Question about Sony KP-46WT510 46" Rear Projection HDTV
Sony brick I have changed my ic's and a 5-amp fuse on the "G" board.I turned the set on and the bow-tie effect is gone, but when I go into manual convergence I can only move the red up and down and not back and forth. Somebody said my convergence output resistors were blown. I'm not sure what those are,if somebody could help me out,part # or what board they might be on that would help out alot. Thanks.
  • Sony Master
  • 8,617 Answers
The resistors in question are located right next to the convergence ICs. Just lift one end of the resistors out of circuit and check them for being open. The resistors will be all the same type , check all of them usually 1 or 2 of them will be open when the IC goes out.
Posted on Apr 06, 2008
Colors won't converge. Picture bows. Replaced ic units. Nothing change. Found one little resistor or fuse(?) that has no continuity either direction. Has a loop symbol on circuit board location. Any ideas?
TWO THINGS: first the set uses two five amp so called pico fuses in the power supply board, they are usually orange and look like a resistor, they need to be check for good or open, when one of the chips fails it is not unusual for it to take one of these out.
There are several more near the chips but they very rarely fail, All will have amperage marked like 5a etc.
Check the two fuses on the power supply board, one may be gone.
Let me know what happens or if you have more questions.
SD TECH
Jan 10, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
I have a sony kp-65w600 i have changed boyh ics and cheked all resisors and fuses still have bow and i am not getting voltage to the ics
There are 2 protection fuses on the +/- 19v supply line. On the G board, check PS6503, PS6504. These are 5 amp IC fuse links, PN: 1-533-597-31. I hope this helps, best wishes.
Apr 23, 2010 | Televison & Video
3d picture and looks like bow tie
Bad STK ICs replace both ICs will have part number on them STK392-110s if this is what you have upgrade to 150s! ICs are Big black ICs also ck 2.7 ohm resistors near ics.
Sep 16, 2009 | Samsung HCM4215W 42" Rear Projection...
Focus issue after replacing convergence IC's
pull the fron grill off the set then remove the cardboard covering the hole that is in the front of the set you will find a square box that has 6 controls on it adjust the focus for the red, blue and green crts, do not adjust the three marked screen control.
Sep 10, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
I have a 53 in. sony projection tv,. bowed picture tubes?!?
Replace Both STK convergence ICs will have part number on them STK392-560 use same part number on your STKs. Also around ICs ck pico fuses 5/6amps they are green or yellow.
Jan 07, 2009 | RCA P56930BL 56" Rear Projection...
RCA model P61950
fl231 is the convergence fuse, and is soldered to the board in proximity of the convergence ICS, on RCA rear projection TVs.
If
fl231 has blown, TV usually does not turn on at al, if you get bowed picture, that means that the convergence ICs must be replaced.
The fuse is on the same board where you find convergence ICs, if the fuse had blown, or the pico fuses at the base of the STK convergence ics had blown, the STKs must be replaced.
There is need of purchasing the service manual to do the job.
The repair shuld be done by a technician.
This is the convergence IC, model may vary:
Dec 13, 2008 | Televison & Video
Sony projection big screen
does the led flash when you try to power it up? If so let me know the number of flashes. From your description I would suggest 1 of 2 things happened. (1) The Convergence amp ICs have shorted and blown the 5 amp fuse on the G board, or (2) the red CRT has shorted shutting the set down. Check the fuse and if blown replace the fuse and disconnect the Red CRT PC board from the RED CRT and try powering up the set. If it powers up without shutting down then unplug the set and rehook the RED crt pc board and try again if it shuts down the reds shorted. But if it still wont start with the CRT unhooked or blows the fuse Change the Convergence ICs
Apr 06, 2008 | Sony KP-57XBR10 57" Rear Projection...
Red won't move...
ok this is an indication that the convergence output resistors might been blown.
Feb 28, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP-46WT510 46" Rear Projection HDTV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
