That does not sound good!
Possibilities:
The D-A convertor is going bad. The hiss could be digitizing noise or noise in the conversion network within the chip.
Noise in a preamp op=amp chip.
Noise in a passive component such as resistor or diode.
Bad plated through hole in circuit board.
The power supply is NOT very likely and since volume affects loudness, teh power amp is NOT suspect..
Troubleshoot this IMMEDIATELY using circuit cooler to isolate bad part.
A tiny squirt on suspect components till you hear a change... then gentle warming with hair dryer till you home in on the part...
I SUSPECT you will find the parts are mostly surface mounted... IF you have not had experience in replacing these before, better take it ot a shop that is equipped to do this.
Testimonial: "Nice answer, and explanation. I have got a good idea of what section is went wrong. I am taking it to a local service centre."
Thanks a lot for the info. What is a circuit cooler ? I have never replaced surface mounted components. I should find someone around to do this I believe.
