norcent 5224pi cd burner...so I'm not paying a chunkc of money for info that is public knowledge about this produvt but seems to be hidden somewhere...I don't want to pay a kings ransom to get info I should find anywhere on this product albeit its 6 years old...
Dec 28, 2009 | Norcent Technologies Computers & Internet
Iv got a 1 tb external hard drive iv pluged a power suply from a toshiba 19 v and i think its blown it there is a little bord concected to the hard drive will that be the problem and if so where can i get...
Improper power supply will cause the malfunction of the HDD. Try to coordinate with vendor/dealer who provided the product and repair the same.
Hope this gives you the information you need
Dec 16, 2009 | Seagate BARRACUDA ES.2 - HARD DRIVE - 1TB...
I am looking for a wiring diagram for my emachine front power switch
Power Supply Types
There are two basic types of power supplies. There are AT power supplies, which are older and in older computers, and ATX power supplies, which you will find in virtually every new computer you can buy.
There are two fundamental differences between AT and ATX power supplies. First, the switch mechanism is different. AT power supplies use a normal on-off switch, which directly turns the power supply on or off.
ATX power supplies use a momentary switch which does not directly control the power. Instead, the switch signals the motherboard, which performs one of three actions:
  • If the computer is off, the power supply is turned on (which turns the computer on)
  • If the computer is on, the computer goes into power-saving mode (standby)
  • If the switch is held for more than 4 seconds, the power is cut and the computer turns off.
Because of this difference, ATX power supplies are better for projects that require the second power supply to turn on automatically when the computer is turned on.
The second difference is in the motherboard connector: AT power supplies provide two 6-pin connectors (figure 1), which are easy to insert backwards. The ATX connector is a single 20-pin connector that only plugs in one way (figure 2).
Figures 1 and 2: The difference between AT (left) and ATX (right) motherboard connectors.
Both power supplies provide two types connectors for plugging devices into. These connectors are called Molex connectors, and they come in two sizes (see figure 3 and 4). A power supply will generally have a few of each size.
Figures 3 and 4: Large (left) and small (right) Molex connectors.
There is no difference between the two sizes other than the size itself. Both sizes provide the same amount of power to whatever device is plugged into it (12V and 5V). The small Molex connectors are generally used only for floppy drives. Large Molex connectors power hard drives, CD/DVD drives, and many fans and lights as well.
Note: You can purchase large and small Y-adapters if you run out of Molex connectors. Be careful when using the Y-adapters however, because if your power supply does not have enough power for all the devices attached (especially true for older, lower-wattage supplies), you can damage it.
Dec 03, 2009 | E-Machines eMachines Desktop PC
I have misplaced the power cord for my x1200 model printer
You may check on ebay for a power pack, otherwise you'll have to buy one from Lexmark or someone who sells Lexmark supplies.
Jul 27, 2009 | Lexmark PrinTrio X75 Printer
Laptop will not power on at all.
Don't know what you have for a laptop, so will have to give you a generic process, here. Power down. Remove hard drive, remove cd reader and/or floppy drive. Remove memory cards. Replace only 1 memory card in the main slot (probably marked as slot 1). Try to power it back up and let us know what happens.
Thanks!
Ron-
Nov 02, 2007 | Computers & Internet
ParkerVision SIGNALMAX WR1500 (884181000031) Router Logo
127 people viewed this question
Top ParkerVision Computers & Internet Experts
Folusho Adeyanju
Folusho Adeyanju
Percy Silwane
Level 1 Expert
Are you a ParkerVision Computer and Internet Expert? Answer questions, earn points and help others
