Question about RCA E13335GY TV
Won't work on ac
Tv set works ok when plugged in to 12v dc source.....won't work on ac....
  • 2,130 Answers
1. Make sure the AC power source is ok.
2. Make sure the AC power cord is good with no damage.
3. Look to see if there is a reset button on the rear of the set. If not, then look for a blown AC fuse inside the set.
Since the set works fine on +12VDC, the majority of the TV set is ok. You have a problem in the AC power supply. It could be a blown fuse, bad rectifier / regulator, bad step-down transformer.
The TV typically runs from +12VDC. The AC supply steps-down the 120VAC and rectifies it into +12VDC to power the TV. At some point in the TV, there is junction point where the +12VDC from the sets internal AC supply meets the external +12VDC power source. Usually they are electrically isolated from each other with a switch or with diodes.
Please let me know if I can be of further assistance to you.
- Jim
Posted on Mar 04, 2008
Alba tv blowing the 12v dc adaptor
Check the adapter itself bow out, when it is plugged to Wall AC socket. Do not load it to TV, and check this. If it blows up, the fault is with the adapter itself. If it don't, the fault must be within the TV circuit.
Jun 18, 2013 | Televison & Video
Need a ac adaptor for a Protron PLTV-32. MODEL LU32A1A3. INPUT 100-240V 50-60Hz 3.0A MAX.Output +24V-6A +12V-3A
I found one through Powerpayless.com at http://www.powerpayless.com/ac-dc-power-adapter-for-protron-pltv-32-pltv32-lcd-tv.html. It works great!
Mar 01, 2011 | Protron Ac / Dc Power Supply For Protron...
How can I operate my LG 26LE5300 LED LCD TV in my motorhome the most direct way possible (i.e....without an inverter)? This low power (40-50 watts) TV has an external brick to convert 120 AC to it's...
1) You need to look at the output current rating (AMP) of this AC to 24dc adapter, this 24vdc adapter is a regulated switching power supply that will maintain 24vdc output up the maximum current rating and also has shutdown circuits if the over current draw is detect and also if the output voltage goes up beyond 24vdc to protect the load (TV).
2) To use 12vdc to 24vdc DC-DC booster, it should have the following spec:
A) The output current rating should be at least 20% higher than the load requires to give its head room.
B) It must have regulated output that will maintain the 24vdc when the input (12vdc) will vary from 10vdc ~16vdc or higher since your batteries will not maintain exact 12vdc all the time.
C) It must have good protection circuits that will protect it self from reverse polarity connections, shorted output protection, over voltage output protection.
D) It should provide AC ripple spec on the 24vdc output, it should be in the milli-volt range (you will always get AC ripple riding on top of DC when you rectify the AC into DC).
These are the minimum requirement for your DC to DC booster, which you need to protect your TV and your motor home from burning down.
I hope I explain it OK to you.
Please leave rating if it helps.
Basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jan 15, 2011 | LG 26LE5300 26 in. LCD HDTV
Ac adaptor on my 32 Protron inch LCD TV no longer work
What is the current output of the adaptor? If it is AC and you use only the 12v to 3v it is ok. But if the current output of the adaptor is DC and you use both 24v to 6v and 12v to 3v there is some danger if use the new one. Remember that DC current have polarity.
Aug 29, 2009 | Protron PLTV-32 Television
TV/DVD COMBO WON,T WORK ON DC WILL WORK ON AC
Have you checked the fuse in the plug on the end of the DC power cord? Just unscrew the end.
Dec 30, 2008 | Sansui CDVD9000
Power supply/ no output voltage
Actually i haven't fixed the problem as yet but i did find some info that would help me to fix problem.
I went to google and entered keyword,,, Electronic parts,,there came up a page,,and i went to several manuf sites till i found a replacement transformer,,then i disassembled the power supply and am now waiting for a replacement transformer.
Sep 21, 2008 | Boston Acoustics MicroMedia Computer...
Thermoking
This system uses in conjunction with the transformers a rectifier which converts the High AC current voltage (220V-AC) to a Low AC current voltage (12V-AC) and then the rectifier converts that energy into the D/C current (12V DC). The two diffrent 12V power sources are controlled, operated by a "electric" relay, via a roadside or electric selector switch. DS_TK TECH
Jun 20, 2008 | Classic Minicooler Mini Cooler / Warmer...
12v &240v connections on an ENGEL COOLER
AUTOMATIC AC/DC CHANGEOVER: All Engel Fridge Freezers can be plugged into both AC and DC at the same time. The Engel is smart enough to use the AC while available and then automatically switch to DC when the AC is no longer working. It will also sense the resumption of AC power and automatically switch back to AC making it ideal for high hurricane areas and places where power disruption is common.
Read more: http://www.roadtrucker.com/engel/engel-12-volt-fridge-freezer-technical.html#ixzz2MvRL2xrC
Mar 29, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Power Source
Are you certain the polarity of the connections to the TV are correct? If you connected them in reverse you may have damaged the TV. If there's a fuse in line check that too. BMW
Jun 01, 2006 | Ktv 9BNC 9 in. Television
RCA E13335GY TV Logo
65 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
