Question about Konica Minolta Magicolor 2450 Printer
OPC Drum Msg reading OPC Drum out - anyone know what this means???
OPC is organic photo conductor. Not sure what that means but apparently we need it to be able to print stuff. Yours has run out and you need to buy a new one. Should be about £100 apparently. But I'm having trouble finding anywhere that sells them, most people just seem to sell toner cartridges. The part number is 1710591-001 if that helps. Unfortunately I haven't worked out how to fit it either. Sorry. Good luck! (I hate this printer...)
Posted on Mar 17, 2008
1020 drum laserjet
The OPC drum is contained inside the toner cartridge.. just buy a new toner cartridge! OPC stands for (Organic Photo Conductor) and its part of the toner cartridge.. Buy a new cartridge HP order number is Q2612X or aftermarket
Feb 04, 2014 | HP LaserJet 1020 Printer
I have an Konica Minolta Bizhub c250. for the last week now the prints and copies are so light I can't read them. I have replaced the toner. I would liek to know if this would be caused by the drum or...
This can be the problem of imaging unit, you have replaced the toner still print is light this means you need to replace its opc drum.Most probably its K.Replace it with the new on.Print will be fine.
Mar 21, 2011 | Konica Minolta bizhub C250 All-In-One...
Nashua tech err cod SC 320
Basically, the code means that the Primary Charge cora is not charging the OPC drum correctly. You may have a bad or dirty corona unit or a old or damage OPC drum or a bad power supply.
Jan 03, 2011 | Ricoh Office Equipment & Supplies
I have a problem in canon IR1210, Machine scan but not print the matter, output black page.please asst me
your OPC is not installed correctly......
reinstall the OPC drum properly; when copies goes out black, that mean no Hight voltage have been reached the DRUM.
Oct 29, 2010 | Canon imageRUNNER 1310 Copier
Lines in paper. New toner, adjust darkness but still light. Needs service
yes, it need to be replaced the opc drum, opc drum cleaning blade and the developer, or just the opc drum and cleaning blade for the opc drum. Best turn out is to be done a regular PM service on the machine and to be replaced the opc drum and the opc drum cleaning blade.
Dec 22, 2009 | Savin 2545DP Black and White Copier
Ar405 error code f2-31. how do i solve this problem I have the same issue, anyone have a "fix" it cam up right after we changed the toner Same problem, code F2-31 popped up after adding toner. I looked up...
Content Process control trouble (OPC drum
surface reflection rate abnormality)
Detail Usually the sensor gain is adjusted so
that the output is a certain value, by
reading the drum base surface with the
image density sensor before starting
process control.
However, a certain output is not obtained
by adjusting the sensor gain.
Cause Image density sensor defective
Check Check process control sensor output with
SIM44-2. (Do not adjust)
and
remedy If the result is far different from the
specified value, it suggests the sensor is
defective. Check the sensor and harness.
If the deviation is relatively small, check
the sensor and drum surface for
contamination.
Jun 02, 2009 | Sharp AR-405 Printer
What is error pc
The PhotoConductor unit.You need change the OPC drum or a new cartridge.
Mar 05, 2009 | Office Equipment & Supplies
To change opc drum in konica minolta
To Change OPC DRUM UNIT in KONICA MINOLTA 2300 w
Switch Printer Off
Open Front Door Cover
Remove Waste Toner Box
Lift Transfer Belts Blue Knob until it's placed at 11 o'clock. (it's directly behind the waste toner box)
The OPC DRUM UNIT is directly under the BLUE KNOB
SQUEEZE HANDLE and PULL OUT the OPC UNIT
Be VERY CAREFUL NOT TO SCRATCH THE GREEN COLOURED ROLLER on the OPC DRUM UNIT.
Replace new OPC DRUM and turn BLUE KNOB of TRANSFER BELT back to 7 o'clock position
Replace Waste Toner Box, Close Front Cover and Switch On.
Status Display will show OPC Drum at 100%
(You can also replace the fuse in the OPC DRUM UNIT and save yourself HUNDREDS on a new one)
I posted this on another solve problem previously, worth looking at.
Jan 06, 2009 | Minolta magicolor 2300W Laser Printer
How to clean scratch on OPC Drum
you cannot take the scratches off the drum---sorry!
Sep 27, 2008 | Canon CLC 1120 Color Copier
OPC Drum Error
Replacing the fuse is only half the job. You also need to empty all the spent toner out of the drum as well. I actually drilled a 1/4 inch hole, poured out all the purple toner, and covered the hole with an old 5 1/4 floppy write protect tab. Any good piece of heat resistant tape should do. Then replace the fuse. Make sure that the contacts the fuse rests on are clean as well.
Aug 23, 2008 | Konica Minolta magicolor 2400 Laser...
Konica Minolta Magicolor 2450 Printer Logo
469 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
