Question about Refrigerators
Kenmore Refrigerator My refrigerator model# 106. 9550751 serial # SF5146680 Right now it is set on highest cool point. When it runs, it is fine it makes ice and everything is very cold, but when the fan turns off, it doesnot turns back on quickly. It takes maybe 8-10 hrs. we have to take all the remaining ice out from the ice basket and then it turns on. please advice
  • kanai Mar 04, 2008
    But when the fan is on and fridge is cold everything is fine. Its just when it starts to melt and everything is warm, I have to take out the remaining ice and then the fan kicks on. Why does it takes 8-10 hrs to start the fan again after doing all the above steps. Please advise on that.
    Scholar:
  • 54 Answers
I'm guessing that ice is obstructing the spinning blade, you might try running it at a more moderate temp first and be sure your door seal is secure and closing completely, its also likely if ice is obstructing that it has over heated the fan several times and the blade is loose on the shaft and not circulating air effectively, you might be able to only replace the blade but if your going in you might as well do it right and replace the fractional hp motor as well.
Good Luck.
Posted on Mar 04, 2008
  • Wes Rackley Mar 04, 2008
    Well it could be a few things but most likely is that there is a defrost termination circuit that has to prove for the fan that there is no ice on the evaporator coil before it comes back on to prevent the circulation of uncooled air, this circuit could be satisfied by either a rise in temperature or pressure. Regardless the root problem is still the same you are generating to much ice on the evaporator.
What is the coldest setting for a kenmore refridgerator
If your refrigerator section is not cold enough at the normal setting you may have a problem.
If you can't find enough information at the link below resubmit your question and include the model number. It should be inside the refrigerator section. It's usually on the upper right wall.
refrigerator not cooling but freezer is fine YouTube
kenmore refrigerator not cooling YouTube
Sep 07, 2014 | Refrigerators
We have a GE GTS 222C top freezer refrigerator, approx. 8 years old. The freezer works fine but the frig doesn't cool and is at the highest setting. We had to turn the electricity off for some wiring...
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 23, 2010 | GE Refrigerators
Freezer side working fine - fridge side simply not cold enough even at highest setting
heatman101
Oct 17, 2010 | Frigidaire FRS3R5EMB Side by Side...
My kenmore fridge 253.53612300 was set on the highest # for cooling and barely worked for about a year now it is freezing everything in the fridge what is going on
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Sep 19, 2010 | Kenmore 53612 / 53614 Side by Side...
My refrigerator is not getting cold even though I have changed the temperature setting to the highest value. The freezer is working fine.
heatman101
Sep 11, 2010 | GE GSH25JFR Side by Side Refrigerator
My refrigerator does not cool properly. The freezer does not have ice built up and the fan is working, I can here it blowing when i open the freezer. The freezer almost works too well, it is at its lowest...
The lowest setting in the freezer compartment may be set to cold holding back cooling to the refrigerator. Try your settings at mid-point on both refrigerator and freezer settings.
Dec 05, 2007 | Kenmore 73503 Stainless Steel Bottom...
Refrigerators Logo
120 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
