I have a 37" philips tv about 2 years old. it will not come on the red light on the front is flashing me a 14 code.
  • 2,322 Answers
Error14 is a combination of 2 faults. The first is that you check the voltage at the 3A95 resistor, located at main control board (B3E). 2nd is that you need to findout why there is absence of power at the audio supplies board. The problem for this situation is that the "MF supply" board is faulty within.
Check this link to get the service manual. Is one the cheapest i've found.
Good Luck.
Posted on Mar 04, 2008
TV wont power on. Upon starting green light on front of display switches to flashing red. I have already unplugged power and tried again
This should be an error code 14. Most of the Philips TVs with this code means the Audio is the problem.
The Audio board maybe shorted out causing the TV to go into "Protection Mode". I would try unplugging the Audio board from the main power supply board and main mother board to see if the TV powers up without going into Protection Mode. That should give an answer if the Audio board is bad or not.
Apr 01, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
42PFL5332D/37 does not turn on red light flashes 6 times.
Don't have a "solution" yet, but found this table that decodes the blinks:
Error Code Table
0 = No error
1 = X-ray protection, E/W protection, and/or Vertical protection active
2 = High beam current protection active
3 = Reserved
4 = +5V protection active
5 = Signal Processor (IC 7150) register corrupted
6 = Signal Processor (IC 7150) error
7 = Total failure
8 = Internal RAM error (Microprocessor IC 7000)
10 = NV memory (IC7088) addressing error
11 = NV memory (IC7088) size error
12 = Histogram (YUV) (IC 7770) error
14 = Sound processor I²C error (TDA9855)
16 = Main Tuner I²C error (IC 1125)
17 = PIP Processor I²C error (IC 7350)
18 = PIP Tuner I²C error (IC 1127)
I, too, have the 6 blinks of a red light. I found another person online that suggested that perhaps the power cord was "defective" as it's a common issue. I replaced the power cord with one from an old computer (they're the same cord) and it seems to be OK now. That's all I can offer you at this time.
Jan 20, 2010 | Philips 42PF7320A 42 in. Plasma HDTV
My philips tv flat screen keeps shutting off and a red flashing code starts blinking?
Not sure what code since you didn't say, but here is the code breakdown.
When the TV does this, the RED LED on the front will blink. For digits 1-10 it will blink pause then repeat. For numbers with 2 digits it will blink the first digit slow and then second digit fast. So 25 would be 2 slow blinks followed by 5 fast blinks.
Error Description Error/Prot Detected by Device Defective module Result
1 I2C1
2 I2C2
3 I2C3
4 I2C4
5 VIPER
6 5V supply
7 8V6 supply
8 1.2V DC/DC
11 3.3V DC/DC
12 12V supply
14 Supply Class D amplifiers
14 Supply Audio part SSB
17 MPIF1 audio supply
18 MPIF1 ref freq
25 Supply fault
27 Phoenix
28 MOP
29 AVIP1
31 AVIP2
32 MPIF1
34 Tuner1
37 Channel decoder
39 POD Interface
43 Hi Rate Front End
44 Main NVM
45 Columbus
53 VIPER
63 PDP Display
Dec 27, 2009 | Philips 50PF7320A 50 in. Plasma HDTV
Flasing red light where the on light is
I have a philips pf50 9630a/37 tv may come on or it may not unplug it and take a chance then comes the 6 steady red flashes followed by 3 rapid red flashes the screen had been completely replaced by philips a year and a half ago
Mar 22, 2009 | Philips 50PF7321D 50 in. Plasma HDTV
Blinking Red Lights
Sound like an error code 14 (Audio supply) is beeing blinked...
You probably would want a qualified technician to take a look at it.
Jan 16, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
No picture on tv. model 42pf5321d/37. red light flashing on lower right. flashes 4xx see Morgan ref. 719nt
Purchased new Pansonic TV,, old one [2 years] was not projection tv. In for repair for kids.
Oct 07, 2008 | Philips Televison & Video
Philips 37PF7320A/37 won't turn on
That blinking led is an error code for the audio standby board in the set. It should not go out this soon and yes it should last longer.
Aug 21, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Blinking red lights
If your TV is less then a year old, i would suggest to call the vendor or manufacturer to have the LCD repair under warranty. Most electronics devices carry one year warranty.
The failure of your LCD is not related to any fuse since you're still getting some lights from it.
Good Luck.
Jul 09, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Red light flashing on tv
My 37" TV Will not yurn on . The green light goes on for 2 seconds then goes off and red light starts flashing. What Repair/Part is needed.
Aug 31, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
Electro Med Services...
