Question about Canon PIXMA MP830 All-In-One InkJet Printer
Error: The type of Printhead is incorrect, Install the correct printhead.
My printer has been working fine, today when I went to print I get the following error, "The Type of Printhead is Incorrect, Install the correct Printhead"
I have not replaced anything, it is the factory original printhead, roughly 6-8 months old. Reset does not help.
I have a Canon PIXMA MP830 printer with the same problem have reinstalled the printhead but no Luck with printing receive the same message. Thanks
  • 7 more comments
  • Anonymous Mar 28, 2008
    My printer
    Printhead"
  • Alesa Apr 22, 2008
    Canon PIXMA MP830. This error message popped on printer screen, "The type of print head is incorrect, install the correct print head." Any suggestions on how to trouble shoot?
  • Anonymous Jun 20, 2008
    Same story. The other day went to print without changing a thing and the printer alarmed and indicated that the incorrect print head was installed and to replace it with the correct print head. Sounds like a faulty error to me. There may be something with the cleanliness of the print head/contacts. I'll check these and report back.
  • aphoneguy Aug 04, 2008
    i have the exact same problem
  • Anonymous Oct 07, 2008
  • pandan348 Nov 28, 2008
  • Anonymous Feb 02, 2009
    darn it i got the same problem...time for a new one?
  • alexinaus Mar 04, 2009
    I had the same problem - it just appeared on the display and I hadn't used the printer at that point. I removed the head, cleaned the contacts with some toilet paper (seemed appropriate) re-inserted, turned it off for about 10 minutes and it seemed ok. Printed a document, still ok. This morning I awoke it prom it's sleep mode and the message is back. At this rate I am going to run out of toilet paper.
  • PrinterTroub Apr 06, 2009
    "Error: The type of Printhead is incorrect, Install the correct printhead."
    I had the same problem, and followed the directions on resetting the print head from canon support website and it worked.  I also used toilet paper to clean the print head contact.
Ok i know this is kinda old, but i found a solution.
First to those people to state I found a solution from hp, cannon etc etc and not give out the direct link, or instructions, then whats the point fing posting????
This error happens when you install an oem cartridge onto your system. Or havent used it in a while, so the machine is somehow misfigured.
This solution is for canon mp800, simply switch off printer. HOLD stop/reset and press and HOLD on/off button. release stop/reset. Now press stop.reset twice. then release on/off button, press stop/reset 4 times, wait 20 seconds, press on/off button twice.
switch machine back on and the printer should find the cartridges.
This method maybe the same for your mp*** if not google RESET CANON PRINTER MP*** and you'll find the correct buttons to press.
here's a printer on reseting a bunch of canon printers http://tricks-collections.com/reset-printer-canon-mp140-mp160-mp180-mp210-mp220-mp460-mp470-mp500-mp510-mp530-mp600-mp610-mp800-mp820-mp810-mp830-mp960-mp970/
good luck.. and FU canon for adding you scamming chips into cartridges.
Posted on Jun 11, 2010
  • Julie
    Julie Nov 20, 2015
    I follow the instructions for the print head error and Behold it worked! I had also cleaned the print head by removing it as shown on youtube and my goodness was it clogged with ink. Love the Internet!!!
  • Julie
    Julie Nov 20, 2015
    I ran the print head under warm water as instructed turning it over and over under the flow of water. shook of excess water and gently wiped the contact. Great Like new.
Don't know if this was what really fixed it, but I cleaned (with toilet paper) what is called the "ink supply ports" as well. I just brushed over them very lightly. The Canon support site says not to touch them, but since it would otherwise mean buying a new printer, I figured it was worth a shot.
Also, I removed and replaced the print head twice.
Posted on Jul 27, 2010
  • sjklein007 Oct 10, 2010
    I read all the solutions listed and went to the Canon Tech Support site and learned how to remove the printhead. The Canon instruction were outstanding by the way. I removed the printhead, cleaned it up, put it and the ink tanks back in, and got the same error message. Went to a Canon store in Bangkok and amazingly they had a new one, however a bit pricely ($57). Put this one in and I was back in business--it worked! I was thinking the worst and a little worried that I would be waisting $57. Thanks all for taking time to write about your trouble-shooting adventures.
