Question about Olympus SP-350 Digital Camera
Focusing problems Hello, I have been trying to take close-up pictures (between 4-12 inches away from subject) but when I press the shutter button halfway, on the screen I see the image come into focus, come out of focus, come into focus,.. on and on for several moments until it settles on the out of focus image. I've tried setting the camera to the macro and super macro settings, and that doesn't help at all. I know it can focus, because I see it on the screen but for some reason it chooses the out of focus view. What is going on?
  • 3 Answers
You may be beyond (up to close) the focal capability of the lens. Even though there is a macro setting, the lens may not have the capability to focus on an object that close (without adding an external macro lens). The specification on the minimal distance for focus should be listed in the owner's manual.
Posted on May 05, 2008
3 Suggested Answers
neta
  • 852 Answers
SOURCE: The minimum focusing distance
Shooting can be performed at a minimum focusing distance of 3cm. An approximate 2.1 cm x 2.8 cm subject can be captured on the monitor.
Posted on Sep 04, 2005
neta
  • 852 Answers
SOURCE: Minimum focusing distance In the Super Macro mode
In super macro mode, pictures can be taken as close as 2 inches. Subjects measuring up to approximately 1.9 inches by 1.4 inches can be captured on the monitor.
Pictures are out of focus on screen and when taken i cant seem to reajust the focus camera has been working fine untill i went to take a close up shot and now completely blurry .
If you are focusing On a subject make sure first that you are two feet away,
You can also try to turn On the blur reduction under setup menu. make sure also that your on auto mode or smart scene.
when taking picture indoor turn of the flash, you can do this by pressing the flash button On the camera
here are some basic troubleshooting
try to put your camera On a tripod or on the table to stabilize the camera then try to take a picture.
the technique of taking a picture Is first you need to half press first on the shutter button and you will noticed camera will adjust Now if the camera already adjusted pull press on the shutter button.
Blurry picture may caused if camera is not stabilized and may cause also if the flash will not fire correctly.
you may call tech support for further support toll free 1 800 235 6325
Nov 12, 2009 | Kodak EasyShare V550 Digital Camera
Auto focus problem
If you set the camera on "manual", it assumes you focused manually and allows you to press the shutter without having to stop half-way. Check your settings.
Oct 07, 2009 | Canon Rebel XT / EOS 350D Digital Camera
How to get manual focus on Olympus Camedia C-750 ultra zoom digital camera
TTTTTTTTTTTTTTTTTTTTTTTTITf correct focus cannot be obtained
When the subject to be focused is not on the AF target mark (not positioned
in the center of the composition), you can use the following steps to obtain the
correct focus on the subject. This operation is referred to as "focus lock".
Determine the position of the subject after focusing (Focus Lock)
1 Press the power switch.
• The camera turns on in the shooting
mode.
• The lens extends and the monitor turns
on.
• The orange lamp lights.
2 Turn the mode dial and select a
shooting mode.
"Shooting mode" (P.36)
3 Position the AF target mark on
the subject you want to focus on.
• When shooting a hard-to-focus
subject, point the camera at an object
about the same distance away as the
subject.
Press the shutter button halfway
until the green lamp lights.
• When the green lamp lights steadily,
the focus and the exposure are locked.
• When the green lamp blinks, the focus
and exposure are not locked. Release
your finger from the shutter button, reposition
your subject and press the
shutter button halfway again.
5 Keeping the shutter button
pressed halfway, recompose
your shot.
6 Press the shutter button fully.
Try the above, info from D-535, C-370 and X-450.
I can email you the complete manual if this works.
Regards
Phillip
Sep 12, 2009 | Cameras
My picture is blurry or out of focus.
ake sure your subject is within the camera's range. You should be at least 20 inches away to take a picture without the flash, and 20 inches to 8 feet away to take a picture with the flash. You can take a picture as close as 8 inches in macro mode. When you take macro close-ups, make sure you have adequate lighting (with the flash disabled). Using a tripod will help you capture sharp pictures. Make sure you hold the camera steady after you press the shutter button (until the red light starts to flash), and your subject isn't moving. If you are shaking the camera when you lock the focus, a warning icon appears in the right corner of the LCD. If you want to photograph a moving subject, you can change the shutter speed while the camera is connected to your computer. Try increasing the shutter speed. See Chapter 4 for more information about how to change the shutter speed from the LCD menus. Make sure your flash is not set to flash off. When you focus on a nearby object, your picture's background may appear blurry. Try changing your focus.
Sep 13, 2005 | Epson PhotoPC 800 Digital Camera
Picture blurry or out of focus.
