Task manager i am having a different problem,. when i boot the computer with xp sp2 cd pack . after installing the task manager will appear on the taskbar when i right click the mouse. after doing some work otherwise installing some software the task manager is simply not visible. i have done my computer by booting upto four times. but every time i am facing the same problem.  please suggest.....
  • mr_viru Mar 05, 2008
    if you are suggesting me that i use McAfee or ESET Nod32/Smart Security.  this maynot solve my problem. because whenever i am booting my computer with the bootable cd by formating the total hdd. then also i am having the problem..  i think you may choose me another solution.  i have tried this booting operation about three times upto now. pls ......
    Problem Solver:
  • 16 Answers
More details about your problem would help me understand how best to go about the issue.
For now, the best that I could recommend is to have your system checked for viruses. The best I've used so far is ESET Nod32/SmartSecurity. But the latest version of McAfee would also do.
Posted on Mar 04, 2008
  • Jeff Imperial
    Jeff Imperial Mar 05, 2008
    Your case, as it seems to me now, may very probably be one when the svchost file from ~\sytem32 folder has been deleted. If you're getting a Stop Error prompt every time you startup, then for sure that it's the problem.
    Or..
    Something went wrong during your installation. It may have been unable to copy a required system file, or perhaps the installation did not complete successfully.
    The next best step would be to have a COMPLETELY CLEAN reinstallation of your Windows after having your hard disk drive reformatted. That's the only full proof way to solve oyur problem.
    But for a less agressive option..
    Try taking out your HDD and attach it as a "slave" drive in another PC that has Interner connection (to make sure the AntiVirus is updated). Then have it scanned for viruses. After scanning and cleaning/deleting/quarantine, retrieve the information you want. You might have music files, documents, videos etc that you want to back up. Copy it to another HDD. Then reformat your (slave) drive using Computer Management from the Control Panel. Pop the newly reformatted drive back into the old PC and install Windows.
Missing task bar - running vista
Sounds like explorer.exe is not running:
1. Hit Ctrl + Shift + Esc at same time.
2. Windows Task Manager should open.
3. Hit File on top menu.
4. Select New Task.
5. Type explorer.exe and hit OK
That should bring your task bar back.
Jun 02, 2010 | Microsoft Windows Vista Home Premium...
Windows did not appeared, only mousepointer was appeared. The icons on destop, taskbar and start menu are not appeared. What are the best solutions Tank you!
Press Ctrl + Alt + Delete together and Task manager will be opened. Click on file -> New task . In the box type explorer.exe.a nd click ok. If this doesn't works boot your computer from XP disk and run repair from disk.
May 27, 2010 | Microsoft Windows XP Professional SP2
Please re-instate my computer virus protection paid this year,
Hi, click on this website, you can download the "Microsoft Security Essential; I use it, and "recommend it "highly." Rating the solution is appreciated, thanks." http://www.softpedia.com/get/Antivirus/Microsoft-Security-Essentials.shtml
Apr 13, 2010 | Trend Micro "PC-cillin" Internet Security...
Volume icon disappear in my task bar. an error msg appears driver is not installed. i dnt have my xp cd to install it again.
Go to Start - > Control Panel - > System
Then the Hardware tab.
Then click "Device Manager" . Look under Other Devices and if the Audio driver is under that you need to find a sutible driver for your computer.
Jan 06, 2010 | Microsoft Windows XP Professional SP2
MSI RS482M4 Mobo not recognizes USB port on XP SP2-3 boot.
Try to find application that load the CPU at 100% by seeing TASKMANAGER.
To start TASKMANAGER press CTRL+ALT+DEL on the keyboard, select PROCESSES TAB, click on CPU to order by CPU load and find process that come near to 100%.
Oct 18, 2009 | Computers & Internet
Laptop does not finish booting up
i recommend you need to re-installed the OS
Mar 12, 2009 | Computers & Internet
HELP ME
hi there my friend,
we have the hard way and then we have the easy way...
the hard way is to bootup with your bootable xp cd .follow the installation guide ..then.put in your key when you get the chance to ..and finish the installation. then apply service pack 2 to your installation .. and you're done...
the easy way would be to make a Slipstream Windows XP Service Pack 2 CD....which you can use each time you need to fix your system.
