Question about Pioneer DEH-P3500 CD Player
Won't reset/no input on bottom bar
Display panel is fuctional except for the reset button. Bottom panel/adjustment panel is non functional. Can't change radio stations manually or with presets. Unit will not reset. sugestions? i do not get any power at all to the head unit, wont turn on or off is there a fuse in the back of wire harness and where is the reset button
  • 15,935 Answers
Can i get the service mode of samsung TV?
# Turn on the TV on and select the input that you want to adjust.
# Turn the display off.
# In quick sequence on the remote press:
{MUTE} {1} {8} {2} {POWER} buttons.
# The TV will turn On with the Service Menu displayed.
ADJUSTMENT - TEST PATTERN - SET OPTION BYTE - FACTORY RESET
# Select the function and use the {VOL+} button to enter.
# Save settings and exit by pushing {MUTE} twice then {POWER}
Feb 15, 2012 | Televison & Video
I am running RPE version 12.0 in my restaurant / bar / proshop with 3 register stations and one office station. For some reason I cannot change the quick button fuctions on the bottom of the screen. I go...
Hi dale388,
Several possibilities. You need to click on the button you wish to change. You need to check the box 'Display this button'. I think that some functions require you to log out and back in to see the change. If you have more than one schedule, to need to be editing the schedule that is currently running to see changes. Are you making the changes on the server. If not, the station you are on may not be communicating with the server properly.
B Mattern
sysadmin@ccybernet.com
Please return and give me a favorable rating if this helps or is of value to you.
Mar 16, 2011 | Pc America Restaurant Pro Express
I don't know how to increase the volume
OSD Menu Functions
English
All the function settings for the LCD monitor are controlled via the control keys located on
the bottom part of the front panel. To display the OSD main menu, press the “Menu”
keypad button on the control keys2.gif. (Note: The OSD menu display will disappear
automatically after approximately 10 seconds, if no action is taken.)
The LCD2.gif monitor has been adjusted to optimal settings before shipment. Adjustments to
the monitor settings can be made using the OSD menu.
• Press the “Menu” button to display the OSD.
• Press the ▲ or ▼ button to select the function to be adjusted.
• Press the �� button to access the function to be adjusted.
• Press the ▲ or ▼ button to select the sub-function to be adjusted.
• Press the �� or �� buttons to change the current setting of the sub-function.
• To go back to the previous menu, press the button. Changes are saved
automatically.
Source
• To exit the OSD menu press "Menu" again. It automatically will save any changes
that have been made.
If this is helpfull; please indicate so.
JZKlipper/Mike
Nov 11, 2009 | Westinghouse LCM-19v5 Monitor
I don't know how to increase/adjust the volume on my LCM-19v5 computer monitor
OSD Menu Functions
English
keypad button on the control keys. (Note: The OSD menu display will disappear
The LCD monitor has been adjusted to optimal settings before shipment. Adjustments to
automatically.
Source
JZKlipper/Mike
Nov 11, 2009 | Westinghouse Computers & Internet
Remote does not work. Can I switch to video input mode manually?
No you cannot. i recommend going to walmart buying a phillips universal remote( about 9 bucks) The silver one , it says "PHILIPS universal" at the bottom. Then program code 0722 into it . all the important fuctions will work like menu and input , pip. But the functions you loose are format and the direct video and audi seting buttons.
Oct 04, 2009 | Loewe Aconda ACO9303 30" TV
Viewing mode will only go from zoom to wide!!!! please help
Hi!
Found some relevant info on how to adjust your video settings... You might want to give it a try!
Thanks! =)
4.12 PC Input Picture Adjustment
The Picture Adjust menu operates in the same
way for the PC Input as for the DTV / TV input in
section 4.2 for Backlight, Contrast, Brightness and
Color Temperature.
4.12.1 Auto Adjust
When the MENU button is pressed, the On Screen
Display (OSD) appears on the PICTURE ADJUST
page. Press the button to highlight the Auto
Adjust selection.
Press the button for the LCD HDTV to adjust to
the PC signal timing automatically.
4.12.2 H-SIZE
Press the button to highlight the H-Size selection.
Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
the horizontal size.
4.12.3 Horizontal Shift
Press the button to highlight the Horizontal Shift selection.
Press the button to start adjusting the horizontal position of the picture. Use the or button to
adjust the horizontal position.
4.12.4 Vertical Shift
Press the button to highlight the Vertical Shift selection.
Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
the vertical position.
4.12.5 Fine Tune
Press the button to highlight the Fine Tune selection.
Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
4.14.1 Understanding Viewing Features
Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
You can switch viewing modes using the remote control.
4.14.2 Viewing Modes
Normal Mode
The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
added to the left and right of the display image. Standard TV broadcasts are
displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
to as pan-and-scan or full frame. These movies were originally filmed in 16:9
(widescreen), and then modified to fit a traditional TV screen (4:3).
Wide Mode
When watching a standard broadcast or full-frame movie in this mode,
the display image is stretched proportionately to fill the TV screen.
When watching a widescreen (1.78:1 source) program or movie, the
display image fills the TV screen. If you are watching a widescreen
(1.85:1 or 2.35:1 source) program or movie, there will still be black
bars at the top and bottom.
Zoom Mode
When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
program or movie, the display image is zoomed proportionally to fill the
width of the screen. The top and bottom are cut off to remove most of
the source material’s black bars. This mode is good for programs or
movies with sub-titles.
Panoramic Mode
When watching a standard broadcast or full frame movie in this mode,
the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
horizontally on the left and right sides to fill the TV screen. The center
of the image is not stretched.
Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
will return to widescreen.
Jan 04, 2009 | Televison & Video
Setting atomic receiving mode
There are two three-bar displays on this watch.
The three in the top left will always show only one bar (or possibly no bars).  The top left indicates the level of charge in the battery and not the atomic receive function.
The three in the bottom right are related to receiving.  The atomic receive is controlled from settings.  With the time displayed, hold down the ADJUST button for several seconds.  Once the timezone name (e.g. LAX) starts flashing at the top, release the ADJUST button and press MODE once to get to the DST control. Press MODE again to get to the Atomic receive control.  Use the receive button to switch ON->OFF->ON... Press ADJUST twice to exit settings mode.
Nov 02, 2008 | Casio Atomic-Solar MTG900 Watch
No Blue Hitachi 50v500
Yes, find a good signal on ch 3 either from a vcr or straight cable. If you change to another input you will adjust set for that input or for that format. Make sure once again that you don't change any settings except the one in question...memory init. You may have to push arrow twice to save changes but I'll check on that. If all else fails you may need light engine.
Jun 10, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Yes, the ribbon cable has gone bad on you. It's about 15$ itself and replacing it is easy.
Dec 18, 2005 | Aiwa CDC-MA01 CD Player
Pioneer DEH-P3500 CD Player Logo
135 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
