Garden Logo
Posted on Mar 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What direction does the fuel flow into a weedeater primer bulb?
Im not sure if the primer is supposed to **** fuel out of top of carb. or from the fuel tank into carb.?
Curtis Sewell
Level 3:
  • Garden Master 7,482 Answers
  • Posted on Mar 04, 2010
Curtis Sewell
Garden Master
Level 3:
Answers
7482
Questions
Helped
1941378
Points
24946
The fuel will flow from the fuel tank to the carb, after going thru the primer bulb, it will fill the carb with fuel and then be shut off after the float in the carb shuts off the fuel flow from the primer bulb.
Hope this helps,
Good Luck,
Please rate me....
Thanks
1helpful
When i press the primer bulb in it want pop back out why?
The thing to understand is that this is not a primer, it is a purge and there is a big difference, a primer pushes fuel into the carb, a purge pulls fuel from the carb and dumps back to the tank, so when the bulb is pressed in, fuel in the bulb is pushed back to the tank, when the bulb comes our fuel is sucked from the carb, if the bulb stays in either the filter in the tank is blocked, or the fuel hose is trapped, or the filter in the carb is blocked, or somebody has fitted the pipes on the carb round the wrong way.
2answers
I replaced my primer bulb on my craftsman weedeater an am not sure what line goes where on the primer bulb can you help also not the gas leaks out of carb hole where
In regards to which pipe goes where, it's simple. If you pump your primer bulb with the pipes off, one side will suck and the other side will blow. The suction side will link to the outlet on the carb. The blow side will link to the return to tank. The fuel line with the filter on it will link to the inlet pipe on the carb.
1helpful
I have a craftsman 358.797931 w/ a walbro carb with primer bulb on top.what line takes the fuel filter and which line goes where on carb. Top and lower tubes
The hose with the fuel filter will go to the bottom of the carb, the top hose off the carb will go to the inlet of the primer and the primer outlet will return to the tank
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Feb 04, 2013 • Garden
14helpful
3answers
Diagram fuel lines tank primer carbutor poulan pro weedeater
I have no diagram but here are the instructions on how it goes.
The small diameter line out of fuel tank (has filter in-tank on end) connects directly to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then "pushes" any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. This is the return line. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb. If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where sometimes the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank. Otherwise, the line should enter the tank for about 1/2" or so.
2helpful
Gas lines crumbled and don't know how to route new lines correctly
1helpful
My weedeater lawn edger wont start. I get no gas in the primer bulb, but has fuel in both the main line and the return line. I blew out the fuel fliter and both lines but still no fuel in the primer...
There may be a malfunction in the check valves in the primer base assembly. Before attempting to get a new assembly, take the retaining screws at the bulb off, remove the bulb and spray the assembly liberally with WD-40 or an equivalent light lubricant. Sometimes this will free the check valves as they only let fuel flow one way and there are 2 of them in the primer base.
Do not use strong solvents, do not ever soak, and never use high PSI compressed air on these carbs. Sometimes, when the check valves in the primer base go bad, the carb floods and the reason is unclear. Zama doesn't list this as a reason for their carbs flooding, but they can. You may wish to view a parts breakdown list for your specific carb. You will need to know the type (stamped in side of carb body) and the model (stenciled in side of carb body). It will be something like a C1U type and a W-18A mode...thus its a C1U-W18A Zama carb. Here is a link to get you started.
http://www.zamacarb.com/pdfs/APPL_CR2010.pdf
Yours will be listed under Poulan/Weedeater
Aug 22, 2010 • Garden
2helpful
I need a fuel line schematic for a WeedEater brand Featherlite Plus weedeater
Presuming the primer bulb is on top of the carb....Fuel filter line out of gas tank goes to the lower part if carburetor body. The other line (normally larger in size) coming out of the fuel tank goes to the primer bulb outlet on the top of carb.
If the primer/purge bulb is not on the carb, things are a little different. The fuel filter line out of the tank still goes directly to the carb, as the bulb will pull old fuel/air out of the carb allowing fresh fuel to flow in and pushes old fuel/air back to the fuel tank.
Fresh fuel in, old fuel out of the carb...you can hook up a piece of fuel line to the bulb and tell which one is pulling and which one is pushing..or depress it with your fingers on it...either way you can tell.
Jul 04, 2010 • Garden
5helpful
Routing of fuel lines for a weedeater bv200 type 2. Which lines go where from the carb into the tank?
The line with the filter goes to the bottom of the carb. The other line goes to the outlet side of the primer bulb and the other line from the primer bulb goes to the top of the carb (The primer sucks gas through the carb).
Ps. if you are not sure which nipple of the primer is the outlet port then put your finger on one of the ports and push the bulb. If the bulb stays ridged then that's the outlet and if it collapses but doesn't fill but up then that's the inlet side.
Jul 10, 2009 • Garden
12helpful
3answers
Craftsman leaf blower, primer bulb will not return, won't start
primer bulb on weedeater will not return to normal or **** gas into it. new primer bulb. lines to tank have been repalce and can blow through them but primer bulb will not push air into tank
Top Garden Experts
Jay Finke
Jay Finke
john h
