Question about Belkin F8E874 Mini Wireless Optical Mouse
Battery installation how do i open it to put a new battery in
    President:
  • 8,637 Answers
Normal 0 If the mouse doesn't have a little door to open on the bottom, then try this.
Just behind the Left and Right keys where your hand rests, apply firm pressure down on the cover and slide to the rear. Some mouse manufactures have used this type of access to replace the batteries.
Hope this helps. Bud
Posted on Jan 20, 2009
Cannot open remote battery compartment
Amazon.com: Customer Discussions: battery installation for remote ...
www.amazon.com/forum/kindle?_encoding...
Amazon.com, Inc.Jun 11, 2014 - As strange as it may seem to everyone else I cannot figure out how toopen the remote for my Kindle HD TV to put the batteries in.
Amazon Fire TV Stick: How To Open The Remote's Battery ...
? 0:44
https://www.youtube.com/watch?v=F__fFr7nZOE
Nov 30, 2014 - Uploaded by The App Store Chronicle
Here's how to put the batteries into the remote for the new Amazon Fire TV: ... Amazon Fire TV Stick: How To Open TheRemote's Battery Door.
Open Amazon Fire TV 2015 remote battery compartment ...
? 2:35
https://www.youtube.com/watch?v=FyTHjZu3L6M
Oct 6, 2015 - Uploaded by sfsilicon
I am not responsible for any damage to your remote. Proceed with caution. This video shows you how to open ...
Jan 12, 2016 | Samsung TV Remote Control
Do I need to buy a battery for my new watch?
Most watches with mechanical movements are shipped with the battery disconnected (with the crown extended). Watches with an LCD display that is on will have been drawing the battery down. The original factory supplied battery will not last as long as a brand new battery because of this - but you should get a fair amount of life out of it.
If you're concerned, you can always opt to purchase a new battery and have it installed when buying the watch. Ask to be sure that if installed - the warranty is not voided. Some places will tell you if the watch is opened to replace a battery it will no longer be considered waterproof. If that's the case *RUN* and find a reputable dealer to purchase from instead. If they will install - make sure the sales slip indicates that THEY installed a battery for you. Then go home and wet the watch or put an a glass of water to be sure the seal it good. You should get that type of sales slip whenever someone installs a battery in your watch.
Jan 16, 2015 | Watches
Remote will not lock doors open gas cap or trunk
Your settings are safe, install a new battery and it will be fine again-make sure the battery is installed properly (correct polarity).
Mar 16, 2014 | 2003 Volkswagen Passat
How do you change the batteries?
Remove the Battery cover on the back of the remote. Remove the dead batteries. Put them in recycling Open the new batteries and install them paying attention to polarity. Replace battery cover
May 06, 2011 | One For All URC-4330 Remote Control
Put a new battery in the car and now the heater does not blow any hot air. Car does not over heat. Thermostat is fine.
Without knowing the specifics...I would hazard a guess that in the process of installing the new battery, the mechanism that opens the heater water valve was disconnected. It might be a vacuum operated valve, or it might be a mechanically (cable) operated valve.
Odds are it is a vacuum operated valve and the vacuum supply hose was knocked off during battery installation.
Good luck
Jan 02, 2011 | Buick Park Avenue Cars & Trucks
How do you install a battery in a 95 kia sephia
Open bonnet, undo the bolts on wires for battery remove cables, Remove old battery and place new battery then put the cables back
Remember Red on + and black on -
Then tighten the bolts
go start the car
Jun 22, 2010 | 1995 Kia Sephia
My Sentry S3807 just will not open. I have the combination right and the key, but it won't open. The batteries could be shot, I suppose, but how do I get in?
How to install sentry safe batteries
slide open the battery cover located just below the keypad.
Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated.
reconnect the connector and put back the battery holder. Slide the cover back in place.
How do I insert the batteries on my advanced electronic lock safe? On the newer model Fireproof Sentry Safes my locksmith recommended me To install batteries,
turn the electronic lock case to the right and remove. Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
Aug 26, 2009 | Sentry Fireproof Safe
Need instructions on how to change the battery on my 1999 300M?
You need to remove the panel from in front of the passenger side front tire to access the battery. You will also have to remove the air filter housing to get at the battery hold down so you can remove the battery. Hope this helped.
Hope it helps and have a great day!
Jun 15, 2009 | 1999 Chrysler 300M
Sentry S3807 safe-cannot open
locksmiths agree on how to install sentury safe batteries
to install batteries, turn the electronic lock case to the right and remove.Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
Jan 26, 2009 | Sentry Fireproof Safe
New Battery Installation (Problems)
I would remove the battery and give it a good charge. New batterys require a low amp over night charge. A cars altenator isn't designed to charge a battery it's made to maintain the battery to it's fullest ability. The headlights opening and closing would indicate to me a low voltage, causing the relays for the headlights not to fully shut or open. Let me know if this solves your issue, if not we can trouble shoot farther. Thank you for using fixya.com
Sep 29, 2008 | 1991 Mercury Capri
Belkin F8E874 Mini Wireless Optical Mouse Logo
198 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
