Ballast problem - Televison & Video
How do i replace ballast on sanyo dlp
Posted on Sep 24, 2009
I just replaced the lamp for the tv. and the lamp indicator is still blinking, I'm guesstamating that the ballast is bad & it probaly is I can't find one for my Tv.
Posted on Apr 16, 2009
How to release the wires from all the tomb stone connectors on a 4 bulb T5 fixture in order to change the ballast?
If you are sure the ballast is gone, just cut the wire as close as possible to the ballast, throw the old ballast and buy a same wiring ballast, use wiring nuts to connect the wire from the new ballast to the wire from the tomb stone socket. DO NOT TRY TO take the wire out from tomb stone lampholder.
Below link is for your reference.
http://www.bulbspro.com/electrical/sockets/fluorescent-sockets.html
http://www.bulbspro.com/ballasts/ballasts/fluorescent-ballasts.html
Aug 28, 2013 | Computers & Internet
BALLAST FOR PRO 24
A trained technician should: Turn off power to bed. Remove top or bottom cover as necessary, Locate bad ballast, Insert small insulated screwdriver into slot on end of ballast and pull out wire, Remove one screw that holds ballast in place and loosen the other screw, The end of the Ballast should be slotted - so pull it out from loosened screw. Now reverse the process to install new ballast. After remounting ballast to bed, simply push the wires back into small holes in connector.
Feb 02, 2013 | Wolff Sunquest Pro 24RS 220 Volts
Changing 7 wire ballast to 6 wire ballast
its got to be the wrong one--wrong ballast.
Nov 29, 2012 | Televison & Video
I am replacing one of the two ancient ballasts in a four tube fixture that has four F96T12 75W tubes. How do I connect the two blue wires in the new ballast? The old fixture has only one blue wire per...
I don't believe you have the correct ballast for your light. Your old ballast was the old iron ballasts they used to use. They still are available but you have to search around to find them.
Be sure to match the tube wattage, length and diameter as closely as possible.
Here is a website that has a good explanation of ballasts, the old iron ballasts and the newer rapid start ballasts: http://www.repairfaq.org/sam/flamp.htm#fb
Section II. deals with ballasts.
I hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie andie
Apr 15, 2011 | Garden
''UV'' light not working!!
I`ve always used one ballast to one light.i.e if your bulb is a 400 you need a 400 ballast only and feeding no more off it. Try this
Sep 29, 2009 | Sunmaster Conversion Lamp HPS Ballast
Replacing ballast
To confirm if the ballast is bad check the ballast board to see if the spark gap (on the ballast board) lights when you first turn the set on. If it does than the ballast is ok.
Sep 20, 2009 | Televison & Video
Ballast location?
the ballast is right in the middle. you should see an electrical cord. open the 2 screws from the ballast cover. then unscrew the top and bottom screw from the ballast. the ballast should come off. cut the wires closer to the ballast, so that you can identify the wire with the new ballast, which will have the same color scheme.
Jun 17, 2008 | True GDM-41 Refrigerator
Ballast replacement
Your set uses the Phillips UPH100W 1.3 100http://servicemanuals.vstore.ca/ 1amp bulb part number 6912V00006A which uses Ballast EUC 6913V0002A and the actual ballast isMB03CA part number 6871VSMB13F I would contact LG and give them these numbers. Is your ballast bad or is the BallastEUC bad? Let me know if I can help you further.
May 12, 2008 | LG RU-60SZ30 60" Rear Projection...
Televison & Video Logo
715 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