    Habit-Forming:
    New Friend:
  • 15 Answers
Hello woofer3b6
This error may come accompanied by error (U052), happens often and I think I can help with the solution, but you must follow the steps in the same way as presented below, remembering that if you have any other questions, just write a comment, I'll be here To help you.
in case the problem is with the cartridges
  • Remove the ink cartridges and place again
  • If the error occurs when you have installed new ink cartridges
This is a solution if the problem is with the printhead
  • Remove the ink head and put it again
  • Clean the print head using a little alcohol in places where you see excessive ink
  • If the problem persists yet replace the printhead
Here is other information can help you, remember im here id you have any other cuestions:
Error printhead type is incorrect install the correct printhead Canon...
Error: The type of Printhead is incorrect, Install - error-type-printhead-incorrect-install-xnnjabddbe1z3hwtjta3ekn0-4-0.jpg
You can look at the electrical manager, ie connect the printer to another location, often the little power that it can receive the printer, can cause these errors.
Clean the printer contacts, which connect to the print head, here something that can help you in this regard, it is not for your Canon printer, but show which is the important part to clean.
How to clean ink cartridges en Rellenado
i hope help you, nice day!
Posted on Nov 20, 2015
Go to www.canontechsupport.com and follow the thread to get to the support for your mutifunction machine and error message. Removing all the tanks and reseating the printhead worked for me, although it appears it didn't work for others.
I carefully wiped some of the ink from the edges of the printhead assembly, but don't know if this really did anything. My 830 is about 18 months old and I have been using both Cartridge World and Canon ink tank replacements.
Posted on Apr 29, 2008
U052 error - The type of print head is incorrect. I have not changed the print head from new, and have done all that was suggested in the on screen help list. It would appear that I have to replace the...
u Can Follow this step :
http://support-sg.canon-asia.com/contents/SG/EN/8200986100.html
if that reference can't solved, in other reference i found this statment
http://www.canon.co.uk/Support/Consumer_Products/products/Fax__Multifunctionals/InkJet/PIXMA_MP_series/MP620.aspx?faqtcmuri=tcm:14-610963&page=5&type=faq#Print%20head%20is%20not%20installed.%20Install%20the%20print%20head.%20U051/The%20type%20of%20print%20head%20is%20incorrect.%20Install%20the%20correct%20print%20head.%20U052
" Print head is not installed. Install the print head. U051/The type of print head is incorrect. Install the correct print head. U052 Follow the directions given in your setup sheet to install the Print Head.
If the Print Head is already installed, remove the Print Head once and then reinstall it."
Nov 17, 2010 | Canon PIXMA MP600 all-In-One InkJet...
I need to replace the printhead the printer keeps coming up error the type of printhead is incorrect install the correct printhead
The part number is QY6-0061-000, it will cost you around $60.00, I believe www.precisionroller.com has those in stock, but sometimes amazon will have them too.
Jan 14, 2010 | Canon MP830 All-In-One Printer
Canon Pixma MP600 - Error Message U052 ... incorrect print head
Hi, sounds like you need new printhead, take a look on amazon for replacement Amazon com canon mp600 printhead I hope this was helpful. Cheers
Nov 27, 2009 | Canon PIXMA MP600 all-In-One InkJet...
The type of print head is incorrect. install correct print head
That happens when the printhead goes out, you'll need a new printhead,QY6-0075-000 around $50.00
Aug 11, 2009 | Canon MP610 Photo All-In-One Printer
Error msg - Print head is incorrect.
The printhead has gone out, you need a replacement, # QY6-0059-000. Around $50.00
Aug 03, 2009 | Office Equipment & Supplies
Incorrect printhead
It just means that the printhead is defective, All of the Canon machines say that when the printhead goes out.
Jul 27, 2009 | Canon PIXMA MP830 All-In-One InkJet...
CANON MP830 all in one is sayin" the type of printhead is incorrectn Install the correct Printhead."
Hi follow the instructions as above...
ie Remove inks and print head...
But instead...
Whilst Canon print head is out...
Use cotton wool and alcohol and clean electrical contacts on back of print head and where they make contact inside printer.
Then install print head and inks and test.
If it does not work you may need to replace print head.
Mar 14, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
48,701 people viewed this question
old marine
old marine
