Question about Maytag Atlantis MAV6451 Top Load Washer
Maytag MAV1634AWW won't drain in permanent press modes
When I run a load in permanent press mode, either with the timer dial or wash/speed cycle, it will not drain. If it is in white mode,fast, regular it works fine. Any suggestions appreciated.
  • Michael VanAmeyden Mar 14, 2008
    Had repairman out and found the plate that engages my motor was rusted not allowing correct tension on the belt. Hope this helps
  • Anonymous Jan 17, 2009
    Washer will not drain completely in main wash of Permanent Press cycle. It drains fine but then abruptly stops with about 6 inches of water remaining. Then it begins adding water for the rinse. It does empty completely after final rinse.
    It drains perfectly in Regular cycle. Haven't tested in Delicate.
    I don't know exactly which model this is, but it is a top loader about 15 years old labeled Heavy Duty 2 Speed Super Capacity
  • 1122 Answers
SOURCE: I have a maytag washer-n-dryer(stacked).
it sounds like your water inlet valve is bad,change it,also try your washer on another water level like small load or med load and see if it cuts off,it might also be your water level switch,hope this helps,thanks-mike
Posted on Jun 02, 2008
SOURCE: Whirlpool Two Speed Automatic Top
Thought the timer was at fault,however wasn`t fully convinced is was as the problem happened on all the other wash cycles.
This led me to checking the lid switch.Metering the wiring to it indicated the switch was not working.
After removing this lid switch, I noticed the plastic casing was coming slightly apart.So do not rely on `` the clicking sound``[ when opening and closing the lid] to indicate the switck is OK.
This casing is bound to fail with time and lid use and abuse [ held together at 3 points with very small plastic clipping points which fail, resulting with an internal spring pushing the casing apart so that you still get the ``clicking sound`` but the contacts not working] .
My solution was to use a plastic cable tie to pull the switch casing together and ``bing``the switch is working and the washer is back in service [ No need to buy a new switch ].
Posted on Jul 18, 2008
  • 18 Answers
SOURCE: Maytag Washer Getting stuckon wash cycle
the possibility of it being the timer is most likely..as the rest of the cycles remain ok.. if you require a timer,you can get one here at this link..(click the link here) http://www.easyapplianceparts.com/AdvancedModelSearch.aspx?ModelNum=HAV4657EWW&mfgModelNum=&fkMfgID=1
please be aware that you will need the machine serial number in order for them to issue you with the correct part/s you will require.. parts are cross referenced with the serial number.
these diagrams will also enlarge in order for you to maintain your machine by yourself at little but the cost of the parts required... but please DO NOT ATTEMPT ANY REPAIR YOURSELF if you think you may not have the technical know how to follow these technical drawings..hope this helps
Posted on Dec 27, 2008
appldoctom
  • 311 Answers
SOURCE: Maytag Washing Machine Cycles Out of Sync with Dial
ive fixed lots off washers over the years[15,000 service calls] and was careful while taking parts off if i wasn't fulmilure with that model,but most timers and knobs have a key way so the knob can only go on one way.if thats not true for you, try this.turn the timer shaft till the washer is at the end of the wash cycle.[finished the load,it would be the final spin ,maybe five minutes long.when thats done the timer advances to off]now knowing that thats an off position set on your knob and then manuly turn it to the off position of the next cycle if it wont run you did it. if not you will have to go to the end of that cycle and remove knob and set to next notch in the knob,until you find the sweet spot.hope this helps God bless,tom
Posted on Feb 27, 2009
  • 6 Answers
SOURCE: Kenmore 70 series 110 washer won't drain or spin, but agitates
You have a broken lid switch. Check to see if the switch is broken off of the two screws that hold it under the lid. If it is, get a new one, take off the case and replace old switch with the new one.
Posted on May 09, 2009
Why doesn't my Maytag washer go into spin cycle?
I would start with the timer module. The spin cycle requires a lot of current (amps) to move the mechanism and load. That current can cause contacts inside the timer to become carboned due to current arching. Try this: wash using a different cycle (permanent press for example). If the spin cycle works in that mode, then there is a 99.999% chance that the contacts are worn out on the regular cycle (if that's what you're using). Lacking a model number, I assume you are using one that has the mechanical timer. Try that and come back.
Dec 16, 2013 | Washing Machines
Kenmore front loader stops/freezes in pump out mode just before final spin
For a detailed Washing Machine illustration, click below.
redarrow.gif Top Load Maytag Style
redarrow.gif Top Load Whirlpool Style
redarrow.gif Top Load GE Style
redarrow.gif Front Load Maytag Style
redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Some problems that can occur with your top-loading washing machine are:
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
Aug 01, 2008 | Frigidaire GLTF2940ES Front Load Washer
Maytag stacked unit LSE7806ACE. dryer is fine , the washer will not fill or run, if I manually turn the timer to drain the tub spins and the lid switch works fine. But the unit won't do anything f
You have a timer problem, the contacts are welded in spin mode.
