Question about Aurora Global AS1502X Shredder
How do you reset the damn thing?
It stopped working. It did this about 3 years ago and I had to reset it but I don't remember the procedure to reset. Something about unplugging it then plug it in then turn it on wait 5 minutes then put a thick piece of card stock in and wait 3 minutes. Turn in circles while you wait rub your belly and pat your head. I just don't remember the order.
sfairfield@cwc.edu
  • 8 more comments
  • UsmcUS Mar 06, 2008
    I cannot find the manufacurer for Aurora and yes I have been trying to find a manual for it.
    We just purchased a $5 fax for a quick fix for another situation and it didn't come with a manual but I was able to find one within 5 seconds on the internet. It has 63 pages to it which I printed. Do you think I can find a manual for a $250 shredder, no. So if anyone has one or knows where I can go to get one, your assistance would be most appreciated. UsmcUS
  • UsmcUS Mar 18, 2008
    Anyone have an answer yet?
  • UsmcUS Mar 26, 2008
    No lights come on when I plug it in. The trash bin appears to be all the way in. There is no life. USMCUS
    I do not know the proper term so reset may not be the correct word to use. There are no lights on when I plug it in no life whatsoever.
    It doesn't run at all. Not in reverse nothing no lights on no life in it.
    Thanks.
    AS1502X
    Thank you. I am waiting for a reply from the company.
    I have tried another outlet which wouldn't matter because the pencil sharpner is in the same outlet and works fine (but I did try a different outlet and nothing). I cannot find a safety switch under the unit. It is on wheels so a button on the bottom does not make sense unless the wheels sense something and I don't think it's that complicated plus I have looked all over the bottom for a switch and nothing. The only switch I can find is when I remove the trash bin it has an edge that fits in a slot when it is put back in place it depresses a red button. Hard to tell if that is working with the bin and the other part of the machine in the way. I work with several engineers and I will see if they have time to look at it. Thanks anyway. USmcUS
    I just spoke with an aurora rep who had me press the red switch inside the unit and press reverse. It didn't work so she said the motor is burned up so I'm SOL. Thanks anyway. I appreciate all the work. Semper Fi USMCUS
  • 19,396 Answers
Again, here is the only online manual provided from Aurora for 1540. It is similar to 1500 manual already published, unfortunately it is just a bit more than a factsheet.
The one you described, more than a reset procedure seems a procedure to unlock the shredder. The only reset procedure I know for this device is leaving it unplugged for 30 minutes, the rest must have been needed to unlock it, in case one of the sensors/switches is stuck.
For example If your shredder run only in reverse mode but not in auto do the following:
A. In "Auto" mode, the motor will not start running until paper is inserted into the paper slot.
1. Switch to "Auto" mode and insert paper into the middle of the shredder.
B. The sensor that activates the shredder in "Auto" mode is located directly in the center of the paper slot. If the paper you are inserting is too narrow, it may not be activating the sensor.
1. Insert paper into the middle of the slot.
C . The sensor which activates the shredder may have become blocked with paper.
1. Insert an index card (or something similar such as a postcard or greeting card), directly into the center of the paper slot. Apply force. This will usually clear any paper blocking the sensor or force it closed.
This from aurora troubleshooting
If your shredder does not turn on at all it is unlikely you can apply a reset procedure. If you give us more details on the fault on your shredder (eg runs only in rev etc. and eventually which error light is on if any) we can troubleshoot the problem.
Check also the internal switch , a small piece of paper stuck inside a switch can prevent if from working.
regards
Posted on Mar 25, 2008
    Master:
  • 788 Answers
Does it have a pull-out waste basket? Did you look at the waste-basket full switch?
  • 5 more comments
  • Dean Joly
    Dean Joly Mar 25, 2008
    Here is some troubleshooting steps for Aurora shredders: http://www.auroracorp.com/troubleshootin...
    Go through all the steps on this page and try again.
  • Dean Joly
    Especially check the safety switch under the unit, it should be pressed in by the waste basket.
  • Dean Joly
    The manual for the AS1500CD is here: http://www.auroracorp.com/images/product...
    Should be quite close to your model.
  • Dean Joly
    The North American contact info for Aurora is here: http://www.auroraglobal.com/ACA/EN/pnew2...
  • Dean Joly
    After extensive digging I have determined that the AS1502X model has been discontinued and removed from the Aurora sites.
  • Dean Joly
    Dean Joly Mar 26, 2008
    If no lights come on at all then there as most likely an electronic fault in the unit. Check the outlet, try it in a different room??? Otherwise, something is faulty inside. Open the housing and look at the circuit, it should be fairly simply, look for something that looks burnt or loose.
    Are you sure the safety switch under the unit is getting depressed by the trash bin. Try holding the switch with your hand to see if life comes back to the machine.
  • Dean Joly
    Dean Joly Mar 27, 2008
    After you said yesterday that there were no lights on it, I suspected that something was burnt.
  • 871 Answers
Yup! IB4G2008, coolguy008, micromaster are right...
the only thing you can do is contact the manufacturer and hope that they will reply ASAP to your query.
done my searching as well and to no avail.
follow the contact #s posted by coolguy008.
thanks for using fixya
    Genius:
  • 3,587 Answers
Maker is Aurora Global, yet another of the Chinese dragons. I went to their site, and that model number appears to be close, but no cigar..please confirm model number, ...
