1. Press the [Copy] button
2. Press the [Menu] button seven times ("USER DATA" or the equivalent will appear on the LCD)
3. Press the [+] button five times
4. Press the [OK] button
5. Press the [+] or [-] until "ENGLISH" or the equivalent (e.g., "ANGLAIS") appears on the LCD
6. Press the [OK] button
7. Press [Stop/Reset] to complete
SOURCE: Canon Pixma MP130 error 5200
Simple! After saying a prayer, I pulled the power lead from the printer (whilst it was still switched on) then I replaced it. Hey presto! Everything returned to normal!
The moral of this story is: do the simplest things first, rather than uninstalling, re-installing, etc. as I had previously tried to no avail.
Caution: if you do think of uninstalling MP Navigator, consult the Users' Guide - there is a correct order for doing this, otherwise you end up with MP Navigator on board and unable to either uninstall it or re-install from the CD, as I did.
Fortunately, there is still Omnipage and Scangear available which can cope perfectly with all scanning needs.
SOURCE: i changed ink my printer showing wrong cartridge
Make sure you are using factory new Canon ink cartridges.
If you purchased re-filled cartridges or third party cartridges that is most likely your problem.
Don
SOURCE: I have a canon pixma mp130 and it keeps saying cart. jammed
Press menu to maintenance.....go to cleaning roller....repeat cleaning 3 times....return to copying...hope this helps
SOURCE: Canon PIXMA MP780 Language setting.
I can not find the appropriate software for this type of printer (MP 780/750), because it isnt in the offer of Canon printer for the instalation. What from offered printers I should choose for the instalation of printer to my PC?
