lee Williams Posted on Mar 03, 2010
My Eiki LC-XB28 projector has been working well for 2 yrs. I recently replaced the bulb and the projector continued to work well untill i encountered a problem with getting power during the initial start up of the machine. Once powered the red light comes on for a flash and then the whole unit shuts down. Once repowerd i noticed a tiny flah through the air vent at the front of the unit. Would appreciate some help??
Paul
Level 1:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 84 Answers
  • Posted on Apr 17, 2014
 Paul
Contributor
Level 1:
Cheetah:
Answers
84
Questions
0
Helped
20905
Points
98
One of the primary power circuit parts might be broken
converter IC somtimes fails due to short circuited 400V capacitors
5 Related Answers
Anonymous
  • 6966 Answers
  • Posted on Jul 31, 2007
SOURCE: won't power up
Hi, The owners manual says that if the red light is flashing, it is an indicator that it is ready to be turned on (use remote or onboard on button); flashing red & green - too high temperature inside, the unit is overheated. Check and clean the air filters; If the red light is steady, abnormal condition and you have to call for service. A copy of your manual is available at http://www.eiki.com/resources/resourcedownload.ashx?filename=/ownersmanuals/om_xb25_20_sb20.pdf Hope this be of some help. Pls post again how things turn up. good luck and kind regards.
shyamprocom
procom office solutions
  • 93 Answers
  • Posted on Feb 08, 2009
SOURCE: the projector switching off after 30 seconds
check the following :
1.does the lamp glow
2.do u get the connected image
3.if yes does the screen show temperature or overheat
4.if yes then one of the cooling fans do not work properly & hence the unit turns to standby & goes into protection
if no 1 does not happen, then check the lamp physically,it should not show melted or breakage.
if the lamp seems ok, then the ballast is defective!
William Czarneky
  • 87 Answers
  • Posted on Jun 15, 2009
SOURCE: Our Eiki LC-986 projector has worked flawlessly
It sounds like it is overheating. Are the fans all working? If so, try opening the casing and blowing all the dust out with a can of air from Staples/Office Depot. If the fans aren't working you may need to replace them.
Anonymous
  • 1871 Answers
  • Posted on Apr 12, 2010
SOURCE: Eiki lc-nb3s projector... fan comes on but no lamp
Please check on of these solutions :
1:Remove the lamp from the projector. Ensure that it has no cracks, discoloration or "smoky" appearance.
2:Try removing and reseating the lamp, or to try another lamp.
3:Reset your lamp timer. Most projectors have no way of knowing if you physically have replaced your lamp. They rely on the user resetting the lamp timer
4:Pull the lamp back out of the unit, give is a brisk shake and reseat the lamp. Occasionally there is some buildup on the lamp contacts or filament during manufacturing.
5:Are the input and output vents blocked or obstructed in any way?
6:Are the filters dirty or clogged? Most manufacturers will recommend filter cleaning on a monthly basis depending on usage
7:Remove any extension cords, power strips and/or surge suppressors. Many current model projectors will not even try to ignite the lamp if they detect drops or fluctuation in voltage supplied to the unit. This is a safety feature to reduce stress on the lamp.
PLEASE DON'T FORGET TO RATE !
Anonymous
  • 57 Answers
  • Posted on Aug 15, 2010
SOURCE: plug in and green light
Check the lamp. If it is not blown then there is a problem in the lamp ballast circuit and the projector will need to be serviced.
How can I find the bulb life remaining?
1,turn on the projector
2,press and holding down "UP" for 20 seconds,
any questions, feel free to ask me
have a nice day!
Jerry Lampdeng Limited
When I on the projector on blue screen one black big spot coming
broken lcd panel, entire optical prism assy to be replaced, costly !!
1helpful
Bulb won't work
If you are sure that you installed the new bulb correctly , then I recommend that you reset your projector . Some projectors don't realize that you changed the bulb physically until you reset them .
please rate !
2answers
Our Eiki LC-986 projector has worked flawlessly for at least 3 years. Last week, the projector shut itself down after approximately 30 minutes of use. This happened at least 5 times, so we replaced the...
2answers
Bulb Life
hi,
This is 2000 Hours, 160 Watts, UHP lamp. dont keep it on always.Check the usage and then replace the lamp. It's better to turn off the projector after each class.
The lamp is around $400.00 for Eiki LC-SD15.
Viren
Rave Services India
Top Eiki Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you an Eiki Office Equipment and Supply Expert? Answer questions, earn points and help others
