Question about Toshiba 57H81 57" Rear Projection Television
Toshiba tv - no picture
Picture is gone, screen went red, then colored lines, we have sound, but no picture for DVD or TV, toshiba 57" wide screen HD model 57HD83, about 4 years old
    President:
  • 4,402 Answers
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Posted on Mar 14, 2008
I have a Toshiba 57H81 57 in. Rear Projection Television. The picture started having "squiggles" in it, which at first went away after the T.V. "warmed up". Now they appear to be...
Ur tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts must be replace on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Jan 22, 2011 | Toshiba 57H81 57" Rear Projection...
Picture started flashing like 3-D in the hd ed mode
ll projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 14, 2011 | Toshiba 57HX81 57" Rear Projection...
My Toshiba cinema series HD separates the red & blue color.
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 18, 2010 | Toshiba 57H82 57" Rear Projection...
54inch Hitachi TV has double figures and colors red, yellow-not normal. Set approximately seven -eight years old. Lost remote control and direction book in moving. Is the set worth getting fixed? Generally...
Convergence problems are very common on all Projection TV sets including Sony2_bing.gif,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer2_bing.gif, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
Apr 11, 2010 | Hitachi 57F500 57" Rear Projection...
The color seems to be off. No red, and lots of purple. This is a Toshiba 57H81 wide screen big box tv. It was purchased in 2002.
Could be a bad board within the tv but it is sometimes the source input meaning it could be dvd player, cable/satellite box, etc causing the loss of color but it is unlikely. I have one of these tvs and they use red green and blue projectors to reproduce the colors so when the red projector fails then you get purple which is green and blue colors combined without the red. I have found it to be sometimes a bad connection inside the tv and I found insects such as roaches inside others. Using extreme caution when opening the rear cover of any tv due to dangerous and fatal high voltage. You might find that simply cleaning out the inside of tv and reseating all the connectors might resolve your issue otherwise you would have haul this tv to a repair shop where you pay half the price of a new flat screen lcd for just repairing this tv which will probaly have another color go out next month.
Aug 15, 2009 | Toshiba 57H81 57" Rear Projection...
The tv seems really dark.57in theatrewide hd toshiba
Go into the tv menu and select the Preferences menu and set your picutre preference from Theater to Normal. The TV is currently in Theater mode, wich is for viewing with no lights on in the room. Switching it to normal lightens the pictue a lot.
May 27, 2009 | Toshiba 57H81 57" Rear Projection...
TV picture is red.
Normal color picture is composed with 3 colors R-G-B (Red-Green-Blue). Picture turns Red means: Missing Green and Blue colors (many reasons: bad contacts, projector tubes dead, and other...). Try to give some "tabs" to diagnose ... I don't know what is the type of your Projection TV, how long you owned it, to have more idea.
May 15, 2009 | Toshiba 57H81 57" Rear Projection...
Toshiba 57" HDTV no red in picture
I had the 65" version of that TV. Loved it, unfortunately it went bad as well. It sounds like the red tube went bad. The tube itself might sell for $400 plus. The installation will take several hours with the alignments which will need to be done. Then after all that you will start to have to worry about the other tubes starting to deteriorate. If there is any red in the picture then the tube is most likely the problem. At tat point I would say buy a new TV. The best bang for the buck if you want size and have the space for it would be the new Samsung or Mitsubishi DLP's. I just installed one at customers house. The 60" Mitsubishi is 1400 at Best Buy Good Luck Rob
Feb 27, 2009 | Toshiba 57H83 57" Rear Projection HDTV
I HAVE A 57 IN. TOSHIBA HD TV AND THE TV SCREEN IS A GREENISH
take the front panel off the tv, the bottom, you will see 6 little nobbs :::, use them to adjust your picture, the left 2 should be for red, the middle 2 dlue, and right green, top 3 are for focas, those are probabily the ones you want to adjust, bottom 3 are for turning the colors up and down, mess with those untill pic looks good
Jan 07, 2009 | Toshiba 57H81 57" Rear Projection...
Vertical Stripes on My Mitsubishi WS-65809 Projection TV
ADAM,
YOU NEED TO ADJUST THE SCREEN VOLTAGES TO BALANCE IT OUT. YOU CAN DO IT YOUSELF. HERE IS A WEBSITE. PLEASE READ THROUGH IT ALL. ITS FOR RED TINT OR LINES, BUT ITS USE IS FOR THE SAME PROBLEM AND COLORS. HOPFULLY, ON A LITTLE ADJUSTMENT IS ALL IT NEEDS.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
PRIDAH
Nov 22, 2007 | Sony KP-57WS500 57" Rear Projection...
Toshiba 57H81 57" Rear Projection Television Logo
204 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
