Question about Dell 2200MP Multimedia Projector
Remote control how do i get the remote to work. I have a dell projector with a dell laptop lattitude 100L. i would like to change slides using the remote to the projector. susan
    Problem Solver:
  • 12 Answers
First, make sure your batteries are good.
For moving the slides ahead, there is a button that says next page. When you push that, it will advance.
O, another things is that you must connect your computer to the projector with a USB cable. I assume that you are trying to run it from a computer.
Perhaps you could explain more about what you are using.
Posted on Mar 24, 2008
Several times each day my mouse on my laptop (Dell Lattitude E5510) becomes unresponsive. I can then use the touch pad to restore my control or the mouse works if I switch USB ports. It doesn't se
Some mouses stop responding if you do not use it for a few minutes. This is usually a battery saving feature. Usually all you got to do is use the scroll button to reactivate the mouse by scrolling up or down. This will bring the mouse back to life. When you change the ports you are actually doing the same thing (reactivating). Also check whether battery needs changing.
Mar 01, 2012 | Computers & Internet
What function key, etc. do I need to use to communicate with a digital projector from my inspiron 1545 laptop? ...
The on-line documentation is scanty (there are about a dozen Ultralight models, but I could not find a link to manuals for any of them), but I've found the following general information:
To cycle between LCD, projector, or both displays, look for a Fx key (it may be F8) with either a monitor icon or "LCD/CRT" over it. To use the key for this operation, hold down the Fn key (labeled in the same color as the monitor icon, probably located to the left of the space bar) and press the Fx key. The brightness and contrast controls work the same way.
I found no reference to controlling the projector from the keyboard. The USB connection on models that have one works in the opposite direction; it lets you use the projector's remote control as mouse buttons to go through slides in a presentation.
Feb 08, 2011 | Dell Inspiron 1525 Laptop
My dell d630 laptop wont recognize my infocus lp70+ remote control and I can't advance my powerpoint slides with the remote control
Here's what the User's Manual says:
Using the Remote Control
To advance PowerPoint slides with the projector's remote, you
must connect the USB cable on the projector's computer cable to
the computer. See page 8 for more information.
Point the remote control at the projection screen or at the front or
rear of the projector (not at the computer). The range for optimum
operation is about 30 feet. If you point the remote at the
projection screen, the distance to the screen and back to the projector
must be less than or equal to 30 feet. For best results, point
the remote directly at the projector.
If you are displaying presentations in Microsoft® PowerPoint®,
you can use the remote's Previous and Next buttons to navigate
through your presentation while in Slide Show mode.
Jan 26, 2011 | InFocus LP70+ Multimedia Projector
My dell d630 won't recognize the infocus lp70+ remote control and I can't advance my power point slides?
Hitachi cp-s240 remote question
Hitachi data projectors are able to function as a mouse using either the USB port or the control port located on the back of the projector.
However, they are not intended to be used as a remote presenter. This means that although you can use the remote as a mouse, you will not be able to change slides in a full screen slide show using powerpoint.
I recommend the Targus remote presenter for this purpose. This device will function as a mouse, pointing device, and will allow you to change slides in powerpoint. In addition, it's inexpensive, wireless, and small enough to easily fit in your pocket.
Mar 02, 2010 | Hitachi CP-S240 Multimedia Projector
Where is the hard drive located on the dell lattitude laptop
Take 2 screws out of the bottom of the laptop. The hard drive slides out of the side of the unit like the CD Drive would.
Jan 22, 2010 | Dell Lattitude D600 Notebook
Dell 100l has two green flashing lights at the front
Kindly remove the ram and clean it and fix it again.
Sep 22, 2009 | Dell Latitude 100L Notebook
Will not change slides forward/backward, remote focus ok,
Your problem is most likely caused by a broken wire under the control panel or a wire somewhere in the "cycle circuit" that is no longer connected. You should seek out a factory-trained repair dealer who has a schematic that can trace down your projector problem.
Mar 15, 2009 | Kodak 4200 Slide Projector
Remote control
Remote of projector just control projector only and wont do questioned / asked job as power point slides are in laptop / desktop.
Sep 12, 2008 | Sanyo PLC XU35 Multimedia Projector
How to Use remote to forward slides of PP presentation
Hi Carolyn
You'll see that the Projector came with a USB cable. The USB cable should be connected from your PC to your Projector and this will enable you to flick through your slides with the normal BenQ remote control.
Thanks for using Fixya !
May 06, 2008 | BenQ PB6100 Multimedia Projector
Dell 2200MP Multimedia Projector Logo
273 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
