Question about Toshiba Satellite A60 Notebook
Can't open Hardware setup
Hi, friends,
Recently, I want to use my Toshiba A60 laptop for presentation, when I connected to the projector by VGA port, the projector is displaying properly but the laptop LCD screen blinded, even use button " Fn+F5", no reponse. I tried to change "Hardware Setup", got info " Common Module terminated!", nothing I can do further, your help is appreciated greatly.
Sam
  • SamToronto Mar 04, 2008
    Solved, Thanks!
  • Anonymous Jun 06, 2008
    I have purchased an Home Theatre LCD Projector TV HP-035 and cant get it to display a powerpoint presentation.
    Would be grateful for your help
    regards
    B
  • 123 Answers
Hi Sam,
Is the correct Graphics driver installed onto the unit?
x-b-m
Posted on Mar 04, 2008
How can i display a portable swivel projector from my laptop using a vga connection? Once im connected all i see is a color bar screen on the wall, do i press something to enable the picture?
There are different types of video outputs which your laptop may or may not support. The three most common types of video outputs used with overhead projectors are Video Graphics Array (VGA), Separated Video (S-Video) and High Definition Multimedia Interface (HDMI). You need to make sure your laptop has the correct output corresponding to an input on the projector you will use.
Weigh the strengths and weaknesses of each types of video input and output. VGA projectors are the most common type, indeed it is likely that any projector in current use will have a VGA input. However, VGA video offers the lowest resolution of the these three types. S-Video offers a higher resolution than VGA, but is prone to screen flicker, especially when you are connecting your laptop to a power supply while presenting, rather than running off the battery. HDMI offers the highest picture quality of the three, and supports audio data transfer as well. However, know that HDMI-equipped laptops and projectors are more expensive than those that utilize the other video transfer formats.
Choose a video data transfer standard best suited to your price range and needs. VGA is always the safest bet, but if you are purchasing a new laptop computer, try to find one within your budget with an HDMI output as well, as it will provide the best quality and allow you to transmit audio without the use of extraneous equipment. S-Video inputs are found on nearly every LCD and Plasma television, meaning that if you are giving your presentation connected to a television rather than a projector, this is a viable option as well.
Make sure you know how to tell your computer to recognize that you wish to use a projector as a secondary video output device. On Windows-based laptop computers, this usually involves pressing the "Function" (or "Fn") key, followed by one of the numbered "F" buttons along the top of your keyboard. In most cases there will be a graphic of what looks like a television screen on the correct "F" key (e.g. "F4"), but if you aren't sure consult the manual that came with your specific model.
Connect your video cable of choice to your projector and your Windows laptop, turn the projector on, and press the correct function key. If you have a solid video card, pressing the same key combination a second time will allow you to view your laptop's screen both on the computer itself and as a projected image simultaneously.
Connecting a Macintosh laptop computer to an overhead projector can be a little trickier. You will need a special adapter to connect to a projector using VGA, as well as the standard VGA cable. This is called a DVI-VGA adapter, and is available both from Apple and other electronics vendors. Plug the adapter to the DVI port on your Macintosh laptop, then plug the VGA cable into the projector and the adapter. Turn on the projector, then press and hold the "F7" key on your Mac. You will be up and running in no time.
Try a dry run of your presentation using your own laptop and the same projector you will be using, if possible. It pays to be prepared, and your audience will be able to tell if you are fumbling around for the right function keys on the day you present. Your confidence will help you start your presentation off with a bang, and it will show.
Aug 30, 2010 | Toshiba Satellite A135-S4527 Notebook
I can't connect my data projector to Aspire One Pro Netbook. Why doesn't it show my powerpoint presentation?
just connect the vga cable to vga port of laptop and to the projector and in projector choose the source of display vga or pc mode and in laptop press f5 button or right click on desktop and choose the display mode lcd +monitor it will show you the display on projector.
Have a nice day and do not forget to rate please...!
