Question about Samsung HP-R4252 42 in. Plasma HDTV
Color bad I have a 42 hdplasma samsung tv. the other 2 tvs in my house that are hooked to sattlelite colors are fine. My plasma tv only has blue gray and brown colors. No reds or pinks. What could be wrong with my plasma? I already tried to adjust the color and all the other options, it did not help. thank you
  • 103 Answers
You might want to check the component cables to make shure they are firmly seated.
Posted on Mar 05, 2008
I have a 42" Samsung HD Plasma 1080. Started going
Sounds like it may need to be serviced due to component failure which unchecked will get worse, it may be also worth try to reset it back to factory settings in its setup menu this should clear any software issues it may have, but I think its more possible a faulty part or parts which comes down to cost and is it worth it sadly?
Hope this helps.........
Aug 28, 2017 | Samsung PS42B450 42 in. HDTV-Ready Plasma...
Need lg 32lh30 calibration specs
I think I have a solution involving far less effort. Have you tuned your picture settings? Out of the box, the settings are ok and the presets will do the trick for most. But if you're like myself, you want the best picture possible. Here are my settings:
Picture menu:
Aspect ratio: Just Size
Energy Saving: Off
Picture Mode: Expert 2
Backlight: 35
Contrast: 90
Brightness: 54
H Sharpness: 40
V Sharpness: 42
Color: 50
Tint: 0
--Expert control menu
Dynamic contrast: Off
Noise reduction: Off
Gamma: Medium
Black level: Low
Real Cinema: On [grayed out]
Color Standard: HD [grayed out]
Color Gamut: Standard
Edge Enhancer: Off
xvYCC: Auto [grayed out]
OPC: Off
Expert Pattern: Off[grayed out]
Color Filter: Off
White balance: Warm
Method: 10 point IRE
Pattern: Outer
IRE: [see below]
Luminance: 137
-- 10 point IRE calibration
IRE: [Red, Green, Blue results, respectively, for each IRE point]
100 [-8, 1, -40]
90 [-13, -5, -40]
80 [-20, -12, -40]
70 [-17, -14, -33]
60 [-17, -12, -31]
50 [-17, -13, -26]
40 [-13, -12, -19]
30 [-6, -4, -8]
20 [-6, -4, -10]
10 [2, 3, -1]
Color management system
Red color: 2
Red tint: 0
Green color: -1
Green tint: -7
Blue color: 2
Blue tint: 7
Yellow color: 0
Yellow tint: 1
Cyan color: 0
Cyan tint: 0
Magenta color: 0
Magenta tint: -2
These are taken from CNET.com
Nov 08, 2009 | LG 32LH30 32 in. LCD HDTV
Playstation 2 is in black and white
ps2 goes black and white on plasma tvs
Nov 01, 2009 | Sony PlayStation 2 (PS2) Console
Dont know what color to stick where
X-box can be hooked up to component video. This is for better picture quality. Not all tvs have this option. Most newer tvs do. It uses green, red, blue. Those will give you the video. Then a red and a white give you the audio. Just match up the colors.
Apr 08, 2009 | Sony KP-61HS10 61" Rear Projection...
My husband moved the tv from one table to another, and now the color is all screwed up. Mostly purple and green. What's the problem? It's an Hitachi 42" plasma tv.
Usually this is caused by unproperly hooked up component video cables. Check the green, blue and red component video cables on the tv and on the device (cablebox) to hopefully solve the issue. Sometimes one just pulls loose also
Jan 10, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Red in left sie of screen show up sometimes on 42 samsung SP P4251
What component(s) are you connected to this TV?And what type of A/V cables are you using?
Does it only happen when you watch cable or directv or dishnetwork?
solutiondoct
Nov 06, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Color problems
I have the same problem... today I got a digital satelite tech come out and hooked a HD digital reciever to the tv and now I have the greenish/yellowish/blue tint hhhmmmmmmm?
Mar 19, 2008 | Akai PDP4295ED 42 in. EDTV-Ready Plasma...
Samsung Plasma 42 in SP-R4232
How do you have the set hooked up? Component or composite?
Does the menu look red as well when you hit the "Menu" button?
Jan 19, 2008 | Samsung SP-R4232 42 in. Plasma HDTV
Sansui 42" Palsma
I assume you are saying that the DVD player only has RCA jacks. It would be good to know if the DVD player has Component output as that is the preferred output. You will know this if the RCA jacks on the DVD are color coded green, blue and red.... You would by a set of component cables, hook to DVD matching colors and then find the same color code on input of the TV. You must also run the red and white cable from the DVD output to the TV input for audio. The input on the TV would be labled component in or input and a #. Simply select the input, or source button on remote to select the input that matches your choice and all should function. If there is no component on the DVD output and only a composit hook up (color code by yellow, red, white) again just match that to the corresponding input on the TV.
Jan 06, 2008 | Sansui HDPDP4200 42 in. HD-Ready Plasma...
Samsung HP-R4252 42 in. Plasma HDTV Logo
174 people viewed this question
Jerry Greenberg
Jerry Greenberg
