Question about Hitachi 53UWX10B 53" Rear Projection Television
Hitachi 50UX23K blows main fuse when just plugging in coax or anything in back
Whenever I plug in my vcr or dvd player or the cable line into the back it blows that main fuse. I've tried both unplugged and while plugged in. Also, S901 relay was removed and I put 2 jumper wires in place of it as a troubleshooting step due to the tv not even turning on. It turns on now, and can flip thru channels but as soon as I plug in the cable (coax) or the vcr, it shorts it and pops that main fuse????
I've spent hours on this!! All capacitors / resistors look fine with no bulging. I even checked the capacitors with ohm meter and all appear to be same resistance. Where can i get an S901 relay or equivilent? It's an OEG 12v /250v /10A / 30A ???? relay
You may a grounding (short) on the coax connector on the set. The connector should isolated from ether side of the AC input of the set. Take a ohm meter, set it to 1K. and test between the coax connector (both the shell and center pin) to both sides of the AC plug. You should get NO reading! If you do, their is a short. (The coax cable is grounded where it comes into the house). As for the relay, try Fry's electronics.
Posted on Mar 04, 2008
Does it matter if it is a old tv, one that has a vcr, can I still connect?
Yes, you should be able to connect using a coaxial cable, connect the cable to the TV using the Coax (IN) input on the back of the TV.
Jun 16, 2010 | Memorex MVD2042 DVD Player
No Power
Unplug from the mains and check the fuse in mains cable plug first, if good open up dvd player, there should be 4 screws on the side and 4 at the back, once undone gently lift the metal caseing upwards and towards you when facing the front of the dvd player, inside the player you should see the mainboard (pcb) on it somwhere there should be 1 or 2 small fuses, get hold of a multimetre with continuity testing capabilities, pop out the fuses from the fuse holder and test them, if they are bad that is your problem you can buy them from a electronic store like Maplins.
Post back with your findings.cheers
Jan 30, 2010 | Hitachi DV-PF3E DVD Player/VCR
How do you hook a dvd player up to a hitachi vcr?
Not knowing the model VCR or TV your asking about here is the most common connections. You will need a video/audio RCA patch cable. This type cable is always included when purchasing a new audio or video appliance. If you don't have this cable they are available at your local Radio Shack, Best Buy and other electronic stores.
On you DVD player locate the three OUTPUT connectors at the back of the unit and plug one end of the color coded (yellow, white, red) patch cable into the corresponding jacks.
Plug the other end of the patch cable into the VCR INPUT jacks, once again matching the yellow, white, red, at the back of your VCR.
That's It!
To see your DVD player on the VCR be sure to select INPUT or LINE on your VCR remote. Some VCR's have an additional set of input jacks at the front of the VCR, usually labeled Front or Line 2. Use whichever one is most convenient.
Aug 29, 2009 | Televison & Video
There has got to be a way
I have this model..was trying to hook it up to a directv hughes receiver. After a day of trying and many curse words I found that using this hookup works . Hook up your satellite connection to you tv as usual...Now plug rca cables(red, yellow white) into the corresponding holes on the BACK of the Directv receiver ..now plug the rca cables into the FRONT of the Magnavox player...you will only use find holes for the white and yellow(that's ok) Now hook up up the dvd player to the tv using the rca connection back of dvd/vcr player..or if your tv only has a coax connection you will need a rf modulator available at walmart etc. You will run the dvd/vcr on L2. The key is the connections to the FRONT of the dvd/vcr player..I hope this helps..:)
Aug 03, 2009 | Philips Magnavox DVD/VCR Dual Player
Magnavox dv220mw9 does not have a ant. in,or ant. out. How do I hook up to my direct tv satellite rcvr. My original hook up is from a DTV d10-300 RCVR to a Sylvania vcr/dvd SR2900,which has a antenna in...
