Question about Crosley CE35100AA Electric Kitchen Range
Control panel quit
Was going to reset clock and the control panel will not budge it came up with 5Ab and nothing works on it now just touched the clock button only
  • Crosley Master
  • 2,651 Answers
You have somehow gotten the machine into a sabbath mode SAB. consult your user manual to tell how to exit mode.(try holding clock button in for 3-5 secs if not please get me entire model and serial ill research for you
Posted on Mar 04, 2008
Control panel
The error code shown on the display is"Sab", not "5ab".
To disable the Sabbath mode push and hold the Clock pad for 3 seconds.
Jun 18, 2013 | Maytag 30" Built-In Single Electric Wall...
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
oven can be changed from Fahrenheit (°F) temperature to Celsius
Oct 26, 2012 | Wolf Range Ovens
Our power went out, I need to reset the clock. I can't find my book and it showing 5ab bath. I'm pushing the clock button and nothing is happening.
Hello, Thank You for using FixYa. I will be helping you today.hold the clock button for 5 to 10 seconds..
Thank You and please rate my answer if it was helpful..
Jun 20, 2011 | Ovens
We have a Kenmore electric range mod. C970-440732. We have 5b or 56 error code on each element display control and 5ab error code on temp display on the the control panel. Nothing work except the clock. ...
Sorry to read about your problem, I hope this helps you out.
I am going to assume it a F5 error code, which means your have a oven control failure. and may need replacement. electronic oven control (also called EOC or clock).
I suggest you contact a service company.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 26, 2010 | Kenmore Ovens
Readout is stuck on 5Ab. Can't do anything with it
I am publishing this tip because of the many users asking me about the code 5AB on Amana, Maytag and other ovens.
Error 5AB in fact does not exist , and what you see written on display isnot 5AB.
The beeping sound is a warning because the oven is in lock condition. The oven is not faulty, and the code is not 5AB, but SAB.
SAB means that the oven is in Sabbath mode, and the control board will be locked for 72 hours with SAB on display.
If power is disconnected a new 72 hours cycle will start.
Depending on the model, there may also be a beeping sound when you try to operate the oven.
Push and hold the Clock button for about 10 seconds, until the display clears, that will reset SAB mode.
If that does not work leave the oven connected and off for 72 hours. If the oven does not unlock after three days, then the electronic control may be stuck in SAB mode because it is faulty, in that case contact the manufacturer at the number listed on the owners manual.
Jul 09, 2009 | Maytag MEW6530D Electric Single Oven
Change time on stove held clock button and got a 5Ab & can't chng
Loof for the tech. sheet in the unit , either in the control panel [top] or the bottom under the drawer. It should tell you how to enter different modes on your range.
Apr 10, 2009 | Maytag MER5775Q Electric Kitchen Range
Stove needs to be reset?
Had the same problem...hold the clock button for about 3 or 4 seconds. That should fix it.
It is really SAB for Sabbath instead of 5Ab.
Nov 02, 2008 | Kitchen Ranges
Range does not work-message on stovetop reads 5Ab
same exact thing happened to me! Its not reading *5Ab* it's reading "Sab" as in Sab MODE...PRESS AND HOLD THE CLOCK BUTTON FOR A TOTAL OF 4 LONG SECONDS!! AND WAAAM!! Your stove is fixed and back to normal..with the Time! lol
Oct 10, 2007 | Maytag MGR5751AD Gas Kitchen Range
Unable to use oven
arkist, sounds like you are in the sabbath mode. Press and hold the clock pad for 3 to 5 seconds. See if it comes back to back.
Apr 30, 2007 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
Crosley CE35100AA Electric Kitchen Range Logo
183 people viewed this question
Top Crosley Kitchen Ranges Experts
Vitaliy Gins
Vitaliy Gins
Oloyede Monsuru
Are you a Crosley Kitchen Range Expert? Answer questions, earn points and help others