Make sure your subject is within the camera's range. You should be at least 31 inches away to take a picture without the flash, and 31 inches to 8 feet away to take a picture with the flash. You can take a picture as close as 8 inches in macro mode. When you take macro close- ups, make sure you have adequate lighting (with the flash disabled). Using a tripod will help you capture sharp pictures. Make sure you hold the camera steady after you press the shutter button (until the red light starts to flash), and your subject isn't moving. If you are shaking the camera when you lock the focus, a warning icon appears in the right corner of the LCD. If you want to photograph a moving subject, you can change the shutter speed while the camera is connected to your computer. Try increasing the shutter speed. For more information, see Chapter 6. Make sure your flash is not set to flash off. When you focus on a nearby object, your picture's background may appear blurry. Try changing your focus.
Sep 13, 2005 | Epson PhotoPC 750Z Digital Camera
What should I do if the picture is blurry or out of focus?
Make sure your subject is within the camera's range. You should be at least 20 inches away to take a picture without the flash, and 20 inches to 8 feet away to take a picture with the flash. You can take a picture as close as 8 inches in macro mode (2.3" zoomed to wide). When you take macro close-ups, make sure you have adequate lighting (with the flash disabled). Using a tripod will help you capture sharp pictures. Make sure you hold the camera steady after you press the shutter button (until the red light starts to flash), and your subject isn't moving. If you are shaking the camera when you lock the focus, a warning icon appears in the right corner of the LCD. If you want to photograph a moving subject, you can change the shutter speed while the camera is connected to your computer. On the PhotoPC 3000z you can also use Program (Sports Mode) or Manual (Shutter Priority) to increase the shutter speed. Make sure your flash is not set to flash off. When you focus on a nearby object, your picture's background may appear blurry. Try changing your focus.
Sep 12, 2005 | Epson PhotoPC 3000Z Digital Camera
Cannot focus on a particular subject
If the camera is having a difficult time auto-focusing, you can try the FOCUS LOCK feature. This feature allows you to focus on another subject roughly the same distance from you and then move the camera back to the intended subject and take the picture without losing focus. First, turn the camera on and locate the Autofocus Target Mark in the center of the LCD. The AF Target Mark resembles an open and close bracket [ ]. Position this AF Target Mark on a subject roughly the same distance away as the subject the camera is having trouble focusing on. Press the shutter button halfway enabling the lens to focus. While holding the shutter button halfway down, aim the camera at the original subject and press the shutter button all the way down.
Sep 01, 2005 | Olympus D-630 Zoom Digital Camera
Focus on a particular subject?
If the camera is having trouble doing an auto focus you can try the FOCUS LOCK feature. This feature allows you to focus on another subject roughly the same distance away from you, and then move the camera back to your original subject and take your picture without losing that focus. First turn the camera on and locate the AutoFocus Target Mark in the center of the LCD. The AF Target Mark resembles an open and close bracket [ ]. Position this AF Target Mark on a subject roughly the same distance away from you as the subject that the camera is having trouble focusing on. Press the shutter button halfway enabling the lens to focus. While keeping the shutter button pressed halfway, move the camera back to include the subject you originally wanted in the image, then press the shutter fully. (Please see page 42 in the D-535 Zoom Reference Manual in Section 3, under the heading titled “If Correct Focus Cannot Be Obtained”, for a more detailed explanation.)
Aug 31, 2005 | Olympus D-535 Zoom / C370 Zoom Digital...
Focus
If the camera is having a difficult time auto-focusing you can try the FOCUS LOCK feature. This feature allows you to focus on another subject roughly the same distance from you and then move the camera back to the intended subject and take the picture without losing focus. First, turn the camera on and locate the Autofocus Target Mark in the center of the LCD. The AF Target Mark resembles an open and close bracket [ ]. Position this AF Target Mark on a subject roughly the same distance away as the subject the camera is having trouble focusing on. Press the shutter button halfway enabling the lens to focus. While holding the shutter button halfway down, aim the camera at the original subject and press the shutter button all the way down.
Aug 31, 2005 | Olympus Camedia D-435 Digital Camera
If the camera is having trouble doing an auto focus you can try the FOCUS LOCK feature. This feature allows you to focus on another subject roughly the same distance away from you, and then move the camera back to your original subject and take your picture without losing that focus. First turn the camera on and locate the AutoFocus Target Mark in the center of the LCD. The AF Target Mark resembles an open and close bracket [ ]. Position this AF Target Mark on a subject roughly the same distance away from you as the subject that the camera is having trouble focusing on. Press the shutter button halfway enabling the lens to focus. While keeping the shutter button pressed halfway, move the camera back to include the subject you originally wanted in the image, then press the shutter fully. (Please see page 20 in the D-425 Advanced Manual in Section 2, under the heading titled “If Correct Focus Cannot Be Obtained”, for a more detailed explanation. This Advanced Manual is provided on a separate CD, in Adobe PDF format.)
Aug 31, 2005 | Olympus Camedia D-425 / C-170 Digital...
Olympus SP-350 Digital Camera Logo
89 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
