Question about Microsoft Windows 2000 for PC
DNS Event Id 7062
The server is giving the following Event Message at everty 6-10 minutes:
"The DNS server encountered a packet addressed to itself -- IP address .
The DNS server should never be sending a packet to itself. This situation usually indicates a configuration error.
Check the following areas for possible self-send configuration errors:
1) Forwarders list. (DNS servers should not forward to themselves).
2) Master lists of secondary zones.
3) Notify lists of primary zones.
4) Delegations of subzones. Must not contain NS record for this DNS server unless subzone is also on this server.
Example of self-delegation:
-> This DNS server dns1.foo.com is the primary for the zone foo.com.
-> The foo.com zone contains a delegation of bar.foo.com to dns1.foo.com,
(bar.foo.com NS dns1.foo.com)
-> BUT the bar.foo.com zone is NOT on this server.
Note, you should make this delegation check (with nslookup or DNS manager) both on this DNS server and on the server(s) you delegated the subzone to. It is possible that the delegation was done correctly, but that the primary DNS for the subzone, has any incorrect NS record pointing back at this server. If this incorrect NS record is cached at this server, then the self-send could result. If found, the subzone DNS server admin should remove the offending NS record. "
Please Let me know the solution
  • lkadmin Mar 05, 2008
    I have installed two server DC and ADC. In both the servers DNS is configured. In forward lookup zone "." and "abc.com" is appearing. The Event ID 7062 is generating the logs very frequently. What is wrong with DNS configuration.
  • Anonymous Sep 19, 2008
    yes, I created DC and removed from server. After removing that, I got this same problem in my server.
  • 86 Answers
It sounds like you have 2 DNS servers running on your network.
disable the one in windows and use the one supplied by your router
Posted on Aug 16, 2009
Hi all\r\n Newbie to servers, ive been given an computer with server 2003 loaded on it it has been through the first stage setup and now im with a few things, mainly when i run the email and internet...
DNS-servers translate names, such as 'www.fixya.com' to IP-addresses, because routing of IP-packets on the Internet is done using the IP-addresses, not by using the names of each computer.
If you have a router between your computers and your cable-modem (or DSL-modem), then the router can automatically supply the "Primary DNS Server" and "Secondary DNS Server" and "IP Address" to your server computer, if you configure the network-adapter on the server to "automatically obtain an IP Address".
As long as you leave your server running, the "dynamic" IP-address that it obtains will, in effect, become a "static" (namely "non-changing") IP-address.
Feb 03, 2011 | Microsoft Windows Small Business Server...
Tip
Server 2003 & client configuration
<p><span>Some days before I have done a job on Windows Server 2003 Enterprise edition & Client XP. It is departmental food court. In the office room of the restaurant have a system which will be Server system and main domain. There was another 8 system in every department of food <span> </span>with printer for billing.I</SPAN><br> <p><span>Windows Server 2003 includes a mission critical Windows Server operating system, such as security, reliability, availability, and scalability.</SPAN><br> <p><span>You have to install DNS server for DC without DNS the client computers wouldn't know which one is DC.You can host DNS on a different server than DC.</SPAN><br> <p><span>Before Starting the DC installation process you need to make sure the <span> </SPAN>following points</SPAN><br> <p><span> </SPAN><br> <p><span>1)You have installed Basic windows server 2003 installation</SPAN><br> <p><span>2)Make sure you have assigned a static ip address to your server</SPAN><br> <p><span><span> </SPAN>Now start DC and DNS Setup process</SPAN><span></SPAN><br> <a><span> </SPAN></A> <span><span>Domain Controller</SPAN></SPAN><span></SPAN> <span>Active Directory is a huge topic in itself. While DCPROMO is easy to run, planning of both the physical and the logical structure is the key to a trouble free active directory. </SPAN> <p><span>Domain controllers do not have to be your most powerful machines, however they must be reliable and always available to answer logon requests. </SPAN><br> <a><span>DNS (Domain Name System)</SPAN></A><span><span> </SPAN></SPAN><span>Role</SPAN> <p><span>Once DNS is setup, it runs itself thanks to the new dynamic component hence DDNS. TCP/IP knowledge plus understanding of how DNS works is essential when troubleshooting connectivity problems.</SPAN><br> <p><span>DNS enables client machines to resolve servers IP addresses. Once the client finds the server, Active Directory uses LDAP to locate services like Kerberos, Global Catalog that clients request.</SPAN><br> <a><span>Print Server Role</SPAN></A><span></SPAN> <p><span>In my experience there is a contrast between the software settings which are easy to configure and the hardware which constantly need for attention e.g. paper jam, 'out of toner'. Check list for print server:</SPAN><br> <p><span></SPAN> <br> <p><span>Printer Priority</SPAN><br> <p><span>Network Printers</SPAN><br> <p><span></SPAN><br> <p><b><span>Client Configuration :- </SPAN></B><span>After</SPAN><span><span> Installation of Windows Xp give the IP Add on TCP/IP of IPV4.If you want to manually configure DNS server addresses, click</SPAN></SPAN><span><span> </SPAN></SPAN><b><span>Use the following DNS server addresses</SPAN></b><span><b><span>,</SPAN></B></SPAN><span><span> and then type the preferred DNS server and alternate DNS server IP addresses in the</SPAN></SPAN><span><span> </SPAN></SPAN><b><span>Preferred DNS server</SPAN></b><span><span> </SPAN></SPAN><span><span>and</SPAN></SPAN><span><span> </SPAN></SPAN><b><span>Alternate DNS server</SPAN></b><span><span> </SPAN></SPAN><span><span>boxes. After all job try to ping each other. I'm trying this and it also pinging. Files and data also can be shared through it.</SPAN></SPAN>
on Feb 15, 2011 | Computers & Internet
Newbie to servers, ive been given an computer with server 2003 loaded on it it has been through the first stage setup and now im with a few things, mainly when i run the email and internet connection...
