Question about Toshiba 55H70 55" Rear Projection Television
Color convergence out on rc 52 inch projection tv
My tv convergence is out of wack and when i got hru menu the convregaece adjust is gone, it use to be there I have used it. My tv is 2 years old and have no idea where to find the convergence board in the back it open and have no idea what Im looking at.
thanks
  • 1 more comment
  • wpwd Mar 04, 2008
    My tv is not a tosh. it is an rca 52 inch projection
  • wpwd Mar 04, 2008
    is that a machine that hatches chickens? lol so are yuo saying that I need a repairman to fix it. I have had the tv for 2 years payed 1000.00 for it and will not spend more than a couple hundred on repairs my wife and i are not very pleased with the tv and would just cut our loses if it is too expensive.
    thanks
  • seesaw996 Nov 01, 2008
    I have a 52 inch RCA where I KNOW for a fact the convergence option was there at one time and now it's just gone! what are my options? Is it something we can fix ourselves? I have read other solutions and it has been mentioned of a fuse? My TV is also 2 years old actually Feb of 06 made, everything else is just fine. Thank you for any possible solutions...........
If it is way out, it is more that an adjustment. It takes a crosshatch generator to do the convergence.
Electrode
Posted on Mar 04, 2008
Screen looks bent and color is out of line
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 15, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Horizontally the picture is distorted (doubled). Sound is ok. we have a 52 inch RCA big screen tv.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
  • Screen looks 3D
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Feb 21, 2010 | RCA P52926 52" Rear Projection Television
Color convergence out of wack
A professional tv technician can realign convergence or you can try to manually realign it yourself via little knobs under one of the tvs panels near the lamps.
Jun 27, 2009 | RCA P52926 52" Rear Projection Television
I have a 52 inch rca dlp hdtv. the color is out of allign and the tvs menu convergence adjustments isnt gooe enough, how do i enter the advanced convergence settings. my S/N is D52W23WX32F445C1002. thank...
Turn off your TV. Hold down the Channel Down and Volume Down buttons on the front of the TV. Hold for 8 seconds. The set will boot into the service menu.
I just fixed my convergence issue with this, no parts.
Jun 15, 2009 | RCA HD50LPW175 50" HDTV
52 inch rca shows picture in 3 colors will not focus
is thr convergence adjustment option still listed in the on screen menu? Let me know and I will try to assist you.
Jan 22, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
My colors all of a sudden went out of wack
Is there an advanced convergence setup anywhere in the menu where the screen displays a grid? If so, you might want to get into that and move along the grid to each section that looks off. Adjust until the color falls behind the gridline, and move on to the next. It can be a time-consuming process, but should take care of your convergence issues.
Jan 20, 2009 | Toshiba 55H70 55" Rear Projection...
Rca 52 inch convergence
You have a opened fuse FL231 next to flyback transfomer are 3 Fuses they look like small brown squares/ Fuse in the middle is bad when you do not have convergence listed in menu.You can pull the top off of these fuses .
Nov 06, 2008 | RCA P52960 52" Rear Projection Television
RCA 52 INCH CONVERGENCE PROBLEM HELP/already replaced the fl231 fuse
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 01, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
C Color is way outta wack on my 56 inch pilips rear proj tv. HELP
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Oct 28, 2007 | Philips 60PP9352 60" Rear Projection...
Rca 52' projection convergence problem
Its a good possibility that your convergence problem could for now be cold solder connections on the driver ICs on the convergence board. The longer you use it the more of a problem its going to surge those ICs till they go bad and maybe cause other componet falure as well. If your not a technician i would have this set serviced asap before it becomes a major repair Good Luck
May 22, 2006 | RCA P52926 52" Rear Projection Television
Toshiba 55H70 55" Rear Projection Television Logo
270 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
