Cant connect to the iternet
I have broadband connection but icant conect to the internet the modem nem is data one zte zxdsl831all
Not accpting the lan card
Posted on Jun 08, 2008
    Problem Solver:
  • 5 Answers
Before we can make any changes on the computer you have to make sure that your modem has got the dsl or light for internet signals is on if it's not on or flashing then contact your isp...
if its on then first you have to do a power cycle of the modem that means unplug all the cables from the modem leave it for 45 secs and then connect them back if it has a reset pin at the back press the pin for 15 secs and confirm whether your are to connect or not.....
Posted on Mar 11, 2008
Is ADSL Modem ZTE model : ZXDSL 831 II compatible or outdated to broadband connection ? How do i find , Modem is working properly or not ?
you need to up date ur drivers then it will b ok ,to check call up control panel click on internet options then click on connections and then set up hope this helps u
Apr 24, 2014 | ZTE Computers & Internet
ZTE MF190 Dialing problem
I have a unlocked ZTE Mf190 USB-Modem. When I put the SIM card in it and connect it to the computer, I am able to connect to 3G Internet via beetel connection manager. Is it also possible to send and receive SMS. But when I try to make a voice call on beetel voice call panel, I receive this error message "Dialing failed! Please try again!" . And also when I use another phone to call the SIM card line number that I put in the USB-Modem, I receive busy tone
Mar 31, 2013 | ZTE Mf190 Unlocked 3g Gsm 7.2 Mbps...
How can i connected a laptop from internet
many way to conect your laptop to internet some of way given here
through broadband with land line or broadband with wirless using wifi modem
first u apply for internet service from any isp in your local are the u able to connect internet using such device called modem
May 19, 2012 | Computers & Internet
Why is it i cant conect to internet?
There are lot of reasons why you cannot connect to the internet, please consider the following:
  • if you are using cable type of internet connection, make sure that the modem is on, the power is properly plug, and the network cable RJ45 is properly inserted both in modem and PC.
  • if you are using broadband, make sure that your enough load in it and has adequate signal in your place or else find a place that has plenty of signal.
  • if you are using wi-fi connection, make sure that you're in a hot spot places that offer free internet connection like hotels, malls, fast food, and schools. But make sure that your computer is wi-fi ready.
I hope these things provided you some knowledge on how to gain access of your internet connection. Please rate it.
Aug 27, 2010 | Microsoft Windows XP Professional
Cant play online games
Here are few things that you can try:
1. update the firmware on the router/modem
2. Open ports on the router/modem for P2P
Jun 10, 2009 | NetGear DG834G Router
How to install zte 831 aii Broadband modem in Linux with USB
I was working at one of Lithuanian internet service providers. We often had clients complaining about ZTE 831 connecting through USB. The answer is - use a LAN card. Sorry.
Mar 13, 2009 | Computers & Internet
Looks like conected but i cant get internet
Router might not be set up with the modem. Your router broadcast wireless signal when it is powered on, so even if it is not connected to a modem(where you get your internet from)you will have a local connection. That's normal. You need to set up the router. Call linksys technical support, if they cannot help try http://technicalsupport.blog.friendster.com
Feb 24, 2009 | Linksys Wireless-G Broadband Router
Asus Router Offline
hello!
-- can you get online if you connect your computer directly to your modem?
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
May 07, 2008 | ASUS WIRELESS ROUTER |WL-520G - RT...
PPPoE over Edimax BR-6104K without a modem
HI,
  Actually in short  "you NEED A MODEM;"
In order to connect your router you need to connect a modem in "bridge mode'( bridge mode is nothing but a configuration on the modem)..
this is a picture of  rear side of a  router,,, you have to connect the modem into the wan port of the router (above),, and in port number 1,2,3,4 you can connect your computers,
Nov 01, 2007 | Edimax BR-6104K Router (br6104k)
Please help
Need more info: You indicated that you moved. 1. Did you change internet service provider? 2. DSL or Cable Broadband? 3. If DSL, what type of modem? This info will help paint a better picture of the problem.
Sep 25, 2007 | SMC Universal Wireless Broadband Router...
Computers & Internet Logo
236 people viewed this question
David Payne
David Payne
