Question about ASUS P5LD2-VM Motherboard
Restart problem my mother board is of asus dual core. my pc is getting restarted again and agian. i m unable to operate my pc please solve my problem soon
    Scholar:
  • 64 Answers
Hi mewada,
If the system is rebooting itself, it may not be an issue with the drivers - there may be a hardware issue or an improperly seated CPU fan or other peripheral.
I'm not sure from your problem description whether you're able to get into Windows at all - does it just randomly reboot, or does it Blue Screen and never let you in at all?
If you're able to get into Windows and it reboots now and then, try installing the proper CPU drivers. For many games and some other applications, dual-core AMD CPUs require a specific driver. There's also a dual-core optimizer you may want to try. Check at the top of this list.
http://www.amd.com/us-en/Processors/TechnicalResources/0,,30_182_871_13118,00.html
Otherwise, please be more descript as to when the system reboots and (if you know) what you think you might be doing when it reboots. Faulty memory (RAM) modules and CPUs are the main causes of systems rebooting (other things are generally at fault for freezing up or blue screens).
Ben
Posted on Mar 04, 2008
Swap single core to dual core. and system shuts down for hardware problems. emachine el1300g-01w using windows 7 mother boards with am2 socktet. i installed the dual core processor and the pc ran good for...
I installed a dual core in my 1300g no problems. I we t against advice and tried a 65w tdp chip for a couple days and it ran a bit hot. A dual core am2 CPU for this machine must be 45w tdp or under. Research the dual core you tried. I'm betting it was too hot or needed to much power. Also the heatsink is crappy too. If you need a better one find a lga 775 heatsink with back plate. They it right in but check for height to fit in your case.
Feb 15, 2011 | AMD 4800+ Athlon 64 X2 Dual-Core Processor...
Mercury pi845g mother board restarts again and
The problem you are facing is generally caused by Defective rams please remove the rams clean the copper contacts by a soft cloth and then reseat them.
Feb 10, 2010 | ASUS P5LD2-VM Motherboard
Sir can i change my processor to dual core using this asus p5v800-mx?
Dear sir,
Deffinately This Mother Board supports Dual core 2ghz-2.8Ghz And Pentium D 3GhzProcessors.You can Upgrade your PC.
P5V800MX motherboard supports the latest Pentium 4 CPU from Intel in LGA775 package. With 800/ 533MHz FSB, Hyper-Threading Technology and core-speeds up to 3.8GHz and beyond, Intel's LGA775 Pentium 4 is one of the fastest desktop processors to date. Enjoy the extraordinary CPU power from the latest dual-core CPU.
Aug 04, 2009 | ASUS P5V800-MX Motherboard
Unable to shutdown the computer
it is the problem your computer operating system or motherboard bios setup problem . You restart your pc after restart then press dell key then prevew your bios setup option then choice bios defalt setup then press F10 press Y restart your pc .
Jul 21, 2009 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
Unable to install turboc++ in new mother board with 2.0 dual core
i suggest you an alternative method to open the turboc++ programme you can create a batch file for the tc executable file by opening the dos prompt and creating it( c:\\edit tc.bat
c:\turboc\bin\tc.exe) and send this shortcut to the desktop
May 28, 2009 | Computers & Internet
I lost my mother driver software cd.Model of my mother board is M2A-VM HDMI.Please send me it.
Dear friend Go there http://support.asus.com/download/download.aspx?SLanguage=en-us
You may see top the left corner Search by model please put the model number here
your model is M2A-VM Then click the search button.. you may put your operating system then you find all for download thanks.
Mar 26, 2009 | ASUSTeK M2A-VM HDMI Desktop Board - Athlon...
If I were you, I'd use dev-c++ or MS Visual C++ exprees, both are freely available on the Internet and are excellent IDE's for programming in C++.
Dev-C++: http://www.bloodshed.net/devcpp.html
Visual C++: http://www.microsoft.com/express/vc/
Dec 08, 2008 | ASUS P5PE-VM Motherboard
Processor for P5VDC-MX
Hey there alcouto, your motherboard supports Intel Celeron, Intel Pentium 4, and Intel Pentium D processors. The socket set is LGA775. The FSB should be no higher than 800Mhz. It appears you have purchased the wrong CPU for your board. I hope the rest of the info helps you on your next purchase. Good Luck!
Jan 29, 2008 | ASUS P5VDC-MX Motherboard
Ihad computer pentium 4 mother board asus 845 processor 1.7 my problem that computer open windows normally then making restart again can u solve it
1.) You are infected
2.)One of ur drive wont work propertly
3.)Problem with ur Power Suply
4) Problem with RAM MEMORIE
And use ur WINDOWS XP CD to repair windows
Oct 10, 2007 | Intel Motherboard
Pc restart problem
Yes, your mobo Asus P5LD2-VM support CPUs with Conroe-core ("Core 2 Duo"). http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=P5LD2-VM But for new CPUs strongly recommended use last BIOS version - 1401 from 2007/08/14. http://dlsvr01.asus.com/pub/ASUS/mb/socket775/P5LD2-VM/P5LD2-VM-1401.rar
Oct 03, 2007 | ASUS P5LD2-VM Motherboard
ASUS P5LD2-VM Motherboard Logo
142 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