Feb 03, 2011 | Computers & Internet
How do I configure my laptops IP address to my router to get online? I'm using windows vista. I tried a few times and I can't find the window to type in the laptops IP address. How?
Follow the following steps to change your TCP and IP Settings on Windows Vista
1. Go to the Control Panel from the Start menu.
2. Click "Network and Internet" and then "Network and Sharing Center."
3. Click "Manage network connections."
4. Choose which Internet connection you would like to change if you have more than one. Right click on it and select "Properties."
5. Click the "Networking" tab.
6. Choose Internet Protocol Version 4 (TCP/IPv4)
(Note that "Obtain an IP Address Automatically" works fine generally)
7. Click "Use the following IP Address" to enter your own IP settings.
- Enter IP address (eg. 192.168.1.125) into the box marked "IP Address, press tab "Subnet Mask" would appear automatically (255.255.255.0) and in "Default gateway." type 192.168.0.1.
To specify DNS server address settings, do one of the following:
- To obtain a DNS server address automatically, click Obtain DNS server address automatically, and then click OK.
- To specify a DNS server address, click Use the following DNS server addresses, and then, in the Preferred DNS server and Alternate DNS server boxes, type the addresses of the primary and secondary DNS servers.(which can be obtained from your internet service provider (ISP).
For visual help, check out step by step guide here
Hopr it Helps!
CreativeTECH
Nov 25, 2010 | Linksys Wireless-G Broadband Router
When i try to put internet acces it works but at the same time it says "communication with server failed A dns error has occured (80410418)" and i dont know how to fix it
This simply means that an Address attached to the name asked for,, that was requested from a DNS Domain Name Server, didn't connect, or work properly,or be acknowledged. So the device indicates that as an Error Message.for Information. As In reality, unless it is the ONLY DNS, and you weren't able to connect to the Internet then it would be of concern, as it is now, it is merely telling you that this event has happened. It may be as simple as an incorrect DNS setting in a router, or a used to be valid "Address" that doesn't exist, or cannot be reached, for whatever reason anymore.
May 16, 2010 | Video Game Consoles & Games
DNS Server is not responding
On your computer, Click on Start and then RUN and type CMD... on the black screen/DOS prompt type there FlushDNS and press enter, this will clear out the DNS and should work
Mar 28, 2010 | D-Link DIR-300 Wireless Router
Dns error
DNS = Domain Name Server
This is a set of specialized servers on the Internet, needed to
translate user friendly internet address such as:
www.microsoft.com
into their binary IP address equivalents, such as:
www.microsoft.com =
207.46.192.254 = (IP address)
$CF 2E C0 FE = (hexadecimal)
1100 1111 0010 1110 1100 0000 1111 1110 (binary)
In order to communicate with Microsoft, your computer
first sends a request to the closest DNS server to resolve
the domain name into a binary address. Once it gets the
binary address of Microsoft, in then prefixes every packet
with a 32-bit destination address, followed by it own 32-bit
return address.
Other specialized computers on the Internet, called routers,
than manage the actual data transfers on a skip by skip basis.
A DNS error means that your computer is either unable to reach
the pre-determined DNS server, or the server is unable to resolve
the particular address due to a non-existent WEB site or a
spelling mistake.
The actual meaning of the message depends on which layer
of the internet protocol in your computer, (or outside of it)
generated it.
Martin.
May 08, 2008 | Computers & Internet
Wrong ip address
Are you trying to get an IP for your computer, or for your modem? Assuming your using a high-speed connection, possibly a router?
Mar 28, 2008 | Computers & Internet
Samsung SGH-D600
First providing the entire text of the message in a comment here would provide useful information to resolve the error.
Second a short discussion of DNS. DNS from your perspectiveis generally several servers assigned by your ISP to provide the data to convert names such as www.FixYa.com to numeric IP addresses to send messages. Generally in a home network these DNS addresses get configured into the adapter automatically from the router using DHCP or manually by the user.
If your web browser can access sites by name such as www.fixya.com despite the DNS message you indicated then your DNS servers are probably properly configured and there is another DNS issue.
If you wish to check further
click on start than all programs then accessories then command prompt
in the window that opens enter the following command
ipconfig /all
There may be multiple adapters shown but one should have all of the following as non 0.0.0.0 addresses
IP address, Subnet Mask, Default Gateway and one or more DNS addresses. The DNS addresses present should normally match those provided by your ISP.
IF you have any questions, can supply the full error message or believe any of the above is an issue please add a comment to this problem and I will provide any additional input I can based on your observations.
Dec 16, 2007 | Samsung Dell Latitude D600 14.1 LCD SXGA+...
Microsoft Windows 2000 for PC Logo
1,040 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