Feb 02, 2010 | Acer Aspire One PC Notebook
I have connected my Toshiba laptop to a benq PB6210 beamer but cannot get presentation on the screen. I need help
1) Turn off the BenQ power, before connecting your VGA cable to the Toshiba laptop.
2) Once your laptop recognises the BenQ unit, you then need to tell your laptop to send an output signal to the BenQ - you do this by pressing your 'screen output' button (this is usually one of the function keys and you may need to hold the key for 1sec). The output function key can choose either single VGA output, or both laptop screen + VGA output.
"If this has helped you, please rate this solution"
Dec 01, 2009 | BenQ PB6100 Multimedia Projector
How do I connect a projector to my G60
Hello
  1. Start by making sure the laptop and projector are both turned off before you start trying to make any connections.
  2. Locate the video cable -Usually your computer should have a svideo ort out. The projector should have either a hdmi or a RCA immput ports, thus you need a svieo to rca cable. Otherwise your laptop should have a VGA port oout where the projectorr should have a VGA port in.
  3. Make sure both ends are securely connected and tighten if necessary. Use a screwdriver or small pliers to tighten the connectors. A loose connection at either end will prevent you from displaying your presentation.
  4. Locate the audio cable and connect the audio cable included with the projector to the Audio Out on the laptop and Audio In on the projector. Make sure these connections are tight.
  5. Start your laptop and the projector. Make sure to check all connections to ensure they have been properly connected.
Really hope this can help you.
Kind regards
Andrea
Nov 13, 2009 | HP G60-120US Laptop
Connectiing toshiba satellite 2210 to a tv set
The cord you need will either be VGA to S-Video or VGA to RCA depending on which port is on the tv.Once you have the cord hooked up to both,You will need to switch into presentation mode on the laptop using the FN + F7 keys.
Please take time to rate this fixya
May 14, 2009 | Toshiba Satellite A205-S4617 Notebook
Projector cannot detect my connection to my laptop
try hitting function 8, had the same problem giving a presentation and that took care of it.
Feb 12, 2009 | Taxan U6-132 Projector
My toshiba tlp 261 won't project the image
hi try using the function key to toggle the display output form the laptop.every laptop when connected to an external display like projector works in the multiple diplay mode.in this mode the laptop vga output can be seen in 3 modes------ only laptop screen, only external deipaly(projector) & both laptop & projector.check this & this should work fine
any further help contact shyam +919867355202
Feb 07, 2009 | Toshiba TLP 261 Multimedia Projector
Video projector from a laptop
You can connect the Projector to the VGA Port of the Notebook which is a Blue Port which can be seen at the rear of any desktop computer to which we usually connect the Monitor to.
The VGA Port will have 15 holes on it and should be in Blue colour.
You can locate the VGA Port at the Left side of the Notebook.
Locate the port according to the information available below :
http://h10032.www1.hp.com/ctg/Manual/c00726464.pdf
Refer to page number 14 (18 of 32) in the manual.
Once you connect the Projector to this port, hold the FN key and press F4 key once.
This wil get the Display on the Projector connected to the Notebook.
If you just want the display only on the Projector, hold the FN key and press the F4 again.
Now, if you want the display back on the LCD of the Notebook, Press the FN + F4 third time.
Hope this helps..
Aug 31, 2008 | HP Pavilion dv2000t Notebook
Power Point Presentation Using Sanyo Pro Xtra X Multiverse Projector
Don't forget to select the Fn key and F4 on HP laptops. It could also be the Fn key and F8 depending on the laptop brand. It is the apple key and the F7 key on a Mac notebook. On Laptops this will toggle the video to the aux port where the monitor cable connects to the projector. There are 3 modes. video on the laptop screen, video on the laptop and projector, or video to the projector only.
Master Rod
Mar 11, 2008 | Sanyo PLC XU35 Multimedia Projector
Toshiba Satellite A60 Notebook Logo
345 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
