Question about Fastora NAS-T4 Hard Drive Array
Reading T4 Device
Is there a way to read a san drive (raid 1) outside the t4 device? (because my fastora t4 has a supply problem and does not start anymore)
thanks
Walter
Did you try to boot the system without all the harddisks inside (keep at least one).
This helped me to bring up the NAS-T4 up again.
Posted on Jul 05, 2008
Which is the right partner of T1? IS THE T7? OR THE T4/ OTHER T2.IS THE T8 OR THE T5?
One needs to know what the voltage and phase(1 or 3) the unit is and what the power supply is.
Apr 12, 2015 | Hobart H600 Stand Mixer
Can't see drives outside of raid
You may not be able to boot you drives outside of a RAID array depending on the RAID type (software/hardware) and configuration (RAID0/1/5). Generally a mirrored RAID1 should be bootable off of the RAID array. If you are using software RAID or a RAID0, you best bet is to update the RAID firmware, and if the data is accessible at all, transfer the data to another storage device.
Jan 24, 2012 | SuperMicro P8SC8 Motherboard
Thermaltake N0001LNU Muse NAS-RAID 4 Bay drivers
Try ths driver solution out, it is the highest satifaction rating on the web. It helped fix most of my driver update issues and I still use it as part of my everyday work tool. It' s very useful and easy. Hope it helps you out.
Dec 02, 2011 | Fastora NAS-T4 Hard Drive Array
I picked up a Fastora NAS-T4, but the previous owner no longer recalls the root password on the device. Is there anyway to reset the device to factory defaults? I see no 'reset' buttons available on it.
Turn off the NAS.
Press AND HOLD power button for about 30 secs.
That will force a hard reset and reset the unit to factory defaults. You will lose all data on drives that are plugged in at the moment. If they are in an ejected state, it may save your data, but I have not tried that.
Oct 15, 2010 | Fastora NAS-T4 Hard Drive Array
I'm looking for a wiring diagram for a diesel VW Transporter T4 1993 automatic as there is a device fitted that advances the fuel injection pump by applying vacuum to a diaphram and thence to the pump,this...
i have a t4 that wont start when i try to sart it all the dash light come on .it turns over but wont start and the side light also come on when i try to start it ??????????????????????????????? help
Nov 01, 2009 | 1993 Volkswagen Eurovan
Vw transporter t4 2.5tdi my speedo jumps
Both Odometer & Fuel gage needs to be replaced, else the potentiometer of both these need to replaced..........sodeep
Jun 20, 2009 | 2005 Volkswagen Microbus
Drivers download toshiba t4/495cme
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/outFrm.jsp?ofId=AskIris&searchString=dynabook&x=0&y=0
Try this link - be careful to match your exact device before downloading any drivers or bios.
May 03, 2009 | Toshiba Computers & Internet
DOES ANYONE KNOW ALLGENERATOR WINDING RESISTANCES ?
5 Ohms at the rotor.
Disconnect all the stator wires and measure each one to ground, it should read opened.
Before disconnecting wires, mark which are hot and which are neutral. Measure between the hot neutral wires and some should read at least 0.5 ohms. You should have T1 and T2 reading 0.5 and T3 and T4 reading 0.5. T1 and T3 should read opened, T1 to T4 should read opened. Also, T2 to T3 should be opened and T2 to T4 opened.
Apr 12, 2009 | Generac Guardian 100 Amp Transfer Switch...
Solaris 9 SPARC doesn't work with Maxoptix T4-2600 disks
You must using solaris format utility to label thies T4-2600 drive. And you must put 512byte/sector MO disk into drive. for example:
1.$ su - root ;Become root user
2. # format ; identified disk
3. choose disk
4. label disk
5. if type unknow please input : type
6. choose T4-2600
7. label
8. modify disk partition
9. newfs ; ex: newfs /dev/dsk/c1t0d0s0
10. mount disk
11. using MO disk like HDD
Mar 26, 2009 | Computers & Internet
My Nas Fastora T4
There's a 9-pin serial connection on the back, can you use that connection to a terminal to see anything? Also, if you don't have access to the manual, visit this link to download the manuals: http://www.fastora.com/product_index.php?doc_name=nas-t4
Oct 22, 2006 | Fastora NAS-T4 Hard Drive Array
Fastora NAS-T4 Hard Drive Array Logo
218 people viewed this question
Top Fastora Computers & Internet Experts
David Payne
David Payne
Are you a Fastora Computer and Internet Expert? Answer questions, earn points and help others
