Question about Aprilaire 600 Humidifier
Aprilaire 600 bypass water flow rate
I'm researching installation of a humidifer in my home. The Aprilaire 600 specs fit my home but I'm concerned about a note in the literature regarding bypass water to flush the water panel (1 qt/5min or 3 gals/hr).
I don't have a floor drain but use a sump with a pump for furnace discharge. Is the 3 gal/hr only when its in a flush cycle or is it continuous?
Thanks
bob
  • 30 Answers
The water is only dispensing over the evaporator pad while the furnace is in the heating mode. When the furnace finishes cycling the humidifier will also stop.
Posted on Mar 04, 2008
Need to find a replacement drainage line for my Aprilaire 600
You can purchase the tubing at most hardware stores or any HVAC supply store. They carry the vinyl plastic tubing and pvc pipe for drain lines.
Sep 09, 2012 | Aprilaire Humidifer Automatic Humidifier...
I just moved iinto my new home. I have never owned a home with aprilair 560 unit. I just got it fixed I hope. But I put a new water filter in monday the 27th. How often should you replace it. ...
It is a bypass humidifer the pad in it should last a couple of years, the water runs over the pad and air pulls moisture off the pad. Putting it into the home. Make sure the damper is open for proper air flow.
Dec 30, 2010 | Aprilaire 550 Humidifier
Aprilaire 550 clunks on shut off. Never did this before. Changed the saddle valve and Solenoid. Checked copper water line for possible vibration on a pipe, nothing. I'm stumped
Thank you for contacting us regarding the "clunk" sound you are experiencing with your Aprilaire 550. The noise you have described is called water hammer. Water hammer is a pressure surge or wave resulting when a fluid in motion is forced to stop or change direction suddenly. Water hammer occurs when the solenoid valve closes at the end of a humidification call. To prevent the sound of water hammer, we recommend contacting your heating & cooling contractor to install a "shock arrestor" part number 4280. This device is installed between the water pipe and the solenoid valve and will absorb the shock and stop the banging. Please contact your heating & cooling contractor or our Customer Service Department if you have further questions. Kind Regards, Jessica Garrett Customer Service Specialist Research Products Corporation
ww.aprilaire.com
Oct 30, 2010 | Aprilaire Humidifiers
Testing a Aprilaire Humidifier 600 Controller
if it works in the test mode then it should be okay but you can get a humidity gauge from radio shack and set in the house to see how high or low its is. the humidifier is only going to give a max of 45% humidity
Nov 27, 2009 | Aprilaire 600 Humidifier
Airconditioning is making baby cough and nose run would a humidifer help? will a humidifer make the room hot?
You may need a HRV/ERV installed. Depends on your indoor air quality(IAQ). It may be allergies. I would talk to a reputable heating/cooling contractor in your area to evaluate your system, recommendations.
Nov 21, 2009 | Aprilaire 600 Humidifier
Aprilaire 600: water only runs in "Emergency" Heat mode
When your unit is on normal the outside unit works and the inside only the fan runs. your heat pump does not remove any humidity when it operates so the installation cotractor did not wire it to operate then. you can change the wiring on the humidifier to operate all the time by wiring it to the fan (g) terminal then it should work just turn it all the way to the lowest humidity when you are in cooling mode.
Jan 07, 2009 | Aprilaire 600 Humidifier
Orifice clogs to Aprilaire 600
http://www.aprilaire.com/themes/aa/en/manuals/600a.pdf look at page thirteen in this manual there is allready a inline filter on the unit. hope this helps
Jan 06, 2009 | Aprilaire 600 Humidifier
Turning on the humidifier shuts off the furnace
It is possible you may have wired it wrong. Make sure your humidifer is not robbing power from your thermostat. This would explain when your humidifer makes a demand to come on it robs power from your t-stat making it lose its call for heat. Wire your humidistat to the "w" terminal and the common terminal so it only runs on a call for heat. With the bypass type of humidifier you purchased it wont do you any good to run when the heat isn't running anyway. If you want an independent operation humidifier you need a steam type.
Dec 02, 2008 | Aprilaire 600 Humidifier
Aprilaire 600 Humidifier Logo
394 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
jdthefixer
Mack Baxter
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
