Question about SanDisk Sansa E280 MP3 Player
MP3 player won't turn on with or without plug in.
I just received it yesterday and charged it and loaded it with songs. After about an hour of play it will not turn on. I tried plugging back into my computer but that still does not work.
    Problem Solver:
  • 15 Answers
First toggle the hold switch, make sure it's not on.
then press and hold the menu button+ centre button, together at the same time for about 10 seconds.
if that doesn't work try pressing the middle button+the play button, for a few seconds. It should work.
If the thing still doesn't turn on just hook it up to a comp and leave it there for a few hours. mine actually took a week to recover.
Posted on Mar 04, 2008
Won't show up on my laptop when i plug it in
can I load song on to my I pad and then load the songs into my mp3
Apr 12, 2013 | Eclipse 180 G2 RD -180 G2 Rd 180G2 4Gb Mp3...
BUSH MP3 MPK4312BUK does not charge up when inserted into USB drive
to get this device to charge it is more complex than just plugging it in.
when i first bought mine it wouldnt charge at all, the way i found to get it to charge while plugged into a usb powered device is to have it switched on, press the M key until it starts playing then hold the play/pause button until you only see the charge bar. then your mp3 player will charge correctly. if only the manual was even slightly relevant to the product...
Oct 10, 2011 | Audio Players & Recorders
Hi, my swimp3 was not used for the last 2 months. I charged it up full yesterday and when plugged into the computer it plays well (i.e I can format it, change songs, actually have it "play",...
Hello nehajo88,
Thank you for contacting us. I work in the FINIS Technical Support department and would strongly recommend that you go to our support page and create a ticket so we can process you for a replacement as it seems to be a defective unit. So please visit our support page (http://www.finisinc.com/support/) and create a ticket and I will be happy to further process your case there.
Thanks!
Aug 02, 2011 | Finis Swi MP3 Player
I charged my swimP3 but it won't turn on when disconnected from the computer.
The Swimp3 Player does need to be charged for at least 3 hours for the best experience. Here are some tips that could help solve your problem:
Problem: The player doesn't turn on.
Suggestion: Charge the battery in the player for at least three hours, this will allow it to fully charge. You can charge it by plugging it into the USB port on your computer or by using a USB wall charger (sold separately). If you do choose to use a computer to charge it, be sure your computer is turned on. If there is no power to the computer, then no power is going to the USB port to charge the Swimp3 player.
Additional Tip: The charging answers are in the Green Indicator Light.
If the green light is flashing off and on, then your SwiMP3 player is charging
If the light is solid green, the SwiMP3 player is fully charged
If you have no green light - then it is not receiving a charge - check the connection, make sure its plugged in properly, or check to see that there is power from the computer or USB wall charger.
Problem: I have charged my player, the light is solid green, but no music plays.
Suggestion 1: Have you loaded music onto the player? Try adding a few mp3 or wma files and test it again.
Suggestion 2: If the power is on, you loaded music, clicked the Play button and no music comes out, press and hold the RESET button for 4 seconds. It's kind of like rebooting your computer when it crashes. Many times a simple reset clears up any challenges.
If that doesn't work, then it could be the
* volume
* incompatible files or
* folders
Volume: On some units the factory volume setting is very low.
Solution: Try turning up the volume by pressing and holding the "+" PLUS button. If you click the "+" button it changes the song, pressing and holding the button will actually control the volume. And if its too loud, press and hold the "-" MINUS button to bring the volume back down.
Incompatible Music Files: If you have loaded a music file that is not compatible, it simply won't play. The SwiMP3 player works with mp3 or wma files, but not aac (like from iTunes).
Solution: Remove the incompatible files. Convert your other music files to mp3 or wma, and if you are importing your songs direct from itunes, you'll need to convert them to mp3s first.
Incompatible NON-Music Files: An MP3 player is similar to a Thumb Drive or Flash Drive because it can hold any kind of file that will fit in the drive's capacity. However, if you have loaded an incompatible file - including JPEGs, Cover Art, Word Docs, anything that is not an MP3 or WMA file, the player simply can't translate it into music.
Solution: Remove the incompatible files, leaving only your mp3 or wma files in your root directory.
Folders: The mp3 player is not able to open folders and play music files stored inside, to the Swimp3 player the folder is simply an un-playable file.
Solution: Open the folders, move or copy the music files into the root directory (remember, mp3 or wma - not aac), then delete the folders.
Michelle
Authorized Finis Dealer
Get Swimp3 Deals at WaterproofMusic.com
May 21, 2010 | Finis Swi MP3 Player
How Long Do I Charge Before I Can Put Songs On?
You can do it while plugged in to usb charger. Otherwise you can do it 2 hours after. It should be charged for about 6 hours
Oct 29, 2009 | Philips GOGEAR SA6045 MP3 Player
Can't figure out how to charge sansa mp3
maybe plug it in ur computer try that mary
Feb 17, 2009 | SanDisk Sansa Clip MP3 Player
IPod mini battery dies when nearly fully charged, often while skipping songs.
iPod batteries are cheap on ebay...like $5...and come with installation instructions. Try installing a new battery and see what happens...?
Feb 11, 2008 | Apple iPod mini 2nd generation MP3 Player
2 problems with my coby mp3 player
I have the same problem just bought the thing yesterday and it won't charge I downloaded music yesterday and charged it, now it isn't recognized by the computer.
Went thru the whole troubleshooting chart and nothing happened, I did email techsupport but haven't heard anything. I guess I'll take the thing back and get it replaced.
Jan 03, 2008 | Coby MP-C582 MP3 Player
No power
I am having the exact same problem. I put songs on the MP3 player and it hasn't worked since. I'm not getting any help or support. If you find out what the problem is, please contact me. This is is so disappointing to buy a Xmas present that doesn't work!
itsmesusan@roadrunner.com
Dec 27, 2007 | GPX MW3837 MP3 Player
Mp3 Player Won't Charge
wiggle your usb cord - I had to wiggle mine a bit where it plugs into the usb port in the computer before it was recognized and listed as a device in 'my computer'. only then did it actually start charging; if your computer is not recognizing it is plugged in, it may not charge.. when i finally figured this out, the actual charging of my 4 gig audiophase mps only took 10 minutes- previously i was trying to charge it for hours without any luck.
Aug 31, 2007 | Audio Players & Recorders
SanDisk Sansa E280 MP3 Player Logo
44 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
