Question about Hotpoint WMA76 Front Load Washer
Program starts, then after a couple of minutes it stops and display says 'On'
Have tried turning power on/off, and have restarted 3 times but it never gets past about 2 minutes before stopping altogether. The display then just says 'On'. It will let me open door, although clothes wet it is not full of water. Machine is 3.5 yrs old.
Thanks
  • symmo Mar 07, 2008
    Thanks for reply - forgot to look back on here as in the end my boyfriend took the top off the machine, then reconnected the circuit board etc and all is fine again. We think that in the years we have had it the vibrating had made something come loose behind the digital display. So, all in all if you have this problem, save yourself lots of money for call out/repair by getting someone handy with a screwdriver to do the above! Thanks
  • stan1664 May 09, 2009
    symmo's "Program starts, then after a couple of minutes it stops and display says 'On'" and emptys the water
  • 108 Answers
Does your machine rotate the drum?
Posted on Mar 06, 2008
I have a Stepmill 7000 pt. I have a terrible time trying to start a workout program like quick start, manual, fat burner, etc. I have to push the program button multiple times to start the program.
It sounds like you may have a faulty keypad. The following link will take you to this item. Stairmaster Stepper 7000PT Stepmill Parts Transmission SPORTSMITH net You might also be looking at a faulty ground or insufficient power coming from your power supply. Check this out put with a multimeter. You should be getting between 12-19 volts DC.
Dec 05, 2017 | Stairmaster Stepmill 7000 Pt
Bosch wft 2830
Its hard to say what your problem is without more information.
If you had a lot of vibration and water from a broken hose, you may have shorted one of the sensing units or main board.
Try to clear the program by disconnecting power and holding down the start key for a few seconds. Similar to Clearing the CMOS on a desktop computer.
Hope this helps
Mar 22, 2014 | Washing Machines
Software is unable to start and a fault is displayed immediately after start of software.
try to turn it off. get the network cable out the machine. wait 1 minute. press 6-stop-powersave (all 3 at the same time, powersave top right corner) With these buttons pressed, start the machine and keep the buttons down until machine is fully started.
Nov 14, 2013 | Xerox Workcentre 7335 All-in-one Laser...
'04 L300-3 Stalls randomly and won't start until I wait about 5 min. Then starts normal
try replacing fuel filter , and next time you go to start it turn key on let it sit for count to 50 then start see what happens
Dec 14, 2012 | 2003 Saturn L-Series
Electrolux EDC77550 drum dryer starts normally but stop after running couple of minutes.
If motor runs continuously with power applied, check for short circuit across motor relay (RL2), or L1 applied to motor relay output (J3-1) with cycle stopped. If motor does not start when Start key is pressed, check for open circuit between L1 and motor relay connection (J3-2). If no wiring problems found, replace Main Control Board.
Aug 14, 2012 | Electrolux Dryers
How to set time on timex 1440 sports watch
Welcome to FixYa!
Here's your request.
TIME AND DATE 1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash. 2. Press ADJUST to set SECONDS to zero. 3. Press START/STOP to select MINUTES. 4. Press ADJUST to change. 5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM. 6. Press MODE when done. 7. To display DATE from Time display , press START/STOP. 8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE. 9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME 1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash. 2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM. 3. Press START/STOP to select MINUTES. 4. Press ADJUST to change.. Press MODE when done. 5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH 1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes. 2. With time displayed, press MODE to select Chrono Mode. 3. Press START/STOP to start. 4. Press ADJUST to view lap time. Press again to sesume lap timing. 5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero. 6. Repeat for successive laps.
Thank you for using FixYa! Have a great day.
Jas247
May 06, 2011 | Timex Watches
1985.5 PORSCHE 944 digital clock (changing time)
There are three buttons, let's call them 1, 2, and 3, from left to right.
Clock
Time setting
A. 12 AM, PM or 24.00 h
With the clock in the time readout mode, keep
button (2) depressed for 4 seconds -12 AM, PM
or 24.00 flashing. After pushing button (1), either
a 12-hour (AM + PM) or a 24-hour setting
program can be selected. If you only want to
change the display mode, push button (3). The
clock then returns to its normal timekeeping
function.
B. Hours
Push button (2) a second time - hour display
flashes. Set hour by pushing button (1). After
pushing button (3)*, the clock returns to the time
readout mode with new hour setting.
C. Minutes
Push button (2) once more - minute display
flashes. Set minute by pushing button (1). Upon
pushing button (3)*, the clock is started -
accurate to within 1 second.
Stop watch function
The stop watch can only be set in motion if the
clock is in its normal timekeeping mode and not
during setting operations.
A. Push button (3) - 00:00 display appears;
B. Push button (1) - stop watch is on;
C. Push button (1) a second time - watch stops.
(Additional times can be added by pushing button
(1) again - stop watch keeps running. Push button
(1) once more to stop timing.)
D. Push button (2) - 00:00 display appears;
E. Push button (3) - normal timekeeping mode.
If button (3) is pushed during operation A and
B, the setting procedure must be restarted
Apr 17, 2009 | 1985 Porsche 944
Stops running
LED Blink Patterns on the Control Board Treadmill Treadmill Maintenance How To Lubricate Treadmill Belt
Try to do this steps in order to fix it.
However if the problem persist.
Time to replace the Controller board Motor.
This board has 3 power supply control:1) Console Board 2) Elevation Motor 3) Main Motor.
One of IGTBs is faulty.
Blessing.
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
Oct 01, 2017 | Proform iLog 750 Treadmill
NNS449WF MICROWAVE OVEN PANASONIC
Usually you press Start 3 times to turn the child lock on, and press Stop/Reset 3 times to turn it off.
If that doesn't work, you can probably unplug it for a couple of minutes, then reset the clock.
Oct 04, 2008 | Panasonic Microwave Ovens
Hotpoint WMA76 Front Load Washer Logo
120 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
