Back to:
Tags:
IBM 4232 Matrix Printer
IBM 4234 dot matrix
posted by Actionguy on Mar 04, 2008
I have a customer site that has the problem that the print gradually moves up the page by about 1/4 line per print job. I checked it out myself and the symptoms are these:
The spacing does not change within a job and so you can print 40-50 pages and see no change.
The spacing does change with each new job and the print moves up the page slightly. After about 10 jobs the print has moved up 2-3 lines. This also occurs when doing test prints from the front panel.
The configuration seems to be proper for the forms they are using. (Green band wide paper)
I have no manual for this printer. (I do have it for the 4230/4232 but these seem to be different enough that the instructions are not the same.)
Any suggestions?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jun 13, 2008
Thanks for Trying (70)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Sounds like the configured paper sized does not match the actual paper page height. So that when it does Top Of Form paper movement the paper stops slightly too low. Doing several form feeds should confirm this. If this is it then reconfigure the paper size to match the paper. Also measure to paper to see if it matches what you want it to be.
Rating Locked! (?) Actionguy has rated this solution as Thanks for Trying
Thank You!
Was the solution helpful?
Show your appreciation by commenting on IBM 4234 dot matrix:
I don't want to Accept this solution
Can you Help with these Printers problems?
Printers
deleated hp software for printer and no cd to reload the...
Printers
trying to set up my all in one ink jet printer lexmark...
Printers
How do I print the error code page from MPC4500
Does this require a firmware upgrade?
Our trusty 4232 has recently started to give a forms jam...
Loading problems.
Repair Service
Find Printer Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
