Question about Microwave Ovens
Setting the clock....
I am just trying to find out how to set the clock on my microwave. It has become highly frustrating..
  • TCGSXR Mar 04, 2008
    The Model and make is Kenmore Spacemaster Over the Range Microwave...Model #5648568510...
    Master:
  • 518 Answers
Since you did not post the make and model I can't look it up. But most will have a clock button, press that > enter the time > press clock again. On some you hit Time > enter the time > hit time again.
Geno
Posted on Mar 04, 2008
GE Spacemaker XL 1800 turns on for 1 second and then resets. The display shows PRESS CLOCK.
Sounds like your losing power, have you tried it on a completely Different circuit??? Either that or bad fuse or connections inside of microwave.
Sep 08, 2017 | GE Microwave Ovens
How do i fix keypad
Keypads will flash when new oven or when disconnected and setting are lost. First try setting the clock
  • push CLOCK--enter numbers--push CLOCK to see if keypad becomes operational.
If not, unplug, replug and try again. As for "fixing" keypad ....that is not likely to be the problem and even it it were, keypads are not user repairable. For further info, dial the the factory customer support phone number.
Mar 14, 2015 | Microwave Ovens
Microwave model no.NN-C2003S beep sound has become low.Please provide remedy
Try a reset by:
- unplugging power for a minute
- plugging it back in
- setting the clock
- trying it again
If that does not fix it, see your owner's manual to see if it can be adjusted (usually not).
If you still have trouble, you should call for service.
Jan 08, 2013 | Microwave Ovens
Turntable will not rotate, clock setting.
Return item to the place of purchase, it is clear this is a manufacture defect.
Apr 03, 2012 | Microwave Ovens
Hi I am having problems setting the clock on my cooker could you please help thaankyou
HELLO.
solution on setting your microwave clock is explained below.
This is a standard 12-hour clock (12:00-11:59) and does not show a.m.or p.m.
The microwave oven and timer must be off.
  1. Touch Clock.
  2. Touch the number pads to set the time of day.
  3. Touch Clock or Start.
Thanks.
Sep 21, 2011 | Microwave Ovens
I am having difficulty setting the clock on my Baumatic BAF9006 90cm dual fuel cooking theatre can you please help
HELLO.
Setting your microwave clock is explained below.
It is a standard 12-hour clock (12:00-11:59) and does not show a.m.or p.m.
The microwave oven and timer must be put off.
  1. Touch Clock.
Thanks.
Setting the clock on a microwave what is the last action after setting the time. Everything I've tried results in the error message coming up.
According to the manual this is how to set clock.
To set the clock, press "Clock" once or "Timer/Clock" twice (depending on your keypad).
The colon symbol (:) will flash.
Enter time of day. The time appears in the window; the colon continues to flash.
Press "Clock" or "Timer/Clock" again - colon stops flashing; time of day is set.
If you need the manual it is on link below.
http://service.us.panasonic.com/OPERMANPDF/NNH624-SET%20UP.PDF
Good Luck
Nov 08, 2010 | Panasonic NNH965BF Microwave Oven
I cannot set the clock on my LG MS1949G Micro wave
After spending 25 minutes on hold while LG try to find out how their own product sets the clock, I now know that the LG MS1949G Microwave open does NOT have the ability to set a clock that shows the time of day.
Jul 11, 2009 | LG LTM9000 Microwave Oven
Above Range GE Microwave not heating
Try disconnecting the power line from the microwave ad then reinstalling it after a few minutes.. then try heating up a small cup of water.. allow 1.5 minutes on high power. it should get very hot or boil.. if it doesn't get warm or hot then you may have a bad magnetron ( the tube that produces the microwave energy that causes things to heat up or a bad filament transformer that is required for the magnetron to work.In either case, if it fails to heat anything, I would go back to home depot and insist they send someone out to address the problem. many of their appliances come with a one year warranty but you might want to call the store and ask someone there about normal applaince coverage ( less extended warranty) and what they normally offer. An inquiry costs nothing..
Hope this helps..
Sep 17, 2008 | GE Microwave Ovens
Setting clock on Westinghouse WST3501 microwave oven
Normally you would press Clock, enter the desired numbers, then hit Clock or Start. Try it with door open and with door closed.
Otherwise, contact Westinghouse Small Kitchen Appliances at 800-947-3745 or see http://www.saltoninc.com/contact/contact.html
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 10, 2007 | Westinghouse WST3504 Microwave Oven
Microwave Ovens Logo
180 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