1 - Download the (full) "Network Install" of the Service Pack (English version [266 MB]), and save it to a directory (folder) on your hard drive (in my case D:\XP-SP2). Other languages can be downloaded from the Microsoft Download Web site.
Note: do not use spaces in the folder name!
2 - copy your Windows XP CD to your hard drive. Just create a folder (I used \XP-CD), and copy all the contents of your Windows XP CD in that folder.
3 - , open a Command Prompt (Start > Run > cmd), and go to the folder where you downloaded SP2 (cd \foldername). Type the command: servicepack filename /integrate:drive/path. In my example the command is WindowsXP-KB835935-SP2-ENU /integrate:D:\XP-CD.
Extract SP2 files
If you get the error:
This service pack can't be integrated error
This is caused by the fact that your Windows XP CD contains updates that will be automatically installed when you run setup. This type of CD's will usually be from larger OEM suppliers (like Dell, HP, or others).
You cannot use this type of CD to create a slipstreamed SP2 install.
First, the files will be extracted, and next they will be integrated in your Windows XP files:
Updating Windows Share
When ready, you should get a confirmation. Windows XP Service Pack 2 has now been Slipstreamed into your original Windows XP files.
Slipstream Completed
Creating a Bootable CD
For this part I used IsoBuster and Nero Burning ROM 6
After you install IsoBuster, you can choose to use only the product's free functionality for what we want to do, IsoBuster will look like the image below (you need to have your original Windows XP CD in the CD-ROM drive).
Start to extract the boot loader from the original Windows XP CD. Using IsoBuster, select the "folder" Bootable CD, and right-click Microsoft Corporation.img. From the menu choose Extract Microsoft Corporation.img, and extract it to the folder on your hard drive where you have your Windows XP files (D:\XP-CD in my case).
Extract Boot Image
Next, start Nero Burning ROM, and choose CD-ROM (Boot) in the New Compilation window. On the Boot tab, select Image file under Source of boot image data, and browse to the location of the Microsoft Corporation.img file. Also enable Expert Settings, choosing No Emulation, and changing the Number of loaded sectors to 4 (otherwise it won't boot!)
Nero Boot Settings
The ISO tab should be configured correctly as shown below:
Nero ISO Settings
If you have an older version of Nero you won't have the option Do Not Add ";1" ISO file version extention under Relax ISO Restrictions. You won't be able to boot your new CD, so update Nero!
You can configure the Label tab to your liking, I would however recommend that you keep the Volume Label the same as on your original Windows XP CD. Here are some (English) Labels:
* Windows XP Professional: WXPCCP_EN
* Windows XP Home: WXHCCP_EN
* Windows XP Professional OEM: WXPOEM_EN
* Windows XP Home OEM: WXHOEM_EN
Nero Label Settings
Next press New, and from the File Browser window, select the files and folders from your slipstreamed location (in my case D:\XP-CD). Now drag & drop the selected files in the ISO1 window.
Copy Files
Next, burn your new CD.
Burn
You now have a Bootable, Slipstreamed Windows XP Service Pack 2 CD!
Apr 28, 2008 | Computers & Internet
Registry Editor, Task manager, Command Prompt Disabled
hi, your computer is attacked by virus .install some antivirus and scan the system to resolve this problem .
Dec 17, 2007 | Microsoft Windows XP Home Edition
Where is Linux mbr file
There's nothing like the Linux MBR File. The option to boot to multiple operating systems is controlled by a software called as the "Boot-Loader".
Windows XP and Linux both have their versions of boot-loaders. The Bootloader that Windows XP uses is called the NTLDR, whereas Linux provides many bootloaders (prominent among them being "Grub" and "LILO").
>but Linux is shown in the manage option from the My Computer in Win XP 2.....
That is the control section of NTLDR. So from what I understand you shouldn't have a problem selecting the operating systems.
If you want the Linux bootloader taking control of the boot process, you can always install it.
All you need is a Linux CD and then run the setup for "Grub" or "LILO".
Information about installing Grub or LILO can be found easily on the internet.
Oct 19, 2007 | HP Data Protector Express Software...
My dvd rw is not detected
When installing SP2 version, you possibly corrupted the drivers for the DVD. It is possible there are different drivers for the DVD between XP and XP (sp2). Go to the laptop mfg website and download the newest drivers for the DVD.
Aug 20, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
David Payne
David Payne