  • 1 more comment
  • Patrick Michaels
    Patrick Michaels Mar 25, 2008
    see my email, cc'd to you, to the director of US operations.
  • Patrick Michaels
    Patrick Michaels Mar 26, 2008
    yo..
    Ginko..the manual dude..scores another victory, and chips away at my sizable lead..
  • Patrick Michaels
    Patrick Michaels Mar 27, 2008
    so, now USMC guy. It's time to muster up the kudos for the expert you believe did KP for your deal..
    Genius:
  • 3,422 Answers
HI,
Since the manual is not available online the only solution is to email the company and get it .Here are the contact details:
Main support number - 86-21-5916-4588 ext.472
Support FAX - 86-21-5990-3429
Email - supportcher@aurora.com.cn
Goodluck,
Please don't forget to rate the solution.
    Brigadier General:
  • 3,614 Answers
Do you need a manual for that?
Posted on Mar 06, 2008
  • micromaster
    micromaster Mar 06, 2008
    You may have to contact manufacturer for more info.
  • micromaster
    Ok, wait i'll try to look for it. As pf now there's no manual available online.
Ft-950 I somehow made the red tx light start flashing.It did this 2 years ago,how do I make it stop? I already did the resets.I do not remember how I stoped it 2 years ago. can tou help?
If a "reset didn't do it, you'll need to contact Yaesu tech support - they're very helpful (but best not to call early Monday or late Friday).
Sep 15, 2013 | Yaesu FT-950 Transceiver
Whirlpool dishwasher model# DU915PWSS0 S/N# DE3960705 reset procedure? The problem: dishwasher will not start the only buttons that will light up when I push them are heavy, rinse only, and heated dry. I...
  • Turn off the dishwasher and unplug it from the power supply. Wait 10 minutes and restore power.
  • 3
    Select a "Hi Temp" wash cycle, followed by a heated dry setting on the dishwasher.
  • 4
    Repeat step 3. This will reset the dishwasher.
  • May 11, 2011 | Whirlpool Dishwashers
    Long time ago i bought a Acer aspire 3000, i stop using it about 2 years ago, now that i turn it on again y donde remember de BIOS access code what can i do, i dont care if we need to reset hard drive i...
    reseting the bios password is easy.
    All you need to do is to unscrew the bottompanel and then remove the CMOS battery to reset the password on it.
    Then after that you will be able to access the comptuer again normally.
    Cheers!!
    Sep 10, 2010 | Acer Aspire 3000 Notebook
    My instrument cluster stopped working on my 1997 Plymouth Grand Voyager SE 3.3L. It was working most of the time for the past year but occasionally would not work, but it stopped working completely 4 days...
    mcdevito75 here, There is a specific part undre rhe steering whell that controls the cluster, if you vehicle has this than it"s a shop only repair item. Check with your local shop. I don"t remember the name of this part though but it also controls the horn.
    Jun 16, 2010 | 1997 Plymouth Voyager
    How to you refill the cartridges on epson stylus cx5000 printer
    If you want to use recyled ink you will have problems with any modern ink jet, they build devices to stop such or at least to make it expensive or damaging to your printer, some of the older epson are great but forget modern ones they are fitted with reset chips not just need ink.....so really one cant refill these without it working out easier to just buy the damn expensive makers ones, the game is rigged I tell you, printers these days are made worse than 10 year ago, give me the old stuff any day..today we throw em!
    Nov 07, 2009 | Epson Stylus CX5000 InkJet Photo Printer
    Reset my RadioShack Wireless Security System Console 49-1000MC
    Hey, Mine did the same thing, this is what I did. I entered "0000" for the pin and was able to reset the unit (0000 is the factory default) It may not work for you, but it's worth a try.
    Aug 06, 2009 | GE Security Simon 3 Wireless Home Security...
    Nashuatec P7132N "Replace printer cartridge" after refill
    Greetings
    I want to see what types of inks used for the printer nashuatec P7132n
    Thankful for your cooperation
    Ashraf Dora
    as_dora72@yahoo.com
    May 08, 2009 | Office Equipment & Supplies
    D-link Di-524 invisible to my new laptop
    Just reset the damn thing. It's been 3 years. All kinds of **** can go wrong.
    username is admin, and the password is blank
    Jan 06, 2009 | D-Link AirPlus DI-524 Wireless Router
    Reset air conditioner
    Unplug it. Wait a few minutes. Hold in the Power button while plugging it back in and keep the button held down until a beep is heard (~5 sec). Unplug the air conditioner, then plug it in again.
    Note: some units require using the Mode switch, rather than Power.
    Aug 09, 2007 | Sharp AF-S100FX Air Conditioner
    Aurora Global AS1502X Shredder Logo
    437 people viewed this question
    Top Aurora Global Office Equipment & Supplies Experts
    chargerhp
    chargerhp
    Adorjani Laszlo
    ray gallant
    Are you an Aurora Global Office Equipment and Supply Expert? Answer questions, earn points and help others