have this model..was trying to hook it up to a directv hughes receiver.After a day of trying and many curse words I found that using thishookup works . Hook up your satellite connection to you tv asusual...Now plug rca cables(red,yellow white) into the corresponding holes on the BACK of the Directvreceiver ..now plug the rca cables into the FRONT of the Magnavoxplayer...you will only use find holes for the white and yellow(that'sok) Now hook up up the dvd player2.gifto the tv using the rca connection back of dvd/vcr player..or if yourtv only has a coax connection you will need a rf modulator available atwalmart etc. You will run the dvd/vcr on L2. The key is the connectionsto the FRONT of the dvd/vcr player..I hope this helps..:)
Jun 04, 2009 | Philips Magnavox DVD/VCR Dual Player
VCR to TV
Your FIOS box is typically a Motorola Digital Cable Tuner. In order to record from the VCR your FISO will have control of the tuner, not the vcr. If your FIOS has two video outputs on it for video (av connections), one should be plugged into you tv set and the other should be plugged into the VCR input. Your cable tuner will have to be set for the channel you wish to record ahead of time while the VCR tuner has to be set to record the line input at whatever time you wish to record. If your FISO has one video output line (av connections), your VCR has to be set to channel 3 when you record (provided that is the channel your FISO box is set for when viewing TV over the coax cable) and you will have to attach the coaxial output from the FISO into the coax input of your VCR.
The only way around this is to get a splitter and split the coax line so that the FIOS is connected to the coax as it is now and the VCR is connected to a seperate line using the coax input, however using this configuration will prevent you from recording digital channels. If you have a cable ready VCR, it will probably only recognize channels up to 150.
If you really want to get it to record digital channels without the hassles find out if Verizon has a FISO box with DVR to it or connect a Tivo to your FISO. Tivo will tune the FSIO when it records and it's very user friendly to use.
Jul 28, 2008 | Sanyo DVW-5000 DVD Player/VCR
Trying to hook up your DV220SL8 DVD/CD Video Cassette Recorder. I have an antenna coming in coax but there are no places to plug any of the jacks on the tv.
There are two ways of solving this problem
1.It seems to me that you need an RF Modulator Box. What this does is convert the RCA cables (Yellow,White,Red cables) into coax. You buy the box then plug you antenna and RCA cables into the box. The box has a coax output that goes to your TV. You can then switch from VCR\DVD to antenna.
2. I dont know if your VCR/DVD has it but try hooking up your antenna to the VCR coax INPUT and then hook up your TV to the coax OUTPUT. Both Coax INPUT and Coax OUTPUT should be on the back of the VCR/DVD device. Your going to need an extra Coax wire for this.
Hope this helps
Thanks for reading!
hope this helps
May 01, 2008 | Televison & Video
Vcr hook up
Have you tried to run:
Coax from the wall to your cable box.
Coax from the cable box out to the VCR cable in.
Coax from the VCR cable out to your TV?
What connections does your TV have? RCA or coax?
Mar 21, 2008 | Sharp DV-RW340U DVD Recorder/VCR
No picture
Tvs usualy have a few ways to hook them up. One is a coax cable this is the silver one in the back that you screw in a cable. The second are RCA cables these are the ones that are yellow, red and white. Yellow is always the video and white and red are for audio. If your using the coax cable your tv needs to be on channel 3 or 4 you may have to force the tv to go to that channel by pushing 03 on the remote. If you are using the Rca cables then you need to change the tv to "video 1" or "video 2" this changes the tv from tunner mode to aux input mode. Most DVD players dont have a coax out so you have to use the rca plugs. Some tvs have the rca plugs on the front (video 2) and the back (video 1) or line in. Some tvs have line out also so you need to figure out wich way you have it hooked up. Do a search for the model of your tv and it should show a diagram on how to hook it up.
Apr 07, 2006 | Emerson EWD2003 DVD Player/VCR
Open Questions:
See all Hitachi 53UWX10B 53" Rear Projection Television Questions
Hitachi 53UWX10B 53" Rear Projection Television Logo
91 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
