It could be something as simple as a scratch on the disc. Check to see if there are any scratches or laser burn marks on the discs. Scratches or marks on discs will render game discs unplayable or will freeze the game and will often show a message stating “Disc Read Error” or something to that effect. Best remedy for starters, is to clean the discs and make sure there are no scratches or marks left on the play-side of the discs. A common problem that Xbox owners are reporting is if the console is moved during play, a whirring noise is heard and then when the disc is removed, very visible laser burn rings are found on the disc.
Laser burn, looks like complete or partial circular scratches around your disc, also known as “the ring of death”. This occurs to discs when the games console has been moved whilst playing, from an upright to a horizontal position or vice versa or simply knocked against or the wires may have been just tripped upon. Discs are then impaired by a ring of laser burn, which is a circular scratch into the disc. Some home remedies may help with very light scratches on some discs but a professional disc repair service is normally required to fix laser burn scratches or damage to XBOX discs.
For further help on Xbox & Xbox 360 disc repairs or to get XBOX discs repaired back to "As Good As New Condition", visit:
www.discREPAIR.ie
Check the “More Info” & “FAQ” Sections for further details on disc repairs and related matters, or send your discs for repair.
If this laser burn scenario is consistently happening to your game discs especially if the console has not been moved or bumped against while the discs is in play, the games console itself may require repair. You should contact Microsoft for assessment and guidelines.
Hope this Helps!!
The driver on your xbox could be corrupted or the disc's are too scratched, Try getting the discs buffed out. Sorry to hear.
Hope this helps ^^. Please dont forget to rate, Thanks
Testimonial: "thank you for the info i know its not the cd being scratched as it works on all other xbox's ill assume its the driver and try to sort it out thanks."
