Question about Sony PlayStation Portable (PSP) Console
Sound problem well when i plugg in my head phones to my psp only one ear plugg work the other doesnt make any sound but they both work when i plugg them into another device. anyway i can fix that.
  • 3 Answers
In order to fix this setting you have to download a video to your psp
1. go to your video on your psp then open it
2.then press ''triangle button '' on your psp
3. browse and you should see ''audio options;
4. then press ''O'' button on psp you shoul see ''left+right'' at left lower corner on your psp
so easy..have fun
or much easy way
when listening to mp3 on your psp try pressing the button beside the left side of ''select button '' on your psp
by;marziano
Posted on Mar 06, 2008
Jvc gumy ear bud headphones purple
When you pull the wire up does it increase the right ear bud volume/ sound? If it does, then it means the right side ear bud has a short within the head phones circuit which is aka the wire that leads to the musical device in which the ear buds branch off from.
If the right side ear bud does not produce an increased volume for sound by picking the wire up or pulling it in towards you or to the left side of your body or musical device then it means that the right speaker is blown.
I know that all head phones come spiced together aka they are stuck together and have to be pulled apart in order to get both head phones seperated from each other so that they can be worn in the ears. If you pulled the wire apart to much or too quickly then that is what ruined the right head phone.
I suggest that regardless if the ear phones begin to work by pulling the wire up,side ways, or into towards your body that you return them back to the store since after awhile the problem will eventually continue to happen causing the right ear bud to completely blow. Once you return the ear phones be cautious with the new set when you seperate the ear buds from each other since they are very touchy and have to be handled with delicateness when seperation is taking place.
Please let me know how it works out for you. I have had many ear buds and I tell ya something; they are very easy to blow one side when seperating. I had to learn after a few pairs that I was ruining the speakers by the way I was seperating my wires. I kept thinking for the first 3 pairs that the store was selling blown ear buds until I began having same problems with another few stores so I said to myself "well the solution is to figure out what I am doing wrong in order to blow one side of my ear buds every time". After few seconds it was not that obvious that all I had to do for assembly was to pull the wires apart in order to get both ear buds to go into my ears.
Jan 22, 2014 | JVC Gumy Ear Bud Headphone - Peppermint...
Will not work with turtle beach x11 head set no mic...
take your cell phone ear piece and mic attached cable and clamp the mic part with the clamp that is on the cable to the end of the turtle beach mic piece just before the foam cover with the cell phone mike facting toward you. plug in the cell phone ear piece to your left ear and then put the tuttle beach head set on just a normal. the cell pone ear piece is so small that you will not even know it is there when you cover it with the turtle beach head set. plug in the cable from the cell phone into the port in the rear of your turbo fire two controler and away you go. you can enjoy the great sound of the turtle beach head set and at the same time chat with the cell phone mike. you can adjust the sound level on the head set but you will not be able to adjust the volume on the cell phone mike. but it works fine just place the head set mike boom real close to your mount so your friends can hear you well. I use it in two worlds two in the marshlands while leveling up on x box live. you can find me a DeepReserve which is my game tag.
best,
Jun 28, 2011 | Datel Xbox 360 Turbo Fire 2 Wireless...
Psp 3000 sounds not good in earphone
The PSP 3000 model lowered the wattage to the headphone 3.5mm jack out to reduce battery drainage. The headphones you have are drawing to much power (buds or not).
Another thing that could be affecting your quality is the connection inside the port could be dusty. I would suggest taking a que-tip and adding a little windex to it and polish out the port then try your luck.
If that doesnt work swap out head-phones
May 09, 2011 | GPS
Left ear doesnt give out sound
there are two reasons for which your left ear head phone is not working:
1.If the insulation between the wires(copper leads inside the cord) fails....the two leads gets short circuited and it will stop working...OR some times the cord ll be looking good but inside one of the leads got cut then one of the headphones fails...
the solution for the above problem is dont wrap the cord...this ll lead to cut or insulation failure....
2.the speaker in the left head phone got failed...
dont forget to rate me...
good luck...
Apr 15, 2010 | Bose Around-Ear Headphones - Silver
No sound from speakers
insert the ear/head phone in backpanel sound pin (Green color),
1.if You can hear the sound in ear/Head phone,then the problem is in the speaker.replace the speakers
2.if You can't hear the sound in ear/Head phone,then the problem is in your system audio driver.So Down load the audio driver which is suitable for your system and install it.
Feb 13, 2010 | Insignia 2.0 Speaker System (2-Piece)
No Audio
Ear phone may be faulty..... Can you hear the sound from the speakers of PSP when you play music/games/Video
Nov 10, 2008 | Video Game Consoles & Games
Sound not working
i guess u need a new internal speaker to prove that try use the phones
Aug 25, 2008 | Sony PlayStation Portable (PSP) Console
Please help
it sound like the ear socket has developed an intermittant connection problem. It could just have a dry joint where it needs to be resoldered, however, if you dont have the correct tools to fix tghe unit it might be best to leave it in to a repair shop.
Good Luck!
x-b-m
Mar 04, 2008 | Sony PlayStation Portable (PSP) Console
My psp sound has gone
The jack where the ear piece enters gets partial contact try and get standard ear piece cause you cud damage the sound unit if you keep feeding it partial current
Sep 30, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
106 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
