My fridgidaire ultra quiet 3 dishwasher leaks and I don't know how to fix it. I have taken it apart to the point where the next step would be to disconnect the entire unit from the electricity and plumbing and bring it out entirley.
My neighbor complaine about the water dripping into her kitchen and I looked under my dishwasher as it was running and it had leaked about a cup to a cup and a half of water for a "light cycle".
-   YEP, MINE IS LEAKING TOO. In my case the leak is comming from the water inlet solenoid valve. Slow leak that just drips. Guess I'll need to call a technician to replace it. Very frustrating. Looks like it was very cheaply designed as the valve is opened and closed by a small magnet. It is housed is a cheap plastic sleave that doesnt seem to have a adequate seal. Not sure how it lasted this long (4 years 8 months).-   cec_inc
Rank: Guru
Frigidaire Expert
Rating: 89%, 2127 votes
a common place to leak on these machines is through the heater leads. run the machine w/lower panel off and see where its coming from , if its dripping down the heater leads, chances are the 2 nuts that secure them are broken and need replacing
Load the dishwasher, set to clean come back in a couple of hours and nothing is changed. Water just...
(More)
Load the dishwasher, set to clean come back in a couple of hours and nothing is changed. Water just keeps running... HELP!!!!!
My frigidaire 1000 series dishwasher clean light does not turn off after the cyle is complete. The...
(More)
My frigidaire 1000 series dishwasher clean light does not turn off after the cyle is complete. The only way to get it to turn off is to switch the breaker.
Frigidaire FDB1050REB2 dishwasher. Blinking wash indicator light when trying to start the wash...
(More)
Frigidaire FDB1050REB2 dishwasher. Blinking wash indicator light when trying to start the wash cycle. Start/Cancel clears the light, but the same happens if I press the Start/Cancel button again. If the 12-pin connector to the control board is unplugged and plugged back in the washer will start if the Start/Cancel button is press. After one wash cycle the problem returns. Wiring connections appear to be sound.