This is almost always caused by advancing the timer by hand when the dial is pulled out in the "ON" position, causing arcing of the contacts.
Sep 22, 2017 | Maytag LSE7806A Top Load Stacked...
Kenmore 80 series top load washer. In the permanent press mode the machine will stop when it moves to the rinse mode. I can manually move the time past the midpoint of the cycle it will run for a minute...
So it will spin and drain when put in the spin cycle right? More than likely it is your timer if you have to keep manually setting. I would check on timer prices and go from there.
Dec 28, 2010 | Kenmore Washing Machines
I have a Maytag Neptune TL. The machine is working normally except it's not able to fully extract the water out of the clothes. When the full cycle is complete the clothes are still dripping wet. I have a...
We are talking about FAV6800A or FAV9800A TL correct?
If so you need these links the Service Manual and parts look up; here is the Service Manual for reference. Sears Parts Direct for reference.
If your machine completes the wash cycle with no error code such as ND (No Drain) and there is no visible water in the bottom of the wash basket when you remove your wash load then I would do this test.
Take the next wet wash load that is dripping wet and lets do a Quick Spin Test in Service Mode. During this test test the FAV6800A LED display model will step thru the RPM (revolutions per minute) or goal is to ensure the machine will spin the wash basket up through all Spin Cycle RPM ranges. Any RPM range above 99RPM’s will be shown with a (.) dot after the two numbers displayed i.e. 350RPM will show as 35. 550RPM will shoe 55. And so on.
I’m and owner of the FAV6800A and I’m not sure what the LCD display of the FAV9800A will display.
Enter into Service Mode;
Page 14 of the Service Manual; below I have cut and paste the instructions.
Enter / Exit Service Mode
To enter Service Mode press the Enviro Plus and Spin Only keys (simultaneously) for three seconds or until the control beeps.
Now go to page 14 and enter this front panel key pad press to start a Quick Spin Test and see if the machine with that wet clothes load will spin the wash basket to 850RPM.
Quick Spin Test
While in Service Mode, press the Hand Wash
key to start a Quick Spin Test.
Quick Spin test steps are as follows:
1) Lock the lid.
2) Spin to index speed 90 rpm and hold for 60
seconds. Pump drains machine.
3) Spin to index speed 150 rpm and hold for 6
seconds.
4) Spin to index speed 350 rpm and hold for 6 seconds.
5) Spin to index speed 550 rpm and hold for 6 seconds.
6) Spin to index speed 700 rpm and hold for 6 seconds.
7) Spin to index speed 850 rpm and hold for 6 seconds.
Pump out.
8) Coast down to 0 rpm chimes 3 times.
Hit the Off button to get out of service mode.
If the machine spins the wash basket to 850 RPM then we need to start looking further. What are your results?
You can check the flow rate of the drain system by again entering Service Mode and turn the Drain Pump on in service mode. I would (hand fill) place 5 gallons of water in the machine and turn on the drain pump see page 16 for Board Output Test.
Enter Service Mode and press the Delicates key. You are now in Board Output Test now press the Presoak key and the Drain Pump will turn on. If your machine pumps out the 5 gallons of water in 60 seconds or less I would say your Sump Cap, drain line connection from Sump Cap to input to the Drain Pump, Drain Pump and discharge line are all working as designed. If the Machine takes greater then 60 seconds to dump the water then you need to start troubleshooting for a drain line restriction or Drain Pump issue…...Rich
Apr 05, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Fabric softener cup on Maytag Neptune washer is full of fabric softener after the cycle. Checked valves in output mode. Both the main and the bleach valve turn on and dispense water, but no water dispenses...
Hi. your problem is actually a rather complicated one.
Timer and selector switches The timer switch is usually the largest dial on the main control panel. It can be either a mechanical device much like a simple clock, or completely electronic with just a digital readout.
The timer runs the washing machine in a pre-determined pattern. It provides the electricity to all of the washing machine components at the correct time and for the correct length of time.
The Start switch is usually part of the timer knob. When you set the timer to the proper cycle, you either pull or push the timer knob to start the cycle.
The selector switches or knobs vary from machine to machine. Most washing machines have one or several switches or knobs on the control panel besides the Timer/Start switch. These let you adjust certain settings; for example, the water temperature, spin speed, timer cycle, and so on. Normally, the washing machine completes the cycle selected on the timer, regardless of how you set these switches and knobs.
Jul 14, 2009 | Maytag MAH2400A Front Load Washer
Kenmore Washer timer dial is not advancing
ok " timer has a small stepper motor in it, and it can be replaced
take stepper motor out .
appliance parts store will have it
or just replace timer
take make and model number with you
Jan 13, 2008 | Washing Machines
Maytag Atlantis MAV6451 Top Load Washer Logo
171 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
