Question about Soyo Crystal DYLT032B 32 in. LCD Television
Audio distortion Sound is distorted by explosive changes in loudness. No problem when audio is sent through independent audio system (electronics + speakers).
  • 2,336 Answers
If the audio goes up and down by itself, I would say that the audio amplifier IC is defective.
The reason that the audio works fine when you use your audio system is because you are not getting the audio through the amplifier IC but you get the audio from the audio outputs.
If you are handy with electronics and hand soldering, this is something you might be able to do. If not I would suggest to take the TV to a repair person, if your TV is less than one year old, the set still under manufacturers warranty.
Let me know if you need further assistance.
Posted on Mar 04, 2008
    President:
  • 1,944 Answers
What do you mean by explosive change in loudness? The volume goes up and down by itself?
When I plug in my marantz TT-42 turntable to my Yamaha R-S300 receiver's phono input, I get a muddy and loud sound. I've tested the turntable with direct input to Bose speakers and it works fine.
If the turntable produces good sound with a line level input on another system, you have the turntable with the pre amp built in. That is why the sound is loud and distorted.
Mar 05, 2017 | Yamaha Audio Players & Recorders
Tip
How Loud Can it Go?
I don't know if I ever installed a sound system to any concert fan who didn't ask me this question. So how loud can I safely play my sound system?
If you have a receiver or amplifier that has an analog dial that goes from 7 o'clock to 5 o'clock the majority of units will output maximum volume at around 1 o'clock assuming a line level signal is sent to it (again it varies a lot from piece to piece). Anything higher then that and the unit will send out a distorted signal colloquially referred to as "clipping". Most modern units now use digital volume controls and everyone is different. The only way to detect this distortion is listen to when the music sounds tinny and harsh instead of clean and musical.
If you do not find it is loud enough for your liking you must invest in a more powerful amplifier or higher efficiency speakers; or you will continue to destroy your innocent speakers and blame them for your over driven amplifier.
on Jan 27, 2010 | Audio Players & Recorders
My jvc UX-D66 B micro system sound is very distorted and crackles when listening to music I checked the wires and they are fine it is the same through aux what could be the problem any advice please
You may have blown the speakers by playing too loud. Try listening with a pair of quality headphones. If the sound is clear through them - then the speakers are most likely the problem.
May 13, 2015 | JVC Audio Players & Recorders
Marshall MB4410, with low volume gives no real volume,
Guitar amps have preamp sections (think unpowered audio mixer) and power amp sections (Crown rack-mount amp). An excellent way to isolate audio problems if amp is still producing audio is to check the preamp out (line out). Preamp output distorted = preamp failure. Connect MP3 player to "Power Amp In"...sound distorted = power amp failure. In your case the latter is the case as your "line out" is clean. Also test each speaker for clear sound as speaker cone damage from being overpowered is fairly common. At 300w. I'll assume the failure was not from cranking the volume to loud but a shorted speaker or speaker wiring could zap the power amp in an instant.
Jan 06, 2014 | Marshall MB4410 Bass Combo Amplifier
Distorted sound
Never used them, but distorted outputs indicates you are over-driving them, connected them to 'speaker out' rather than 'headphone out', Or you have already blown the drivers. Connect to a different sound source and see how they work then. You likely will not get a loud boom from any headset.
Dec 28, 2013 | Sennheiser Audio Players & Recorders
My left speaker is loose
The symptom you are describing is exactly what is known as a "BLOWN" speaker or the voice coil has "shorted", this is caused from the volume being up to loud, heating up the voice coil and frying it, in the future if the bass/sound is distorted then turn the volume down just enough to stop the distortion and this will save the speaker.
As far as getting a replacement speaker, you will have to contact the manufacture to get a replacement.
Good Luck !
Apr 21, 2010 | Philips FWC577 CD Shelf System
Sound Distortion
somekind of hardware side failure or bad drivers.
I hear sounds from my audio output if i connect my headphones there directly but when I connect it to my speaker system they filter the distortion.
Apr 13, 2008 | ASUS M2N-E SLi Motherboard
Hd tv but no hdmi plugin,standard red,white yellow plug...when there is a loud noise (explosion,dino roaring etc)I get a loud crackling noise from speakers that actually drowns out the sound fx on a ps3...
Sounds like more of a tv speaker problem then your ps3. You can change the audio settings on the XMB dashboard of your ps3. I think they are default at max.
Mar 13, 2008 | Sony Playstation 3 (PS3) Console
YAMAHA HTR 5660 MAKES POPING SOUND WITH LOUD NOISE AND BRIGHT LIGHT
Looks like you've got the best connection available - initially I thought it might have something to do with decoding the prologic signal from the analog input, but obviously not! And since you've got the audio separate from the video it is unlikely there is any interference from the video signal in the cable. Have you tried a different DVD player (I reckon that is most likely)? Also try connecting the video signal DIRECTLY from DVD to the TV if you aren't already doing so (you are anyway aren't you - the HTR 5660 doesn't have HDMI out does it?) Finally, if you have some spare cables around, try changing them - see if you get the same response when using component video cable instead of HDMI.
Jan 26, 2008 | Yamaha HTR-5660 Receiver
Soyo Crystal DYLT032B 32 in. LCD Television Logo
147 people viewed this question
Top Soyo Televison & Video Experts
ted dux
Are you a Soyo Televison and Video Expert? Answer questions, earn points and help others
