Question about AMD Asus K8N-E-DELUXE nForce3 Mainboard (MBASK8NEDLX) Motherboard
CPU Fan connector
The connector on the motherboard has failed and I am using an altrnative connector. The motherboard keeps telling me that the connector has failed and that i should pree F1 to continue.
Is there a solution?
    Scholar:
  • 64 Answers
Hi vinbren,
There is probably an option in your system setup (BIOS) that will disable the CMOS from detecting a dead fan. While you may be putting yourself in harm's way should the fan actually die and the shutoff mechanism is thereby disabled, it sounds like since you're using an auxiliary connector this wouldn't apply to you anyway.
Check the BIOS setup (generally accessed by pressing F1, F2, F10, del, or ESC when the system first POSTs) for hardware monitoring and see if you can turn it off.
Ben
Posted on Mar 04, 2008
Ms-7108v1
1 long beep dram refresh failed
remove everything
JUST INSTALL MIN. RAM, CPU, CPU FAN, POWER CONNECTION, THAN TURN MACHINE ON, IF OK, CONTINUE INSTALLING I DEVICE AT A TIME UNIT YOU IN COUNTER AN ERROR THAN YOU WILL KNOW WHAT IS WRONG.
now a few things to check video card, ram, cpu fan plugged in right area,
you mite want to reset the cmos, by jumping the connectors for few seconds, then turn machine off, remove jumper, than just install cpu and fan, ram, speaker, keyboard, turn on if ok add video card, turn on , if ok, than install hhd, 1 at a time, than restart system if boots ok than move to next device, keep doing this until you installed everything you want or have to have in the system
Jun 07, 2014 | MSI 848p-neo2-v-848p Neo2-v Intel 848p...
CPU fan not working computer shuts down. Replaced fan and it still does this? Hp Pavilion 9597c
Its possible that the Motherboard connector for the fan is not putting out power. there are CPU fans that use a standard 4pin Molex connector, that is what I would suggest you use.
Mar 18, 2011 | HP Pavilion (F2111-60950) CPU Heatsink &...
ASUS Motherboard M2N68-LA (False) "cpu fan has failed" If I press the F2 on the keyboard, bypass this failure and computer keep running well.
U'L LDAMAGE YOUR MOTHERBOARD AND THE CPU TURN IT OFF AND UNPLUG ALL CABLES OPEN THE CAS COVER AND CHECK THE CPU FA N IS MOVING OR NOT IF NOT THEN CLEAN THE FAN AND CHECK THE FAN CABLE IF IT STILL NOT MOVING CHANGE THE HEATSINK INCLUDIN THE FAN DA VN
Jun 13, 2010 | Intel D915GAG Socket 775 Motherboard -...
Error message shuts computer at start up...CPU fan failed. HP Pavilion M8400 F Phenom X49500 2.2 GHz (computer is new to me)
the trick is that there is more than one spot where you can plug in the CPU fan, had the same issue with an HP myself. try a different spot to plug in the CPU cooler. mine was in the upper right hand of the board and was labeled CFAN. the one i thought was for the CPU (it was same color as the fan connector) was actually a case fan connection.
Mar 29, 2010 | ASUS M3A78-CM AMD 780V AM2+ Phenom FX /...
My computer won't start. Power supply (ttgi 450ss) has a blinking green light and the power supply fan starts when plugged in. Motherboard (asus m2npv-vm) has a green light illuminated between the pci...
See if you plugged in the 4 pin power connector on the motherboard besides the main power connection on the power supply (usually black colored and its a plastic 4 pin connector)
Try another power supply if all else fails. If new power supply does not work with this unit then its a motherboard which is blown and motherboard needs replacing.
Hope this helps
Mar 16, 2010 | TTGI SUPER FLOWER 450W quad fan switching...
Intel D865GVHZ (Gateway Hazelton) motherboard system cooling fan
This fan error message shows up when the CPU fan is not plugged into the CPU FAN plug on the motherboard. The Intel D865GVHZ
motherboard has a total of 4-fan plugs so it is easy to plug the CPU fan into one of the other fan plugs that is not marked CPU FAN on the motherboard.
Apr 12, 2009 | Intel (8W501B1M3G) CPU Fan, CPU Cooling...
Home built 4 yr old pc wont boot
You have voice message telling you CPU test failed , but does it BEEP at all ? if you have a Beep code then replace the CPU fan ( when CPU gets too hot it will either shut down or the PC will not boot up at all )
Jul 23, 2008 | Intel Motherboard
Processor fan failure massage.
I supose the fan works, you then need to enter bios and disable cpu fan monitoring, if the fan doesnt spin connect it to another fan connector or a plain 4pin molex connector / might require a adapter.
Try to get into bios and disable cpu fan fail alarm, keep the temperature alarm on 80 or 70. so it will yell if it gets too hot.
Apr 17, 2008 | Intel Motherboard
CPU fan not turning with ATX 12V connector plugged in
With the fans on its drawing more than the PSU has.The PSU is bad. Replace it. If it still happens please let us know...It shouldnt.
Jan 06, 2008 | EliteGroup P4IBMS Motherboard
AMD Asus K8N-E-DELUXE nForce3 Mainboard (MBASK8NEDLX) Motherboard Logo
97 people viewed this question
Top AMD Computers & Internet Experts
Alun Cox
Robert Monigold
Robert Monigold
David
David
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
